pinging? or ticking? - Page 2
Old February 28th, 2010, 11:33 AM   #21
stephen has a spectacular aura aboutstephen has a spectacular aura about
In 2 loader was supposed to be louder.
Old February 28th, 2010, 04:20 PM   #22
vsix is on a distinguished road
Originally Posted by stephen View Post
There are three likely possibilities.
1. These cars tend to build up carbon deposits in the rear cylinders which can cause preignition.
2. Exhaust leaks are common which can sound like a ticking sound. This usually will be loader when the manifolds are cold and is loader when the throttle is depressed.
3. Valve train wear can lead to valve noises if the wear is severe enough that the lifters can't compensate. This also tends to be loudest when the engine is cold but shouldn't depend on throttle opening.
1. and 2. sounds very, very interesting and I will go after that! WOW that helped me alot. Yesterday I red something with carbon building up and old fuelrails.
Point 3. isnt the issue I heard valve ticking and can say its not valve ticking.
As for doing a vid while driving: I will try but cant promise.
I think steven hit in the right direction ..these are my trouble makers. As soon as I get the manifolds with headers replaced. Ill let you know.
I will anyway port and polish my intakes and heads then Im gonna see if there is to much carbon built up that causes A. lean running B. poor power output.
Thank you people!
stock....
Old March 1st, 2010, 09:03 AM   #23
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
I'm going for exhaust leak. You hear it under load because you're pushing more exhaust gases out. Your flange is discolored because exhaust is escaping there. Remove the midpipe and check it for cracks. Remove the header and inspect it. I just had to replace my pass. side header. For months there was a small "tick" or "ping" it was irritating. I had written it off as a sticking valve lifter and was waiting to tear into it. Finally the header just separated completely and there was no longer any question. Stock replacement and she runs like new. I would check that before anything internal motor wise.
Old March 1st, 2010, 10:01 AM   #24
speed4goal is on a distinguished road
Send a message via AIM to speed4goal
I use to have a chevy corsica before I bought my stang and its valves would ping while I was driving if I didnt use premium gas, You could give it a try. And ever since I've had my stang its always had this tick in the engine, but since I've switched from royal purple to castrol edge this tick has gone away. I've had this tick for about 80,000 miles. I could only hear the tick at idle...
(2000 v6)bbk cai,motoblue udp,65mm throttlebody+spacer,diablo tuner, 4.10 gear,t-lok,160 thermostat, screamin demon, msd wires. bbk shorty headers, off road x,streetpro mufflers, Royal purple fluids, K&n oil filter.
(89 5.0) msd dist,wires
Old March 1st, 2010, 10:07 AM   #25
goren813's Avatar
'00 3.8L & '05 4.6L
This issue is occurring under load, not at idle. These cars do not need premium gas. Ensuring proper oil levels and changing it as should is a must, low or old oil can cause pinging. I'm still for exhaust leak.
Old March 1st, 2010, 11:38 AM   #26
I had about enough of searching an trying to fugure out where the leak could be and bought those headman headers, a catted x pipe, and magnaflow V8 catback just to make sure that my frankensten exhaust setup that I will replace wouldnt cause anymore of a problem!
As for the oil...if you really start to dig deeper into the materia...then you almost start to feel when your baby needs oil...no I would never forget to change oil nor run thr wrong one.
My car was cold today just a short trip to the bakery and maybe 15 mins drive...no pinging...but for my oppinion still bad acceleration...well need to wait till my exhaust setup arrives and will keep you updated. I will for sure tear the engine apart for porting and polishing ( have a bigger TB and like to benefit more of it) so I can check for carb build up...you know maybe I got two troublemakers carb and manifold leak! Well see!
stock....
Old March 1st, 2010, 11:43 AM   #27
Trick Tuners's Avatar
KB'd GT
If you flash back to stock and the problem is gone then i would suspect detonation.
Detonation Explained
If you ran a higher octane tune, than the gas in your tank it could cause this. If you had the right octane in the tank, then contact your tuner.
Old March 1st, 2010, 11:49 AM   #28
Yea I contacted my tuner and we both did figured it out that it has nothing to do with his tunes. Its a mechanical problem. Thanx for the help though!
stock....
Old March 1st, 2010, 02:09 PM   #29
Admanistrator
v606er's Avatar
v606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud of
My brother had the same thing on his 2000 V6. It is a fairly common problem with these cars. It was an exhaust leak where one of the headers had cracked. I think the left one, but I'm not sure.
MAD Stangs #8
Threads Similar to: pinging? or ticking?
pinging... 02gtmustang 99-04 27 September 24th, 2009 01:35 AM
no more ticking/pinging ajm 99-04 55 March 24th, 2009 10:10 PM
Pinging when its colder hellbred07 2005 - 2010 3 November 23rd, 2008 11:19 AM
Pinging Odin 2005 - 2010 24 July 13th, 2008 09:40 PM
I think my car may be pinging.. need4steed 2005 - 2010 4 February 21st, 2008 01:03 PM
