Opinions on this Combination - Page 2
Old February 22nd, 2010, 12:23 AM   #21
b1gdaddy98's Avatar
1998 Mustang V6 Vert
b1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of light
Send a message via AIM to b1gdaddy98 Send a message via Yahoo to b1gdaddy98 Send a message via Skype™ to b1gdaddy98
also don't forget to tell them that if they plan on upgrading gears you needa get a tlok and tuner....i've heard that NUMEROUS times
NCMM ORIGINAL
Vert Crew #03
Old February 22nd, 2010, 12:31 AM   #22
heretic81's Avatar
35th Anniv Edition V6 Cpe
heretic81 is on a distinguished road
Thanks, mcqueen! Rep added! Just one more quick question... The limited-slip: does that help with low-end power, or is it strictly for burn-outs (which I won't be doing)? In other words, is it worth the extra $400 or so to buy/install it if I'm not going to be using it for burn-outs?
Old February 22nd, 2010, 12:35 AM   #23
b1gdaddy98's Avatar
yeah, def according to everybody it gives a huge burst of speed in the beginning. i'm pretty sure it'd be pointless to upgrade gears without a tlok
NCMM ORIGINAL
Vert Crew #03
Old February 22nd, 2010, 12:37 AM   #24
Dancing Naked In The Rain
mcqueen's Avatar
The tlok isn't required, but since the differential has to come out for the gear install, you might as well put the tlok in. And good catch on the tuner. That's required to recalibrate the speedo for the new gears. You could always get a speedo recalibrator, but for $170 more you'll get a lot more use out of the tuner.
The limited slip will be great for burnouts but if you're not stomping on the gas you'll find you have much more traction than with the open differential. I can't say for sure, but I'd put my money on it helping with low end power. Especially combined with steeper gears. Also, you can usually get a decent deal if you get your gears and differential installed at the same time seeing as how the differential has to come out to put the near gears in. And if your car has more than 60,000 miles you should seriously consider a bearing kit from AmericanMuscle. It's around $70 and it's not required but, in my mind, I'd rather have things new and working nicely than to let them wear out and push them too hard one too many times.
Old February 22nd, 2010, 12:40 AM   #25
b1gdaddy98's Avatar
yeah, i'd rather pay 300$ for labor or whatever then the shop having to take it apart twice!
NCMM ORIGINAL
Vert Crew #03
Old February 22nd, 2010, 12:44 AM   #26
heretic81's Avatar
My car has 154,500 miles on it! So, at the risk of sounding completely retarded, isn't all that stuff housed in the driveshaft? And if it is, wouldn't it also be a good idea to upgrade to an aluminum driveshaft at the same time, for all the same reasons (i.e., they're already down there)???
Old February 22nd, 2010, 12:51 AM   #27
mcqueen's Avatar
The differential is actually in the differential housing. When we talk about that we generally just call it the rear end which generally refers to this piece:
If you look under the rear of your car it's incredibly easy to spot and if you do any work on the back of your car, this is a good jack point (although I think Ford recommends we don't use it as such, but oh well ). You could upgrade to an aluminum driveshaft if you want, but it's not really required. Basically you lose some power through your drive train and an aluminum driveshaft just helps retain a larger amount of power than stock, although it's not a much larger number. I'm not sure what the stock driveshaft is made out of, but aluminum will be light and spin with more ease.
Old February 22nd, 2010, 12:55 AM   #28
b1gdaddy98's Avatar
yeah my 98 has 87,000 miles on it. I plan on getting the gears, tlok and the bearing kit all at once!
NCMM ORIGINAL
Vert Crew #03
Old February 22nd, 2010, 12:58 AM   #29
heretic81's Avatar
Yeah, I guess I'll probably do the same (as long as the wife okays it!)
Old February 22nd, 2010, 01:01 AM   #30
mcqueen's Avatar
Buy her some roses, a nice dinner, and maybe even a little jewelry. Problem solved, no more okay needed from the wife
Old February 22nd, 2010, 01:09 AM   #31
b1gdaddy98's Avatar
oh lord...tell her it's prolonging the life of your car so you can get her a new one in the near future lol that'll win her over
NCMM ORIGINAL
Vert Crew #03
Old February 22nd, 2010, 01:12 AM   #32
heretic81's Avatar
lol! Yeah, that might work! She doesn't even want to pay for 4 new tires (that I need to pass inspection)!
Old February 22nd, 2010, 01:13 AM   #33
mcqueen's Avatar
Your wife wouldn't like me then. I just bought 4 new tires because I wanted bigger wheels (bought new wheels too ). The tires on my current wheels are only a few months old (they're becoming the winter wheels/tires unless I end up buying a beater for the winter).
Threads Similar to: Opinions on this Combination
Muffler combination Red98V61992 V6 Mustangs 5 February 7th, 2010 09:45 PM
Looking for cam combination with supercharger! WhippledRoush42 2005 - 2010 29 September 13th, 2009 06:31 PM
Coupon Code Combination RJVetter831 American Muscle 2 July 30th, 2009 12:12 PM
Tire and rim combination smokeshow 99-04 6 April 18th, 2009 07:57 PM
Combination of... 5.0cent 5.0 Mustangs 32 October 29th, 2007 04:26 PM
