lights dim
when driving down the road and coming to a stop or slowing down with the rpm's droping, my headlights and dash board lights dim for a split second or two.
This happens one or two times while the rpm's are droping. What would cause this? |
MM's Official Lucifer
Alternator. Battery... Have them both checked at an auto store = free. Check battery terminals and cables for corrosion.
Mine does it also, but mine is because I have UDPs. I run my headlights, foglights, with dash lights, gauge lights, gauges, cd player, with the mach speakers. Mine only dim when I am idling. So if you have UDPs that may be the problem. Otherwise, I would try cleaning battery cables first, that is the easiest. Then you can test your battery using a multimeter. Then if both are good, then you can google how to test your alternator.
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
Threads Similar to: lights dim
| Guages/dash lights are dim | Scumlabs | Audio/Video | 7 | December 21st, 2009 02:09 PM |
| hazard lights flashing real dim | ddarkslayer | 5.0 Mustangs | 11 | September 17th, 2009 01:54 PM |
| Luminics bulbs seem dim | Zatrekaz | Audio/Video | 8 | July 15th, 2009 12:27 AM |
| Anyone else with one foglight more dim than the other? | mustangmanic | 99-04 | 9 | April 29th, 2009 01:13 AM |
| dim dash lights on 67 | pritchr1 | Classic Mustangs | 7 | June 15th, 2008 02:09 PM |
