96 V6~97 GT
JY Turbos
Ok. before i do this i plan on upgrading my gears nd tlok and a shift kit.. runnin TTurbos on a 3.8 auto would it be better to run 3.73 or 4.10s?? also plan to install new auto shift and probly shift it as manual. if i did so on a TTurbo setup would the 3.55s be better?? its a 96 nd i wanna get it runnin around 275-350RWHP Daily Driver.. any input would be great..
-ON- CAI -Comin Soon- UDP Upper Intake Spacer O/R H-Pipe Flow40s |
MM's Database Error
if you only want that range of hp, you will be better suited for a single turbo setup.
for boost the 3.55s are gonna be ideal, but they dont make them for the 7.5 rear.
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
96 V6~97 GT
ok. well to upgrade to an 8.8 rear end what all would i need??
would i need to get a new trans or driveshaft?
MM's Database Error
i havent done the swap myself, but i think you can just swap the whole rear end assembly and it should bolt right up. im not 100% positive on that though as far as the driveshaft connecting right, but im sure someone can fill that part in. you dont need a new transmission though, i know that for sure.
It will bolt right up. No new parts required.
Did my swap last summer in a couple of hours without a hitch
CAI, Screamin' Demon Coil, Livewires, Steeda Tri-ax, Steeda Clutch Quadrant and Adjuster, UDP, 8.8 rear end with 3.73's, 1/2 inch VAP intake spacer, SCT X3. |
muneris pro ego
like Johnson said, 3.55's are ideal. if you want to stay with the 7.5, you can get 3.44's, which wont be too much different thatn the 3.55's. if you do stay 7.5, make sure you get a detroit true trac
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
97 v6 mustang
10.71@125
Your transmission should be fine, if you have an auto a jmod and converter would help a lot. As far as getting to your hp mark i would recommend ported heads and intakes, of course i always say to forge the bottom end.
The 7.5 rear should hold up, but a 8.8 would be better. Ive seen 7.5s blow out at those hp levels, and have seen some hold more.
97 v6 tma turbo 600hp and 10 sec v6 member xxxhp @21psi 10.71@125mph http://www.youtube.com/watch?v=hBoRWBr77Do Fastest Single Port V6 Mustang w a Ported Stock Upper Intake www.gssmotorsports.com |
Threads Similar to: JY Turbos
| Turbos | ShadowStrom | 2005 - 2010 V6 | 11 | May 10th, 2012 02:43 PM |
| Anyone know about Turbos or a SC on a V6 | Pastor J | 2005 - 2010 V6 | 25 | October 19th, 2008 11:48 PM |
| Turbos On A V6 | myPONYisHARD | V6 Mustangs | 29 | December 18th, 2007 07:36 PM |
| Turbos | homeboy2kfun | V6 Mustangs | 32 | October 27th, 2007 10:26 AM |
| turbos | Xman | 99-04 | 15 | April 26th, 2007 07:58 AM |
