Sub Frame Connectors... benifits?
Old February 2nd, 2010, 03:30 AM   #1
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
Zatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud of
iTrader: 15 reviews
So, what are the benifits of Sub Frame Connectors? AM has a good priced set and I was considering doin some more suspension mods.
So, what do you get from them exactly?
Black Bullitt Rims FT/FS
Looking to Sell or Trade for Silver FR500s
Looking to buy a lot of 99-04 Interior Pieces
If you have any for sale, PM me
Old February 2nd, 2010, 03:42 AM   #2
Imran's Avatar
01
Imran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud of
Stiffens up your car. Id get them first.
Old February 2nd, 2010, 04:41 AM   #3
WhtStang00's Avatar
2000 Mustang V6
WhtStang00 will become famous soon enoughWhtStang00 will become famous soon enough
Send a message via AIM to WhtStang00 Send a message via MSN to WhtStang00
White 2000 V6 Mustang|Black Saleens 18x9|Flowmaster 40s|AM CAI|8000K HIDs|SCT XCAL III/H&R SS
Old February 2nd, 2010, 09:42 AM   #4
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Be sure to get the full length ones. And check out MM's version, then compare them to the AM ones. I don't know off top the differences, but you want the full support that the weld-in MM one has. It has a cross beam at the seats as well. So long as the one offered on AM has these characteristics, it should be alrite. People praise the MM FLSFC's. Def. a good mod for chassis stiffening, helps in cornering but also prevents flexing upon hard launching.
Old February 2nd, 2010, 12:43 PM   #5
stangcharger's Avatar
stangcharger is on a distinguished road
Send a message via AIM to stangcharger
full length keep the frame of the car from twisting. To give you an example we saw signs of my frame starting to twist at only 195rwhp.
436rwhp/378rwtq tuned by HPP
www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com
Old February 2nd, 2010, 12:50 PM   #6
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
not meaning to thread jack, but i was just thinking about the helpful characteristics of sub frame connectors and i was wondering, would they actually help in a wreck too....to help keep the frame from twisting up, in turn helping you stay safer?
SCT Mass Air Flow Sensor $200
Old February 2nd, 2010, 12:54 PM   #7
Teamsterjohn's Avatar
2005 Mustang V6
Teamsterjohn is on a distinguished road
I just bought a pair off a guy on ebay for my 05. There made by Tommy Brown I belive. There also good for if your car is lowered and you now have a good jacking point to jack up you car.
CAI, UDP, Eibach Pro Kit, Predator performance tune, C/C Plates, Ajustable Panhard Bar, 17 inch rims and tires, GT duals with Pypes X pipe. GT Rear Bumper.
Old February 2nd, 2010, 01:38 PM   #8
goren813's Avatar
'00 3.8L & '05 4.6L
Woody that's a good point... I wonder though, because modern cars are made so that some areas are crush areas, while others are built to remain rigid. So if Stangs weren't built to have the sub frame so rigid, it may be quite the opposite of what you suggested, as in it may be more dangerous. IF the crumple zones aren't able to crush as they should, more energy may be transmitted to the cabin, which means to the people inside, which is bad. I really have no idea though, this is just another way it COULD go.
Old February 2nd, 2010, 09:05 PM   #9
Assassin_Dan's Avatar
1998 Mustang V6
Assassin_Dan is on a distinguished road
Send a message via MSN to Assassin_Dan
I thought crumple zones were just located behind the bumpers?
CAI, Screamin' Demon Coil, Livewires, Steeda Tri-ax, Steeda Clutch Quadrant and Adjuster, UDP, 8.8 rear end with 3.73's, 1/2 inch VAP intake spacer, SCT X3.
Old February 2nd, 2010, 09:26 PM   #10
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
no, the whole body is supposed to collapse, and i believe on most cars at least the engine is supposed to slide under the cab.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old February 2nd, 2010, 09:35 PM   #11
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
Mach 1's and convertibles come with sub frame connectors from the factory.
The stiffer the frame the better. Crumple zones are really only in the front of the car from the bumper to the fire wall.
