4.2 Crank
Ok, so I have been looking at different cranks and it seems all of the 4.2 cranks are not forged? They say cast, not forged? Also I plan on building a car for nitrous. Would a crank from a 4.2 pickup work? I mean be tough enough to handle the instant torque?
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
1999 Mustang V6
![]() iTrader: 3 reviews
those are the ones we use for strokers. like ssms has prepped and balanced ones.
Regular 4.2L crank from F-150 is fine for anything. I think either J or Gary was running one at 660+rwhp without any issues. Eventually maybe crank walk, but that isn't the toughness of the crank.
Forged 4.2L crank isn't worth it IMO. No one has broken a cast 4.2L crank to date that I know of.
436rwhp/378rwtq tuned by HPP www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com |
ok, thanks. i was curious. because i would think it would be easier to find a cheap 4.2 pickup crank then buying one from ssms. i know i will have to go there for the rods and pistons but still every little penny saved adds up.
completely agree.
2k 3.8 5spd
Not yet..
I am new to modifying..Can I grab a crank from a junk yard?
#7 | |
[8MINUS2]
If you want something 100% reliable then I don't advise grabbing a crank out of a junk yard vehicle unless you plan on having it prep'd afterward. fast/cheap/reliable You sound like your on the fast/cheap route, thats the one that leaves you calling triple A.
not really, but if you know people at machine shops and engine building shops so you can get good deals on if it needs to be undersized and balanced it pays to buy a used crank.
#9 | |
1994 V6
No you don't. David Dalke sells Wiseco pistons for half of what SSM charges. There are other's out there cheaper as well. He also sells h-beam rods for less. Don't just assume that the only place to get parts from is Super(high priced) Six Motorsports. Wiseco OE replacement FORGED pistons...*UPDATED 2/20/09* - Super Coupe Club of America Forums |
2003 mustang
7.48x1.56=11.67
You have to use the sc crank and bearings to use that setup.
I've spoke with dave and he quoted me a price around 1000 less than ssm quoted me for the price of a built short block. It included cam of my choice along with degreeing it. Really good deal. I may do this when the time is comes.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
hey thanks!!!! a ton!!!!!!!!!!!!!!!! that is awesome, wow the money saved from modded mustangs is going up!!! yes.
the sc crank, is that the supercoupe crank? if so dang!
2003 mustang
7.48x1.56=11.67
yep...and bearings
[8MINUS2]
So wait, what rods do you get with the O.E. wiesco replacements?
1994 V6
You can use either the stock replacement C.A.T. Power rod 5.915 or what was previously used, which was a 351 Windsor rod 5.955. Either way, the pistons are made for the rod being used.
The C.A.T. rods are about $360 while other manufactureres Winsor rods (S.C.A.T. or Eagle) are about $460. |
1994 V6
If you retain the 3.8 crank from an SC, it is also forged.
1999 Mustang V6
What years SC can I get it from? I saw a 94 on clragslist for $300.
1994 V6
A crank for $300 or the whole motor. All the cranks are the same.
[8MINUS2]
Interesting, so what does the total price come out for a build short block using the o.e. wiesco's and scat rods?
1994 V6
That depends. Are you studding the mains, using mls gaskets, new timing chain etc.? So basically, it depends on the parts.
The pistons through SCU are $75 for an SC piston and I can't see it being more for an N/A. C.A.T. b beam rods are $360. SCAT rods are $466 with 8740 bolts. David used to sell them for $300 a set. Not sure how much now. MLS gaskets are about $80 a pop. Timing chain is about $40. The machine work depends on your shop. |
Threads Similar to: 4.2 Crank
| crank | 2000GTCONVERT | 99-04 | 17 | August 5th, 2009 10:35 PM |
| HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability? | the1968jeepthing | 99-04 | 2 | September 29th, 2008 11:39 PM |
| Crank ??? | 01gtMustang132 | 99-04 | 14 | September 20th, 2008 03:08 PM |
| crank | mpboy | 99-04 | 1 | February 20th, 2008 04:24 AM |
| Crank | Fast98stang | 96-98 | 7 | January 7th, 2008 05:17 PM |
