02 Mustang V6
13.605 @ 101.60
![]() iTrader: 6 reviews
Suspension Noise
I have a clunking sound thats getting more pronounced as time goes on. I hear it mainly when I go over a speed bump or pull into the driveway. I also hear it when I pull away from a dead stop (not hard just casually). Sounds like left side when in the car... any ideas?? Kinda hard to describe
Thanks in advance!
BBK Intake, BBK 70MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, Aluminum DS, 7.5 T-Lok w/ 3.73's, Centerforce Clutch, ZEX 75 Shot, Sniper Tuned
did you take your isos out?
White 2000 V6 Mustang|Black Saleens 18x9|Flowmaster 40s|AM CAI|8000K HIDs|SCT XCAL III/H&R SS
02 Mustang V6
13.605 @ 101.60
Good thought. I only dropped the front end, stock springs still in the rear. All isolators are still installed. The sound seems to be left rear suspension but any ideas would be great. I'm lost... worn bushing? worn wheel bearing possibly? would any of those make sense and if so, what else would be a symptom? I have a wicked vibration at about 110 MPH
1999 35th Road Race Pkg
Ford has a service bulletin regarding a noise like this. It has to do with the rear sway bar but is suppose to be only on Cobras. Might take a look at the sway bar though. Maybe a worn bushing.
![]() Success is not how far you get, but the distance you traveled from where you started. OK, and how FAST you got there!
v6s do not have rear sway bars. at least not to my knowledge. i would try looking at bushings and see how they are. you could always add some lube to them and see if it goes away, then maybe they were just dry.
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
Threads Similar to: Suspension Noise
| Suspension noise | stangnewb | 2005 - 2010 | 46 | January 27th, 2009 05:36 PM |
| front suspension noise | texas_mustang | 2005 - 2010 | 16 | October 29th, 2008 10:37 PM |
| suspension noise | dhsrcjh | 96-98 | 25 | September 21st, 2007 04:17 PM |
| Rear suspension noise | Veeder | 99-04 | 1 | July 23rd, 2007 01:18 PM |
| weriod noise in suspension | barksdaleammo | 99-04 | 10 | April 3rd, 2007 04:54 PM |
