The New Girl on the Block
Old February 21st, 2010, 05:18 PM   #1
heretic81's Avatar
35th Anniv Edition V6 Cpe
heretic81 is on a distinguished road
Okay, so here's what I have for pics so far:
Here are the struts, driver's side first:
They don't look too good to me!
Here's a few shots of the muffler:
And the body damage:
Here's the best shot of the engine:
Here's a shot of the audio wiring (it's set up for an amp/sub in the trunk):
And here's a close-up of the crazy tube that the audio wiring goes through:
And finally, some videos for you. The first one is me sitting in the driver's seat, turn the car on. I can't hear the noise in the video, but this car revs up pretty crazy when you first start her up. If you can see the tachometer jump, maybe you can diagnose without hearing it, but it just sounds like a serious rev. The second video is basically from my camera phone sitting propped up in between my wallet and the bar where the hood clamps in the middle, looking at the engine while I run and rev it up for you. You can't really see much, but maybe it's all you need(?)! Hopefully my wife or someone else can hold the phone while I take the next vid. Here ya go:
Hope this is enough for you guys for now. I have more/can take more. I'd really like your input. Apparently, the heater core is busted, as the front passenger side floor is a little damp, and the floor underneath and behind the front passenger seat is completely soaked. The guy at Valvoline told me that's what that was most likely from, and said to just get some connector valve to by-pass the heater core until I have the $$$ to fix the heater core. Beyond that, they said I should just get the rear differential done, a flush the coolant system or whatever, and do something with the transmission fluid that costs around $70. Oh yeah, the guy told me the power steering sounds bad (it whines), too.
Thanks for any help. Can't wait to see what you have to say!
Old February 21st, 2010, 05:26 PM   #2
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
My car does the exact same thing when I first start it. The tach jumps up. I do not think it is anything to worry about. As far as the struts, mine look exactly like that. One way to test to see if they are bad is to jounce your car which means push down hard on the front and rear bumper hard a couple times then watch and see how many times it takes for the car to stop going up and down. It should only take 1-2 times. Or another way is to drive on the interstate and if it feels like you are driving a boat then it is time to replace the shocks and struts.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old February 21st, 2010, 05:31 PM   #3
heretic81's Avatar
Well, that's a relief! This is my first Mustang w/a manual transmission, and the only other car I had that was a stick was a Mazda Protege (same year), and it never did that. I was a little worried!
Old February 21st, 2010, 05:33 PM   #4
Codeman's Avatar
Ya mine worried me also. It gets a little annoying. You can try cleaning the IAC and Mass Air sensor. It might help. I am going to try cleaning both this spring.
Old February 21st, 2010, 05:40 PM   #5
b1gdaddy98's Avatar
1998 Mustang V6 Vert
b1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of light
Send a message via AIM to b1gdaddy98 Send a message via Yahoo to b1gdaddy98 Send a message via Skype™ to b1gdaddy98
the weird tube thing you're talking bout for the stereo is your fuse case, that way if your stereo blows it doesn't hurt your care it just blows a little fuse!
NCMM ORIGINAL
Vert Crew #03
Old February 21st, 2010, 05:42 PM   #6
heretic81's Avatar
Sweet bippy! I was wondering what that was for, but I figured it was good! Thanks for clearing that up!
Old February 21st, 2010, 05:45 PM   #7
heretic81's Avatar
Yeah, the stereo's crazy, BTW. I hooked up my portable cd player through the tape deck because that works, but it sometimes swaps to the cd player for no apparent reason, which is broken. Then it starts making all kinds if crazy, angry noises (probably the cd that's stuck in there spinning out of control). I'm gonna take it to an audio shop and have them install my deck soon, but just thought you should know. I think it might be indicative of an over-all electrical problem with the car, but I'm probably just being a worry-wort.
Old February 21st, 2010, 06:30 PM   #8
b1gdaddy98's Avatar
you should install it yourself...a cd player is like the easiest thing to install just snap and plug basically. Good looking car though especially for the deal u got it at, good luck wit it all! you got any plans for it soon?
NCMM ORIGINAL
Vert Crew #03
Old February 21st, 2010, 06:43 PM   #9
Codeman's Avatar
U could try installing it yourself like above said it is not too bad. But if you are more comfortable taking it somewhere do that. It is best to pay a little more than mess something up.
