stumbling in
hello,
i was wondering if anyone here could help. i have a 2000 3.8 manual trans. when i start out from a stop sign or signal, i get a hesitation and stumble when driving at normal road speeds there doesnt seem to be a problem. just initial take off. |
#2 | |
Re: stumbling in
I don't drive fast. I fly slow.
stumbling in
not clutch, i do have check engine light i should add.
just checked when in neutral i get same stumble when i 1st open throttle. hope this clears things up a little. thanks guys mike p.s when this happens i can hear it misfiring. |
#4 | |
Re: stumbling in
stumbles
it has a hesitation sounds like 1 or 2 cylinders are not firing
its not your clutch....as stated before its your driving.....that used to happen to me when i first started driving a standard...try giving it a little more gas...see if that doesnt fix your problem
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra |
stumbles
been driving this car since new.
this prob has just shown up recently. as stated i have a check engine light also. it is most certainly a misfire. thanks guys guess i better find a shop near me. mike |
MM's Resident Ricer
2006 Scion tC
13.001@113
A misfire would be a flashing check engine light go to autozone and get the code for us.
stumbles
hello gents
i ran codes today p0411 p1414 p1116 saw nothing that would cause stumble i have. maybe i need injector service,changed fuel filter seems to have gotten worse. mike |
MM's Resident Ricer
2006 Scion tC
13.001@113
http://www.modularfords.com/forums/a...achmentid=8047
look through that at all your codes and see if it helps any.
thanks green,
i looked at codes,had sai prob before but it didnt cause this stumbling i am having now. replaced air pump before showed same codes,was seized from moisture. will pull it again and check. but this stumbling happens when engine is warm and i notice it when in neutral also. give it pedal and right off idle it stumbles ,when in gear you can feel it is not firing all cylinders. once i hit about 2krpm it clears no other symptoms.
MM's Resident Ricer
2006 Scion tC
13.001@113
Do you have any mods or are you pushing high hp?
Also how old is the clutch?
green,
it is all stock 90k mi. original clutch, does it in neutral so i know it is not clutch. it doesnt buck like clutch probs,it kinda just chugs along unit it hits about 2k rpm. it is the initial throttle opening whether in gear or not it stutters clears its throat then alls well. if i mash the pedal it falls on its face then clears out around 2krpm. small throttle opening same result . |
plugs...wires??? cant overlook the small things
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
was gonna start this weekend with plugs and wires.
if that didnt clear it up, injector service is also on to do list. just need to get this cleared up emissions test coming soon. god i miss carbs! thanks for replies mike |
#16 | |
i would clean your maf out and iac for the hell of it. just be careful while servicing these parts. put some injector cleaner in your gas or just put it right in through the throttle body.
MM's Resident Ricer
2006 Scion tC
13.001@113
Clean the MAF make sure nothing is in the airbox take apart the intake and clean it up nice. If it isn't the clutch sounds like the car is choking.
#18 | |
maybe a new filter or just clean it
muneris pro ego
i had a similar problem and it turned out to be my air filter... i gleaned it out and it worked fine after
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
#20 | |
i didnt think about it but same thing with my dads f-150
Threads Similar to: stumbling in
| Another stumbling mustang changed IAC and Tp Sensor | onerealfastang | 99-04 | 12 | August 6th, 2009 06:02 AM |
| stumbling when going down the road | kdb30 | 99-04 | 9 | June 25th, 2007 12:35 AM |
| 86 stumbling under load | hopper | 5.0 Mustangs | 6 | April 25th, 2007 09:25 PM |
| Stumbling powerband issues continued. | MySallyMI | 99-04 | 2 | March 14th, 2007 12:10 PM |
