Dumb question on aftermarket Cai
Old February 6th, 2010, 07:53 PM   #1
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
So I went to replace my airfliter yesterday and I was unbolting the plate that is bolted into the side of the car between the airfilter and engine. The first top rubber one comes out easy as anything but I keep trying to undo the 2 at the bottom, I was going to take 1 off and loosen the other so I could turn it around and grab my airfilter. Is there a nut on the bottom of it? I would hate to have to go under my car and take off this nut n bolt to change my damn filter!
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old February 6th, 2010, 07:59 PM   #2
97fordsixer's Avatar
97 single port w/bolt ons
n/a
97fordsixer will become famous soon enough
if you can put pressure on the big backing plate like your gonna pull it towards the battery it might create pressure to unscrew those bolts. i had that same problem once and it worked for me
bolt ons for now..... split port swap very soon....
Old February 6th, 2010, 08:01 PM   #3
Matt.'s Avatar
12's?
ill try it, its been pissing me off so bad, did u do anything differnt when u put the bolts back in to save u the hell of the same thing happing twice
Project Red Magic
Old February 6th, 2010, 08:04 PM   #4
n/a
well the bolt sit in a rubber grommet and i found if it does it again you can sometimes pull the whole unit up and out of the grommets all together. it didn't hurt anything but i just installed the screws with anti seize and not to tight.
Old February 6th, 2010, 08:05 PM   #5
Matt.'s Avatar
12's?
im gonna try it in about 15 mins
Project Red Magic
Old February 6th, 2010, 08:13 PM   #6
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Easiest under the car for mine, one person holding the bottom piece with a pair of pliers and someone up top to unbolt it.
Old February 6th, 2010, 08:14 PM   #7
Matt.'s Avatar
12's?
but i mean I shouldnt have to get under the car to change the airfilter
Project Red Magic
Old February 6th, 2010, 08:18 PM   #8
goren813's Avatar
'00 3.8L & '05 4.6L
It's fender well... not really a way around having that heat shield.
Old February 6th, 2010, 08:22 PM   #9
Dancing Naked In The Rain
mcqueen's Avatar
Unless you're installing an air filter that's too big for the fender opening. If you can't get those screws undone simply remove the clamp on the MAF, remove the MAF and the connected part of the air inlet tube from the coupler, and just pull the filter out + the grommets out of their holes. There should be 2 metal pieces inserted into the grommets that the screws hold on to. Might be easier to get the screws out of those holders if you get the holders out of the grommets and get a good grip on them. The screws might not be stuck at all, the holders might just be spinning in the grommets.
Old February 6th, 2010, 08:32 PM   #10
Matt.'s Avatar
12's?
yeah im gonna go apeshit on it, i was thinking about rigging my own cai with something like this (not the left part cuase its a ram air) and put a drop in filter with a headsheild. I would keep 1/2 my old cai and this would force more air in as well as make it easy to clean my filter
dose that sound like a good idea or waste of money
Project Red Magic
Old February 6th, 2010, 11:03 PM   #11
n/a
i like it! ive always thought that to be a kool idea.
Old February 6th, 2010, 11:13 PM   #12
Matt.'s Avatar
12's?
well i took off my black filter( guess the jackass who owned it b4 never cleaned it)It turned out the nuts on the other side were weird ass circle things that I could not get a hold of with vise grips or anything . I replaced the airfliter with bigass spectre air filter from autozone. I had to move my hand around in the fender and get it all cut up but with the help of a second set of hands moving the cai tube i got it in.
Project Red Magic
Threads Similar to: Dumb question on aftermarket Cai
dumb question jasons_98gt 96-98 3 October 5th, 2009 08:00 PM
dumb question mlessor96GT 96-98 2 May 29th, 2009 07:35 PM
Maybe a dumb question 05gtdroptop 4V / SVT 2 October 28th, 2008 12:10 PM
Dumb Dumb Question on my part. mustangmanic The Clubhouse 53 July 3rd, 2008 12:57 AM
dumb question 4point6GT 96-98 4 June 26th, 2006 10:16 AM
