OD Button Does Not Function
Old February 20th, 2010, 11:47 PM   #1
unclejim's Avatar
unclejim is on a distinguished road
I installed a UPR AOD Shift Lever [Ball style] with the OD button assembled directly below it. It actually works great as a custom shifter, but the OD button has me stymied. Now my OD function does not work when I press the button both in drive or on the road traveling at any speed. I do not think it is shorted out or it would come on since it would complete the circuit when I start the Mustang. I did not get an owners manual so I do not know what fuse to look at to see if I accidentally shorted it out. Any help fixing it would be appreciated. I even replaced the short OD wiring harness since I inadvertently broke the original.
Also, the seat belt light on the instrument cluster does not work nor does the warning buzzer. I checked the bulbs for both and the instrument cluster seems ok, both lights are not burned out.
Thanks for any help.
Uncle Jim
Scottsdale, Arizona USA
Old February 21st, 2010, 02:31 AM   #2
plak424's Avatar
2000 Mustang v6
16.683@83.86
plak424 is on a distinguished road
2000 Mustang Workshop Reference
Check that out its the workshop data in the tech thread. It shows a diagram of all the fuses and shows what they're for. Might be a simple fix if it is a fuse.
Old February 21st, 2010, 06:34 AM   #3
99 BLUE V6's Avatar
99 V6 BASE
NEVER RACED THIS ONE
99 BLUE V6 has a spectacular aura about99 BLUE V6 has a spectacular aura about
i had to replace my O/D button wire came apart. new one didnt work at first. it was the fuse.
Old February 24th, 2010, 06:02 PM   #4
unclejim's Avatar
Please... which fuse is it, I do not have an owner's manual, the previouse two owners, a Stewardess, and then a Nurse lost it. Your help would quicken my fix... Thanks .
Uncle Jim Petersen, Director
Arizona Mustang Car Club [AZMCC]
Old February 24th, 2010, 06:05 PM   #5
unclejim's Avatar
Thanks for the thread, however, there is no reference to the OD Button. What's next?
Old February 24th, 2010, 07:25 PM   #6
99 BLUE V6's Avatar
99 V6 BASE
# 28 two over from door and two down
Old February 27th, 2010, 02:01 AM   #7
unclejim's Avatar
#28 was the problem! I replaced fuse and it works great now. Thanks for the tip. I had gone thru the fuse diagram and there were eight or nine fuses to check including #28. You saved me a lot of time, thanks again.
I also fixed the seatbelt problem. Seems there is a process to go thru to turn it off and I probably did that during my removal of everything from the guage cluster and the AOD shifter and OD button assemblies.
Now on to exhausts...
Threads Similar to: OD Button Does Not Function
Search function failed me... poindexter18 V6 Mustangs 13 February 6th, 2009 08:55 AM
Does Anyone Use The Rep Function? AggieStang The Clubhouse 52 October 28th, 2008 12:51 AM
is this a function? nba1341 The Clubhouse 13 March 25th, 2008 10:11 AM
