door speakers
Old February 26th, 2010, 06:52 PM   #1
96 V6~97 GT
Stang6er is on a distinguished road
door speakers
im sure its posted somewhere but im kinda in a hurry.. anyone know wat size they are?? thanks...
-ON-
CAI
-Comin Soon-
UDP
Upper Intake Spacer
O/R H-Pipe
Flow40s
Old February 26th, 2010, 06:55 PM   #2
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
small like 1.5"x 1.5". I might not be 100% but they are nowhere as big as the frame leads them to look.
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old February 26th, 2010, 06:57 PM   #3
davisac's Avatar
2001 Mustang
Slower than a Honda Odyssey
davisac is on a distinguished road
5x7/6x8
Let the music be your master. Will you heed the master's call....
Old February 26th, 2010, 06:58 PM   #4
96 V6~97 GT
it would maybe help if i put the year.. its a 96 v6. not the tweeters matt.. the ones at the bottom of the door
-ON-
CAI
-Comin Soon-
UDP
Upper Intake Spacer
O/R H-Pipe
Flow40s
Old February 26th, 2010, 06:59 PM   #5
davisac's Avatar
2001 Mustang
checked crutchfield 5x7/6x8
Old February 26th, 2010, 07:02 PM   #6
96 V6~97 GT
long shot question..
u happen to know wat aftermarket speakers will fit??
-ON-
CAI
-Comin Soon-
UDP
Upper Intake Spacer
O/R H-Pipe
Flow40s
Old February 26th, 2010, 07:06 PM   #7
davisac's Avatar
2001 Mustang
5.25 without modifications and 6.75 if you cut the door a little
Old February 26th, 2010, 07:14 PM   #8
Matt.'s Avatar
12's?
O sorry I was assuming tweeters. I have no idea about the 96's. Goodluck man
Project Red Magic
Old February 26th, 2010, 08:31 PM   #9
2000 Mustang v6
winnie51189 will become famous soon enoughwinnie51189 will become famous soon enough
Send a message via AIM to winnie51189
anything above 5.25" will require a mounting plate but most components come with the plate you would need. I put my 6.5" Alpine type-x components in the doors with the adapter plate they came with and they fit perfect.
Old February 26th, 2010, 09:22 PM   #10
Ponygirl95's Avatar
1995 Mustang V6
Ponygirl95 is on a distinguished road
I've had good luck with crutchfield. You can enter the specifics for your car and they will give you a list of what will fit. They even supply mounting brackets if needed and wiring harnesses which are REALLY helpful (very little if any splicing).
Old February 28th, 2010, 05:16 PM   #11
96 V6~97 GT
ok i got them in.. thing is they dont have any audio.. jus bass.. any ideas how i get the audio to play??
-ON-
CAI
-Comin Soon-
UDP
Upper Intake Spacer
O/R H-Pipe
Flow40s
Old February 28th, 2010, 05:37 PM   #12
davisac's Avatar
2001 Mustang
whats your setup? check connections first obviously
Old February 28th, 2010, 05:39 PM   #13
b1gdaddy98's Avatar
1998 Mustang V6 Vert
b1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of lightb1gdaddy98 is a glorious beacon of light
Send a message via AIM to b1gdaddy98 Send a message via Yahoo to b1gdaddy98 Send a message via Skype™ to b1gdaddy98
which ones did you order and from where? I always thought Crutchfield overpriced their stuff...but that's just me
NCMM ORIGINAL
Vert Crew #03
Old February 28th, 2010, 05:46 PM   #14
WhtStang00's Avatar
2000 Mustang V6
WhtStang00 will become famous soon enoughWhtStang00 will become famous soon enough
Send a message via AIM to WhtStang00 Send a message via MSN to WhtStang00
check out
Onlinecarstereo.Com - Wholesale Car Audio/Stereo Deals At Bargain Prices
they have good prices
White 2000 V6 Mustang|Black Saleens 18x9|Flowmaster 40s|AM CAI|8000K HIDs|SCT XCAL III/H&R SS
Old February 28th, 2010, 05:52 PM   #15
davisac's Avatar
2001 Mustang
yeah they do you have to look around for sales or open box. then you cant beat them
Old February 28th, 2010, 06:53 PM   #16
96 V6~97 GT
jus picked them up from wally world.. there pioneer ts-a6872r 6x8.
connections are good. striped and twisted together then used electrical tape.. there rated for 240 watts apiece and im thinkin that the stereo i got jus cant push them..
Setup is stock rear and tweets. kenwood cd player. pioneer doors. 2 10" pioneers runnin off 2ch 1000w amp.
-ON-
CAI
-Comin Soon-
UDP
Upper Intake Spacer
O/R H-Pipe
Flow40s
Old February 28th, 2010, 07:01 PM   #17
Dancing Naked In The Rain
mcqueen's Avatar
When you get some time, you may want to pick up a soldering iron and some solder (Wal-Mart has a cheap soldering iron that should do the trick) and put some solder on the areas that you twisted the wiring together. I wired my footwell LEDs the same way and I've got one coming loose already. Not to mention your speakers vibrate more than my lights so there will be more stress on the joints.
Old February 28th, 2010, 07:18 PM   #18
davisac's Avatar
2001 Mustang
crutchfield says 2-40 watts RMS recommended so i dont think that its the power. mine are 100 watts RMS till i get money for an amp and their doing "ok".
what about the polarity of the wires sure thats ok? i assume the speakers before were working fine?
Old February 28th, 2010, 07:21 PM   #19
96 V6~97 GT
the speakers were totally blown..
another thing i cant figure out is wen i start driving they cut out at a certain volume.. but wen im sittin still they play as load as i want
-ON-
CAI
-Comin Soon-
UDP
Upper Intake Spacer
O/R H-Pipe
Flow40s
Old February 28th, 2010, 07:28 PM   #20
davisac's Avatar
2001 Mustang
you dont have a volt meter thing do you? it sounds like your head unit is powering too much and getting to its limits causing distortion or loss of power. how loud are you playing?
Threads Similar to: door speakers
Mach 460 Door Speakers NYMustang21 99-04 2 April 7th, 2008 09:23 AM
rattle from door speakers new2mustangs 99-04 2 January 17th, 2008 11:02 AM
Need Help Installing Door Speakers Fox2102 V6 Mustangs 10 December 2nd, 2007 01:42 PM
door speakers EasyE64 Audio/Video 11 October 20th, 2007 06:28 PM
installing door speakers ayyubam2002 Audio/Video 2 August 2nd, 2006 10:00 PM
