Shortys
Old February 8th, 2010, 09:06 PM   #1
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
Shortys
Ok, so I plan on getting some shorty headers this spring. I know I know, do not try to change my mind. They are going to work for what I need. My question is, which ones to get, I am looking at BBK, or MAC. The MAC are cheaper, am just curious if they are pretty mush the same. The tube diameters are exactly the same.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old February 8th, 2010, 09:35 PM   #2
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
get rims my friend.
Also i have heard good things about the MAC, BBK has been know to have problums with there products, idk about headers. But I would go with MAC being its the same product for a smaller price and BBK has a shady rep
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old February 8th, 2010, 09:50 PM   #3
Codeman's Avatar
alright thanks. I figured they should be pretty equal since they are both the same diameter. and as far as the rims go. im fine with my stock ones, our roads are rough and rocky so the nice rims would get all chipped up. i am prolly just going to buy some 15 inch lightweights for drag racing.
Old February 8th, 2010, 09:54 PM   #4
Matt.'s Avatar
12's?
aww =/, but goodluck with the headers man tell me how they turn out cuase I might get some too
Project Red Magic
Old February 9th, 2010, 10:24 AM   #5
Codeman's Avatar
alright i will. i know everyone says shortys are junk and not worth it, but in my case they are going to be. i will try to get a sound link up to compare the two. i have to wait until spring tho, too much snow and too cold now.
Old February 9th, 2010, 12:14 PM   #6
stangcharger's Avatar
stangcharger is on a distinguished road
Send a message via AIM to stangcharger
MAC all the way. My exhaust is full MAC from headers to catback.
How will the shorties work in your situation? just curious.
honestly just keep the stockers if you want shorties. They will both do sufficient for the same goal. Spend the money elsewhere.
436rwhp/378rwtq tuned by HPP
www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com
Old February 9th, 2010, 12:18 PM   #7
lcorriveau3's Avatar
1999
YAWN!!! what??
lcorriveau3 has a spectacular aura aboutlcorriveau3 has a spectacular aura aboutlcorriveau3 has a spectacular aura about
Correct me if I am wrong but, don't our stock (99-04) manifolds make within 1-2 hp of shorties??
Old February 9th, 2010, 12:37 PM   #8
somewhere around that number yes.
Old February 9th, 2010, 12:42 PM   #9
Codeman's Avatar
I want the shorties, because they have to flow better than our stock ones. If you look at the design they have to. Sure they may not flow as well as lts, but there are two reasons that i do not want LTs. The first being that i think that they make our cars way too loud. I really do. even with mufflers. I just do not want to attract more attention then needed. The other thing that I do not like about LTs is the fact that they move the powerband to higher rpms, sacraficing low end torque. I do a lot of light to light racing where I want the low end torque, i do not ever really get up to the high rpms. Next, i think that the shorties just add some more to the exhaust note. They do not make it so loud, but they just make it sound more crisp. These are my reasons.
Old February 11th, 2010, 05:16 PM   #10
Codeman's Avatar
the other reason that i am thinking shorties is because i plan on trying to piece together a custom turbo kit. after doing a lot of research i decided a turbo would work much better for me than a supercharger. and after doing a lot of research i found that with some time, i could make a decent kit myself. i am not planning it for this summer, but it is going to be an on going project. and i am going to be welding and fitting tubing and over time hopefully i will get it done.
Old February 11th, 2010, 07:15 PM   #11
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
You don't have enough mods for them to flow better, this has been dyno tested by somebody on 3.8 already and didn't gain anything. Infact I think he lost 1-2 hp. Lets see too loud is an option, you can do long tubes with stock gt / mach mufflers and it won't sound loud at all. The powerband gets moved up while you get added power down low your looking at this the wrong way. And shorties only "smooth" the exhaust tone a very small bit.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old February 11th, 2010, 08:13 PM   #12
Codeman's Avatar
Well how does that work? If the shorties will not gain anything because i do not have enough mods for them to flow better, how come lts would gain anything besides shifting the power band? I am really jc?
EDIT: I totally agree with you on them not really doing anything because i do not have mods. I understand it is pointless without ported heads or a cam, but if you look at it the other way then lts really are doing absolutely nothing except changing the power band to higher in the rpms, and also they are going to cause you to loose even more torque because you are deleting the cats in most cases. Look at monster trucks, i do not know if you watch monster jam, but i do and a lot of the trucks used to run just zoomy headers with no collector or anything, now the new thing is to run a collector and a muffler on the bottom, they do this to gain more torque. So this just shows that sure you may get may? get more hp higher up with lts because of the powerband change, but you are loosing a lot more down low due to a loss in backpressure.
Old February 11th, 2010, 09:21 PM   #13
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Your not going to lose anything down low because of the long tubes, its been proven over and over on the dyno on our cars on 3.8 and more importantly v6power.net - As far as the monster trucks they aren't running a muffler to gain torque they are doing this because the stadiums are requiring them to become quieter because they are so loud.
Old February 11th, 2010, 09:30 PM   #14
2000 Mustang v6
winnie51189 will become famous soon enoughwinnie51189 will become famous soon enough
Send a message via AIM to winnie51189
Really no point in arguing about headers when there are so many factors in what makes one header better than another. Honestly it all depends on the application. For when possible you want to pair the headers tubes with opposing exaust strokes, so they fire one after another, this causes the stroke of one tube to help scavenge the exhaust from the other tube. The better you scavenge the exhaust gasses from the heads the better gains. Tuned headers are always better than non tuned headers. Also try to think of the engine as a pump, the inlet and outlets must be balanced in order to prolong life and performance. If you increase the input you must increase the output so they compliment each other, otherwise you are harming your engine life and performance.
Old February 11th, 2010, 09:45 PM   #15
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
sounds like that was read right out of a beginners guide to performance
Old February 11th, 2010, 10:01 PM   #16
Codeman's Avatar
ok, you should send me a link to some of the dyno results. i believe you i just want to see what the power curve looks like. and i do agree that it has too many variables.
Old February 11th, 2010, 10:07 PM   #17
2000 Mustang v6
A quick google search should provide ample enough material. I for one don't bother trying mods which have minimal gains that were dyno proven by others. Especially the ones that have been done multiple times, but I will try new mods without hesitation.
Oh and Kyle, it sounds like I'm doing a good job of retaining information lol, especially all the crap they hammer into us mechanical engineering students.
Old February 11th, 2010, 10:28 PM   #18
Codeman's Avatar
i still do not understand how they are proven to do nothing. if so why do they run them on the super six mustang? Is it due to issues with fitment since they swapped the engine in? Im jc. because that is the part that is still making me a little hesitant.
Old February 11th, 2010, 11:06 PM   #19
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Haha Yep,
I'm sure you've learned by now what they hammer into you and what you know that works are sometimes two different things
Old February 11th, 2010, 11:07 PM   #20
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
He would have had to make a set of custom long tubes, nobody makes long tubes for a 3.8 swapped fox body. If you want to go search 3.8 for those threads go ahead they are like 2-3 year old threads. Its where most people base the "don't buy shorties" argument from.
Threads Similar to: Shortys
LT or SHORTYS???? Stang808 V6 Mustangs 22 February 16th, 2010 02:30 AM
Shortys M L Struck 96-98 4 March 27th, 2009 06:27 PM
Gone with Shortys andres0286 99-04 6 April 1st, 2008 09:36 PM
Shortys Worth It? MyGT 99-04 6 December 15th, 2007 08:48 PM
