Half Shafting a tb
Ok, so i was reading an article on how to half shaft a throttle body. I was just a little confused. Ok, so are you just polishing the bore of the throttle body? or are you grinding away some of the metal on the shaft that holds the butterfly? I looked at the how to article on rpm-mustang or some site like that. Thanks I was jc. Also has anyone done this? and does it make any difference?
![]() UDP, CAI, True Duals, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, FRPP C Springs, and J&M Full Length Subframe Connectors Great Automotive How To's http://tooldesk.com/blog/ |
97 single port w/bolt ons
n/a
you are grinding the shaft only! i did this and cant tell much difference. Mabe a little on the high end but dont expect wheelies. Its cool telling people you did it then.
![]() bolt ons for now..... split port swap very soon.... |
Ok thanks. that is what i thought. Do you grind the glat part where the butterfly sits in? or the part where the bolt heads are, the article confused me. I was jc. I know it says that you can use a fine sandpaper wheel to polish just make sure not to get to close to the edge where the butterfly sits.
MM's Official Lucifer
No wheelies!?!?!? Why am I modding this thing at all!?!
"Fast she goes...in the city of Overdose" ![]() |
ha, that would be sweet to pull a wheelie off the line like the charger in the fast and the furious when he races the toyota supra.
n/a
i think you grind the head part and not!!! the threaded part or it wont hold itself on. j/k with the wheelies i pull them all the time. just like fast and furious
no its a cool mod though just take your time and itll go smooth.
Ok, that makes since, because then when the throttle plate is open there will be less restriction due to that huge ripple in the middle.
2003 mustang
7.48x1.56=11.67
A cheap trick is buy use a stock gt tb(Bolts right up). You must relocate the iac though. It can be punched to 70mm.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
n/a
very nice trick/tip. how about retuning for more air then? id assume you would have to or it will run funny.??
jt thanks. And that is no problem for doing the IAC because I am planning on running the windstar upper so i will be doing that anyways. So 99-04 gt throttle body is 70mm? and will bolt up, all is needed to change is the IAC? If so thanks so much
2003 mustang
7.48x1.56=11.67
It will bolt up but you may need to open the intake to the same size as the tb. It will bolt up. Can be ported to 70mm...stock is roughlly 68mm maybe
ok, sweet thanks so much. That will save me a ton of money buying a stock gt one that someone is selling because they upgraded. Thanks. reps.
Modded mustangs is amazing, i have saved now 400 bucks around on my summer build with some info on here and some little tricks. thanks.
2003 mustang
7.48x1.56=11.67
No prob man!! I'm all out about saving money on modding the stang. This shits addictive and can get expensive!! I've got a room full of parts waiting to go on it...should keep me busy this spring.
that is what i am doing right now. i am trying to slowly acquire some parts. i am looking to do about a week long upgrade on my stang this spring.
+infinity
2003 mustang
7.48x1.56=11.67
nah...shouldnt need retuned for bigger tb. Hell...I swap from a 4.0" on the street to a 3.6" pulley for the track which is about 6 more psi and I dont need to add any fuel on the handheld. The maf will compensate if tuned properlly.
n/a
sweet. Hey codeman i see you were in tha classifieds did you get that stock tb? i will be lookin for one in a while just dropped the cash for a tuner. Modding is like a drug. Once you pop you cant stop! or a pringle however you wanna look at it.
I still got to get the cash rounded up, but im 99 % sure.
just bought the throttle body. actually i asked for it for bday, but since i am ordering it from the guy on here i bought it lol.
n/a
nice. if you install soon post whatcha think.
Threads Similar to: Half Shafting a tb
| last play of the half | stangfreak | The Clubhouse | 4 | December 7th, 2008 05:15 PM |
| Half way done. | Dansby | The Clubhouse | 20 | September 10th, 2008 11:09 PM |
| half shafting throttle body | myPONYisHARD | V6 Mustangs | 35 | July 15th, 2007 07:00 PM |
| At Half Mast... | Gunny | 2005 - 2010 | 4 | May 25th, 2007 01:21 AM |
| Bout got the better half.... | auburntiger7231 | 99-04 | 2 | May 17th, 2007 05:07 AM |
