The lifters?
Well I was warned when I bought my car from my dad.. he noticed a a ticking sound that I thought was the TOB like on most standards and such... With further research.. I dont think its the TOB at all. Its something to do with the lifters.. was wondering if anyone could give me a better definition or understanding to what exactly these were for and if its something I should be concerned about..and if so..price range for correcting?
#2 | |
Dancing Naked In The Rain
Also, my TOB is going out. It's got a nice squeak when I let the clutch out
The lifter is a hydraulic device that automatically adjusts the valves. A light ticking noise especially if it's only when the car is first started and goes away in a few minutes is normal. If it persists it may help to run the engine for a while with a quart of automatic transmission fluid mixed with 4 quarts of oil. If that doesn't help then the lifters and probably rocker arms should be replaced. I found that the stock rocker arms can wear to the stage where the lifter can't compensate any more. The cost for parts- lifters, rocker arms, and push rods will be about $350. It requires removing the upper and lower intake manifolds.
2007 mustang v6
8.903 1/8 @74.96
My father swears by this stuff called "Roslin" to clean lifters. you just replace 1 quart of oil with it on your next oil chang. lifters get gummed up pretty often on high miliage cars. cleaning your system could fix your problem and save you alot of money as well. or you could just have a rocker arm out of adjustment. you can get "roslin" at your local auto parts. it's in a dark red bottle.
#5 | |
The soul stealing Ginger
hmmmm i like the sound of this Roslin stuff. going to try it with my lifter, little bugger.
I put 1qt of automatic trans fluid in with the oil on our 94 cherokee and it's got about 310,000mi on it. after about 500mi, the oil was changed and it does run a lot better than before. Of course I also changed the air filter and the fuel filter as well so that made a bigger difference than the auto trans fluid I'm sure. But I still do it about 500mi before every other oil change.
Look Ma! My First Post!
very interesting and healthy discussion about mustang automobiles
You know you're getting old when you stoop to tie your shoelaces and wonder what else you could do while you're down there. testking 350-001 | testking 640-802 | testking SY0-201 | testking 642-813 |
I'm doing it wrong
04 Grand Cherokee
Wheres the ticking sound coming from? I have a ticking sound as well when I first start my car and I am looking at every possible issue before spending money.
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
01 True Blue v6
to slow to matter
If its a lifter, the ticking would be comming from the middle of the engine. A lot of people who here ticking find out its usually a leaky exhaust manifold.
I'm doing it wrong
04 Grand Cherokee
Alright thanks, just checking mine isnt coming from the middle of the engine.
Resident badass
You need to bring it into sears Saturday and let me listen to it. A lot of people mistake the famous exhaust leak for a lifter tick.
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
14.37 @ 96
tick .. tick ... tick .... tick ..... tick
TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK TICK !!!!!!! =) |
1999 Mustang V6
or an injector.... try some injector cleaner and open it up on the highway
Resident badass
Lol. On shop ket when I was looking as fuel system specs the other day it has a big bold warning that says not to clean then because the have something that keeps them clean..
Well i have a really bad tick, more like a clank but it's not a rod knock or a loose rocker arm. Im in the process of tearing it apart, im thinking its a bent rod or broken valve
14.37 @ 96
any missfire ?
bent rod suucks asss I know
#18 | |
14.37 @ 96
![]() mroe detail on this noise and we'll try and help ya. |
Resident badass
14.37 @ 96
I was thinking push rod but ok
Threads Similar to: The lifters?
| what lifters? | McMustang5.0 | 5.0 Mustangs | 0 | November 6th, 2009 10:42 PM |
| lifters | 2000GTCONVERT | 99-04 | 6 | September 4th, 2009 11:42 AM |
| Which lifters ??? | 86_Notch | 5.0 Mustangs | 4 | March 23rd, 2008 11:56 AM |
| lifters | terribleonexx88 | 5.0 Mustangs | 9 | March 11th, 2008 07:37 PM |
| Hydraulic Lifters | ssajdowitz | V6 Mustangs | 2 | October 30th, 2006 10:23 PM |