Or at least thats what I know about the zones.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old February 2nd, 2010, 10:14 PM   #12
2000 Mustang v6
winnie51189 will become famous soon enoughwinnie51189 will become famous soon enough
Send a message via AIM to winnie51189
Why the hell would the whole body collapse? That's a terrible design, especially considering the people tend to drive from within the body of the car.
Old February 2nd, 2010, 10:25 PM   #13
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
It absorbs the impact and protects the people inside the car. Does tend to total the car though.
Old February 2nd, 2010, 10:42 PM   #14
Codeman's Avatar
That is why i said the cab is not supposed to collape. This is why cars nowadays are safer than cars of the seventies, and also why more cars are totaled. Like ^ said. The cars of the seventies you could smash into each other like demo derby and they would not crinkle, and also then all of the energy from the impact is then transfered to your body. The new cars watch a demo derby crinkle fast. This is because the force of the impact instead of being absorbed by the people is absorbed by the car. Sure it totals out your vehicle, but i would trade a vehicle for my life any day.
Old February 2nd, 2010, 11:18 PM   #15
2002 mustang v6
joshridge is on a distinguished road
Send a message via Yahoo to joshridge
^ forsure!
Old February 2nd, 2010, 11:33 PM   #16
2000 Mustang v6
^Sarcasm.
I'm pretty sure the frame as a whole is supposed to crumple, the specific areas, that were designed to crumple do, but only to prevent the death of the passengers in the passenger areas. Our cars don't actually have frames. Or atleast not the type of frames as the cars in the 70's had. We have unibodies. And although the crush zones are helpful they are only there to help divert the forces in a controlled fashion. Not sure if you've been in an accident or not but you still get a shit ton of engery transfer. That's why we have safety restraint systems in our car such as airbags, seatbelts, etc.... I would say they help even more so than the crush zones.
Old February 2nd, 2010, 11:34 PM   #17
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Being a man of science I will have to disagree with that statement.
Old February 2nd, 2010, 11:45 PM   #18
2000 Mustang v6
This is fun! Which one? If it's about the safety restraint systems being more helpful than the crumple zones. I guess really it depends on where the accident occurrs. If it's the classic T-bone accident then airbags and seat belt would do more to help than the crush zones that never got touched in this accident. However if it's a head on collision, the crush zones do help, but without airbags and seatbelts you're likely dead regardless(either faceplant into the steering wheel or fly out the windshield onto/around the other car).
Old February 3rd, 2010, 12:41 PM   #19
Codeman's Avatar
Ok, i agree with you on the side impact, since the car is not going to collapse the same way as it would in a frontal or rear end impact. But Even if the old cars of the seventies had airbags, due to the fact that all of or most of the impact is transferred to your body it would cause major porblems. I know that you still absorb a lot of the impact even in new cars, that are meant to crumple, but you do not absorb near what it could be if you had a car that did not crumple. I agree however that for the systems to work correctly you must be using your seatbelt, and your airbags.
Old February 3rd, 2010, 12:46 PM   #20
goren813's Avatar
'00 3.8L & '05 4.6L
There are many studies comparing crash results and injuries from modern to older model cars. New cars are 293892838 times safer, this of course includes better seat belt design and construction, as well as airbags and the crumple zones. The latter makes a huge difference. Injuries are on such a case by case basis though, some times people are killed because they WERE wearing the seatbelt, just because of the specific crash dynamics. On any given day however, belts, bags and technologically advanced chassis will save your life. And plus in FL now its the law to buckle up.
Threads Similar to: Sub Frame Connectors... benifits?
Sub frame connectors? 07 STROKER 2005 - 2010 20 June 5th, 2008 06:30 AM
Sub-Frame Connectors ArmyChargedGT 99-04 19 April 11th, 2008 02:44 PM
Sub Frame Connectors e3sean 5.0 Mustangs 20 November 19th, 2007 12:37 AM
Sub-frame connectors 2000Mustang The Clubhouse 2 April 4th, 2007 09:59 AM
Sub-Frame Connectors cristo General Tech 7 March 20th, 2007 04:12 PM