Old February 21st, 2010, 06:54 PM   #10
heretic81's Avatar
Yeah, the last time I tried to do it myself, I screwed it all up. It was not easy, as I had to cut the wires from the stock system and re-attach them all individually to the plug I bought. I ended up just taking it to Best Buy, where they fixed it all for me. I think I'll either take it to a shop or pay a buddy to do it this time, save myself a headache.
Old February 21st, 2010, 07:00 PM   #11
b1gdaddy98's Avatar
yeah if you're not comfortable with it then it's def worth payin someone to do! What kinda cd player you putting in there?
NCMM ORIGINAL
Vert Crew #03
Old February 21st, 2010, 07:04 PM   #12
heretic81's Avatar
Thanks!
And yeah, my immediate plans are to purchase a set of new tires, fix the heater core, and find OEM front seats that have the pony inlay somewhere.
Then, when my wife gets her full-time gig at the Post Office, install a twin turbo kit! I'm sure I'll need a tuner once I do that, and I'm not sure if it's possible to have a CAI with a twin turbo set, or even necessary, but I'll do it if it makes sense. Then I want some long tube headers and a flowmaster dual exhaust system. Then maybe I'll get a racing clutch with a short-shifter, upgrade the brakes, upgrade the struts, then bring her to the dealer for a full body restoration, a paint job (black, of course), and some tinting on the windows. Then I'll find some nice, black rims, and convert the interior to all black (maybe delete the rear seats).
Yeah, I want to murder her! Muahahahahahaaaaaaaaa!
Last but not least, I will install a custom system in the trunk, preferrably with one 15" sub with a dedicated amp, and two 10's powered by another amp..
Old February 21st, 2010, 07:06 PM   #13
heretic81's Avatar
I said in a previous post that it was a Pioneer, but I was wrong! It's a Panasonic, from 2007. Just a basic deck for now. Once I get some cash flow, I'll upgrade it again.
Old February 21st, 2010, 08:40 PM   #14
heretic81's Avatar
So, one thing I forgot to mention was the door... I included a pic, but that might just be the plastic molding that's off, which bugs me anyway. The real problem is that the door won't close properly unless you slam it. It seems to get caught underneath. There's a fair amount of play if you try to lift it up when it's open. Is that just a hinge problem that's easily fixed, or am I going to need a new door somewhere down the line?
Also, about that noise when it starts. It's really "scratchy" sounding. Doesn't just sound like a normal rev. I wish I could get better audio quality outta my phone so I could show you exactly what I mean, but it sounds bad. It's probably not supposed to sound "scratchy," is it??!!
Old February 21st, 2010, 08:42 PM   #15
Admanistrator
v606er's Avatar
v606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud of
I foresee this thread having 11 pages. 15 or more if she posts pics of herself.
MAD Stangs #8
Old February 21st, 2010, 08:45 PM   #16
heretic81's Avatar
If who posts pics of herself??? I'm a guy...
Old February 21st, 2010, 08:47 PM   #17
b1gdaddy98's Avatar
lmao I was thinkin you were and I had no idea wut the v60 person was talkin bout
NCMM ORIGINAL
Vert Crew #03
Old February 21st, 2010, 08:47 PM   #18
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Then why on earth are you driving a v6?
Sorry dude.. I had to take that one.
Old February 21st, 2010, 08:50 PM   #19
b1gdaddy98's Avatar
^^^^ OUCH that hurt...
NCMM ORIGINAL
Vert Crew #03
Old February 21st, 2010, 08:54 PM   #20
heretic81's Avatar
Very funny! I read that the base hp for a 99 V6 is 190, and the base hp for a 99 GT is 260. That's only a 70 hp difference. I'm sure a V6 can be modded to have 260 or more hp. And I test-drove a 98 GT automatic that didn't impress me at all. I like my V6 manual! It sounds great, has good pick-up, and almost won a race last night on I-95 against what I think was a 99-04 GT!
Threads Similar to: The New Girl on the Block
cute girl/pulled over/sexy girl silvergtstang99 The Clubhouse 59 July 18th, 2010 01:19 AM
short block's block vrs block in car stock? adrenaline=lifeline 99-04 7 August 19th, 2008 08:22 AM
short block differs from a long block how? mustangfox9091 5.0 Mustangs 35 September 26th, 2007 10:57 PM
