Engine swap question
hey guys, I got a friend with a 95 3.8 auto mustang with a blown bottom end. He recently purchased a 99 complete engine package from a guy that swapped to a v8. Comes with everything including, pedal assem. T5 trans, wiring, pcm, motor, ect ect....What will this take to swap into the 95 body? And what driveshaft will work since thats the only piece that wasnt included...i dont think the auto 95 drive shaft will work on the 99 t5 swap. Thanks!
2002 Nitrous Injected V6
12's?
Yeah you might have a few issues getting things to fit being they are from 2 generations of cars, I think you will need to upgrade the driveshaft. But i hope it goes smooth with not so many issues.
![]() Project Red Magic -Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped- -18 Inch Hypercoated Saleens wrapped in Nittos- |
48.47@ 12.58
a 99 mustang doesn't have a T-5.
Uh yea 99 mustangs have T5's my 2000 does.....???
48.47@ 12.58
your 00 has a T-45
48.47@ 12.58
Anyway, you will need transmission mounts, motor mounts, the drive shaft, and an 8.8 rear end.
It says TR5 which would be t5 correct? I thought late 2000, early 2001 they swapped to T45
an 8.8 rear is definetly not necessary.....why an 8.8?
48.47@ 12.58
It was in early to mid 01 they swapped. My bad. You are correct. I was thinking that you had a GT.. force of habit. They swapped the GT T-45 in mid 01 to the T-3650 from the T-45.
I guess they gave you the T-45 when the GT's upgraded. Not saying anything bad about the 6'er though. I owned 2 of them in mustang form.
48.47@ 12.58
Well frankly, you are going to be adding 130 or so HP. Odds are that you will break a 7.5 if you beat on it even just a little.
no problem no both the 95 with the blown motor and the new 99 motor are both v6 just difference of single port and split port, and auto to manual. The auto to manual swap I have done personally before so thats not going to be an issue for me. The question is what all will need to be done to put a 99 v6 into pre 99 bodies
48.47@ 12.58
OH.. ( still thinking v8.. lol)
the 7.5 would be fine then.
Threads Similar to: Engine swap question
| 96 engine pi swap question | jg42122 | Modular Mustangs | 1 | January 18th, 2010 09:16 AM |
| Engine Swap Question | Ticket-Me-Yellow | V6 Mustangs | 11 | December 7th, 2009 02:22 AM |
| Engine swap question | hopper | 5.0 Mustangs | 9 | November 7th, 2008 04:23 PM |
| Engine Swap Question! | 02MustangV6e9 | 5.0 Mustangs | 3 | September 24th, 2008 02:16 AM |
| Engine swap question | energiesource | 99-04 | 11 | September 19th, 2008 06:54 PM |
