How much HP can a stock rear end and transmission handle
Old February 6th, 2010, 01:42 AM   #1
97greenstang's Avatar
1997 Mustang
N/a but prolly slow
97greenstang is on a distinguished road
Send a message via AIM to 97greenstang
Question
Well like it says How much HP can a stock rearend and stock 4 spd tranmission handle
I need to know so i know if i have to incorperate a new tranmission/rear end into my "build"
thanks
Old February 6th, 2010, 11:47 AM   #2
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
Well the stock 4spd, I am assuming must be the auto, and they are able to hold easily 350+rwhp. And if you have a cooler, and j mod, they can handle in the 400+rwhp range. The stock unit, well idk, because it is an open differential where only one wheel spins. If you run a tlok you are looking at the ability to hold 260rwhp about, and then the strongest option is getting an eaton or detroit style unit, and they can hold up to i 350-400 rwhp maybe more, depending on your tire and how hard you are launching.
Chris, was running 497ish rwhp on his detroit unit.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old February 6th, 2010, 03:20 PM   #3
stangcharger's Avatar
stangcharger is on a distinguished road
Send a message via AIM to stangcharger
The auto can handle near 400 rwhp and the t-5 can last awhile between the 330-350rwhp mark. Mine gave out at the 385rwhp mark. They like to give out in 3rd geAr.
The rear will be a bit of luck. Mine is still working at my levels. And some blow with almost stock hp. So it will vary person to person.
FYI on the auto do a j-mod and tranny cooler.
Did the 94-98 models use the same auto tranny? I'm mainly familiar with the manual trannys.
436rwhp/378rwtq tuned by HPP
www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com
Old February 6th, 2010, 07:09 PM   #4
02 Mustang V6
13.605 @ 101.60
Garman91 is on a distinguished road
iTrader: 6 reviews
What diff and gear are you running?
BBK Intake, BBK 70MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, Aluminum DS, 7.5 T-Lok w/ 3.73's, Centerforce Clutch, ZEX 75 Shot, Sniper Tuned
Old February 6th, 2010, 07:44 PM   #5
1996 Mustang Cobra
atlanticblue98 will become famous soon enough
94-95 use the AODE
96-04 use the 4R70W
1996 Cobra Coupe-#3779
Laser Red, Saddle Leather-1 of 994
1998 Atlantic Blue V6- R.I.P.
11/1997-3/3/2010
Old February 6th, 2010, 09:27 PM   #6
3.73's and my 7.5 rear. Guy from salvage yard said it was from like a ford explorer I think. Can't remember for sure though.
Originally Posted by atlanticblue98 View Post
94-95 use the AODE
96-04 use the 4R70W
Thank you. I appreciate the info.
Old February 8th, 2010, 02:32 PM   #7
1997 Mustang
N/a but prolly slow
Well im just wondering because I plan on throwing on preformance Cyl heads (fully ported upper and lower fro supersixmotorsports. basically the power package ive been asking so much about, imputting that on and they say on the dyno they got roughly 85-100HP out of it. Then also throing a dual exhuast W/ a 8-9psi vortech s/c. That why i wanted to know cuz i dont want to driving one day and all of a sudden my rear blows out clean from my car.
If i makes a difference my 4spd is infact the auto and i have 4.10 to the best of my knowledge
Threads Similar to: How much HP can a stock rear end and transmission handle
Transmission and rear end noises wtaylor V6 Mustangs 2 February 1st, 2010 02:26 PM
Strong vibration from transmission/rear end? acidtonic 4V / SVT 5 May 12th, 2009 11:53 AM
97 gt transmission and rear end questions 86ttops 96-98 11 October 4th, 2008 06:53 PM
just wondering whats good for building the rear end to handle about 550? lilmarc1988 99-04 5 March 11th, 2008 12:18 PM
Stock Rear End On 03 GT? Gtwrestler 99-04 2 October 26th, 2006 06:22 PM
