blown head gasket, or cracked heads?
The other day I started up my mustang and it didn't want to start up and started shooting white smoke out of the tailpipe when it did. Checked it, and of course there's coolant pouring out too. Someone told me it was either the intake gasket or the head gasket, and hoping for the best I went in and replaced the intake gasket. Took me 3 days, a couple hours each day. Just my luck, it didn't fix it. I looked closer at the tailpipe and the coolant's gushing out, and since I don't wanna go through getting it wrong again. how can you tell if it's the gasket or the heads themselves? Plus, how much does it cost to get these things fixed? I dunno if I wanna take apart the whole enginge again
i hate to say it but that definately sounds like a severely blown head gasket. If you cant do it yourself or you dont have a friend to do it for you, its going to cost you more then likely an arm and a leg. Just hope the head isnt cracked but that may also be a possibility. if you thought doing the intake was fun the heads are a whole nother story.
![]() New block with forged internals running 16psi, tuned by Lasota Racing Too many mods to list... 3.73's and Truetrac Finally Done!
#3 | |
its not cheap at all.
would the car even start if the head was cracked
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra |
yes the car would start with a cracked head
i had a cracked head that went from the intake port on cylinder #4 to the spark plug hole and when they removed the head it was in 2 peaces... and as for it gushing out that much antifreeze im going to say ur going to need an engine flush thats IF its not to late and the antifreeze thats probably sittin in ur crank case hasnt ruined your main bearings your rods and your crank and oil pump. and probably lifters too. |
head gasket
What year is it? Earlier V6 engines were very prone to failed head gaskets. Later engines used a multilayer steel (MLS) gasket and were much less likely to fail.
To answer your questions. A machine shop can pressure test the heads to check for cracks or they may be able to see them if they are severe. A few points on removing and replacing the heads. 1. The head bolts are tight, you will need a breaker bar and probably a length of pipe to remove them. The bolts are stretch type and need to be replaced with new. 2. While the heads are out get a valve job and probably at least new exhaust guides. The heads need to be surfaced to a very strict tolerance on the finish for MLS gaskets. Also carefully clean and check the block surface. 3. Torque everything to specs. 4. Change the oil since it may have coolant in it. I used a victor gasket set which I believe is the original equipment manufacturer. It cost ~$480 for machine work and the gasket set/new head bolts. |
source for rebuilt heads
If you have a cracked head this is a source for a rebuilt good one
http://www.adccylinderheads.com/site...oduct/CH-207-F |
how expensive are gaskets?
ive seen a full kit for not nearly the price you guys are tlking bout. if im right it was under $200
price
yea I was forced to let my sister drive my car for 2 weeks a long time ago before i had my liscence and she warped the heades, ripped exhaust of three time and shit, but yea chris i think thats how much that part cost If it guzzling out open the radiator(WHEN ITS COLD!) and pour some coolant in and start it up let it bubble up ad some more and dore this for a little bit to de pressurize the system see If it still poors out, prob not it but its def worth a try, happened to my freind who didnt depressurize it after installing a new radiator so just give that a shot
2003 Mach 1, 5 speed ![]() U.S. Army - 11B "And on the 8th day god created the infantry and all hell stood at attention" |
#10 | |
#11 | ||
Re: price
gasket set
The Victor top end gasket set cost ~$130 from the supplier I use and the head bolts were ~$30.
ok, so I'm down to the heads, those exhaust bolts are a pain in the ass! Someone told me that when you take off the head bolts you gotta do it in a pattern or it can crack. Is this true? If it is, where could I find this pattern?
#14 | |
I don't have a haynes manual, anyone know where I can find it online?
Just found this pic, does it look right?
![]() So I take em off 8-1, put em back on 1-8? Also, how important is a torque wrench? I don't have one myself, so if it's necessary I'll have to borrow one from someone. |
#17 | |
head bolts and gaskets
As mentioned above remove the head bolts in the reverse order. As I mentioned before they are very tight. I used a 15mm 1/2" drive socket and a 3/4" breaker bar with an adaptor to 1/2'' and a length of pipe.
Be very sure to install the head gaskets correctly. The small water passage hole goes toward the front of the engine on both sides. Be very sure to torque the heads exactly as Ford says. You will need to rent a torque wrench. The bolts are torqued in three stages then one at a time loosened then torqued to a spec depending on whether it is a long or short bolt and then angle torqued 180 degrees. I did that as two 90 degree turns. I found I had to use a 1/2" drive universal to get to some of the head bolts. Also the intake manifold bolts need to be torqued but I had to buy a torque wrench with a lower range. After it's back together I would change the oil twice if there is evidence of coolant in the oil. Once before starting it and again after it has been run for a little while. |
torque specs
V6 tech articles on this forum gives the torque specs.
#20 | ||
Threads Similar to: blown head gasket, or cracked heads?
| =( blown head gasket | itschristorres8 | V6 Mustangs | 17 | October 23rd, 2007 12:14 PM |
| blown head gasket | 5.0pwr | 96-98 | 2 | September 18th, 2007 12:57 AM |
| blown head gasket.......new heads? | sniperrider | 5.0 Mustangs | 18 | April 26th, 2007 12:10 AM |
| Blown Head Gasket | Lax89 | 5.0 Mustangs | 10 | February 17th, 2007 09:01 AM |
| White Smoke / Blown Head Gasket? | terribleonexx88 | 5.0 Mustangs | 20 | November 2nd, 2006 01:28 PM |
