Sequential Tail lights w/ LEDs
Old March 6th, 2010, 05:33 PM   #1
Pdiddy321 is on a distinguished road
I have a 2003 Mustang and I installed the splice-in sequential tail lights kit. I replaced the stock bulbs with LED bulbs and they flash fast/don't work sequential anymore. Please help!
Old March 6th, 2010, 06:00 PM   #2
Admanistrator
v606er's Avatar
v606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud of
Which sequential kit did you get?
MAD Stangs #8
Old March 6th, 2010, 07:43 PM   #3
I believe it was the web electric do it yourself kit, I got it awhile back and just now decided to put LEDs
Old March 11th, 2010, 11:38 PM   #4
Vapor7's Avatar
1999 35th Road Race Pkg
Vapor7 is on a distinguished road
You probably need balast resistors on each segment of the lights to draw the right amps in order to get them to flash at the right speed. LEDs do not draw as much current as standard 3157 bulbs. My LED tail lights have two ballasts resistors installed on each one and they are not even sequential. I could probably fake it with some electrolytic capacitors but you'd have to experiment with the size then install one on each set of LEDs along with rectifier and possibly a resistor to bleed off the charge after each flash. Too complicated when you can probably get a kit some where for them. See if Americanmuscle has one.
Success is not how far you get,
but the distance you traveled
from where you started.
OK, and how FAST you got there!
Threads Similar to: Sequential Tail lights w/ LEDs
Sequential Tail Lights joshbarber17 Classic Mustangs 2 February 1st, 2010 07:17 PM
my sequential tail lights. dansgt Videos 7 September 1st, 2009 07:26 PM
sequential tail lights Matt060301 2005 - 2010 7 September 25th, 2008 03:47 PM
Sequential Tail Lights? Roos85 99-04 14 May 25th, 2008 06:31 PM
Sequential tail lights 05bluestang 2005 - 2010 18 February 22nd, 2008 12:25 PM
