Aluminum Driveshaft - Page 2
Old August 11th, 2010, 05:10 PM   #21
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
2004 Bolt on & Cammed 3.9L V6
Old August 11th, 2010, 05:10 PM   #22
walt1120's Avatar
14.45 @95.8
btw, ive heard aluminum flywheels arent the best for a DD
Old August 11th, 2010, 05:46 PM   #23
Jetflo's Avatar
2001 3.8L w/ 5spd
Jetflo will become famous soon enough
Smile
Aluminum flywheel has a bad vibe
I've been told the same thing by most tuning shops around here. I was really set on it for a while.
Racing starter, lighter battery, a lighter Steeda K member, coil overs for the front struts, aluminum upper and lower rear control arms all appear to be better options for saving weight than most rotating parts. You could get a V6 manual under 3000 lbs with these parts.
The drive shaft remains a good question. I think I want the composite over aluminum but wow is it expensive @ $900! It would not be to save weight.
There is no speed limiter on my car thanks to SCT Livewire so I'm always worried about the 110 MPH rating on the stock drive shaft. I have discovered it is good for 130 MPH indicated but for how long?
Are you absolutely certain you're not pregnant?
Old August 11th, 2010, 05:54 PM   #24
6Stang99's Avatar
2000 Jeep Grand Cherokee
6Stang99 will become famous soon enough6Stang99 will become famous soon enough
I put an alum. driveshaft in my car to see if it would help minimize the vibrations I was feeling while cruising in 5th gear on the highway. And indeed it did.
Cammed '99 Mustang V6 -- Sold
Supercharged '89 Hatch -- Sold
Looking for a project Stang now...
MILITARY CREW - TERMINAL LANCE - MARINE CORPS. INFANTRY
www.wotmustangs.com
Old August 11th, 2010, 05:58 PM   #25
NorCalWhtHrse's Avatar
2001 Mustang V6 Coupe
NorCalWhtHrse has a spectacular aura aboutNorCalWhtHrse has a spectacular aura aboutNorCalWhtHrse has a spectacular aura about
links to aluminum driveshaft for the new edge...
Old August 11th, 2010, 06:13 PM   #26
6Stang99's Avatar
American Muscle or Latemodelrestoration. They both have them. I just got the driveshaft for the 94-95 5.0.
www.wotmustangs.com
Old August 11th, 2010, 06:24 PM   #27
Jetflo's Avatar
2001 3.8L w/ 5spd
vibrations from wear or age or what?
How many miles were on your car when you swapped the drive shaft?
Do you remember the vibration being more noticeable at a certain speed?
Old August 11th, 2010, 06:31 PM   #28
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Speed Concepts - M-4602-G - Aluminum Driveshaft for 1979-1995 Mustang/GT/Cobra 5.0L V8 and 1994-2004 3.8L V6
Old August 11th, 2010, 06:34 PM   #29
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Originally Posted by Jetflo View Post
Looks like you own a V6 too by your sig Stroker
I own 2 of them...
But notice I said "your" and not "my"
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old August 11th, 2010, 06:57 PM   #30
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
This Zombie thread was reawakened and has turned into nonsense haha
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old August 11th, 2010, 08:20 PM   #31
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
Nobody ever said stock V6s weren't nice...we just said they're slow. And if you disagree, I don't know what to say. I just rode in my friends 2009 V6 and it was very disappointing...especially since I did work to my car. I didn;t even remember what a stock V6 felt like, and that one had probably 20 more horses than mine did stock.
Old August 11th, 2010, 10:42 PM   #32
walt1120's Avatar
14.45 @95.8
yeah but if you have a 3.8 auto with stock gearing its like night and day compared to an auto 4.0
2nd gear pulls so shitty on the 4speed when you first shift into it, on the 5speed auto when it shifts to 2nd its already in the powerband like 4500rpms
Old August 11th, 2010, 10:43 PM   #33
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
^ That is why you buy a manual
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old August 12th, 2010, 03:10 AM   #34
Jetflo's Avatar
2001 3.8L w/ 5spd
Automatics used to be a major handicap
From 1964.5 to about 2005, the automatic was a handicap to acceleration regardless of engine size or model. Year after year, test results typically show a second or more difference in the 0 to 60 time. For pre-2005 Mustangs, swapping to a manual will give higher rwhp and torque on the dyno. This swap is just enough of a big job that I think most probably accept the automatic and make the best of it.
I wish people would buy more manual transmission cars. Now that the latest automatics are just as good or better than manuals the balance will likely swing to even fewer manual transmission cars being sold. Even if the benefits have been erased, I still find driving a manual to be a lot more fun.
Old August 12th, 2010, 03:53 AM   #35
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Could be the almost 40rwhp they dyno stock over the 3.8?
Old August 12th, 2010, 04:58 AM   #36
nukeman13's Avatar
99 mustang v6
nukeman13 is on a distinguished road
my car is mostly stock and i still out pulled an 08 model v6 with 5 speed auto trans it had the gt package but im not sure what the difference is besides looks
but i was surprised how much faster it was than the v6's with 4spd auto trans
Old August 12th, 2010, 10:10 AM   #37
Codeman's Avatar
I raced an 05+ v6 that the guy said was stock. He blew me out of the water. NO joke I had gears everything. All I know was he had a shaker hood and exhaust, but I think he had a SC on it cuz I could hear one well not for long as he blew by me.
Old August 12th, 2010, 12:48 PM   #38
goren813's Avatar
'00 3.8L & '05 4.6L
What are your "mostly stock" mods? Even an auto 4.0 would have you in a real race...
The 4r70w isn't a slouch for an auto either really, gets praises at the track and can be improved with a shift kit.
Not that I'd ever take an auto over manual but I think its exaggerated how much it lags behind a manual, if you've got a less than perfect driver in the manual, the auto will take it all else equal.
Old August 19th, 2010, 12:13 AM   #39
2000 Mustang v6
winnie51189 will become famous soon enoughwinnie51189 will become famous soon enough
Send a message via AIM to winnie51189
An aluminum flywheel wouldn't be bad for a dd unless you drive up a lot of hills.
Threads Similar to: Aluminum Driveshaft
Aluminum Driveshaft goren813 V6 Mustangs 8 February 10th, 2009 09:59 AM
aluminum driveshaft... 97fordsixer V6 Mustangs 10 May 6th, 2008 01:26 AM
Aluminum Driveshaft adam0421 2005 - 2010 2 June 7th, 2007 01:29 PM
ALuminum Driveshaft USARMY1983 5.0 Mustangs 0 April 13th, 2007 11:51 AM
