3.8 Oil Filter Housing
Old March 20th, 2010, 10:03 PM   #1
Proud American
MustangMatt96GT's Avatar
I need a oil filter housing... the plug is stripped on the engine we got now and it is leaking oil at the plug... it got threaded in crooked. Any ideas on where I could find one?
Ill get a picture later....
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old March 20th, 2010, 10:18 PM   #2
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
are you talking about the housing for the oil filter or for the oil plug on your oil pan? on either you could try googling it or go talk to your local ford dealer and ask about it. Then get the part number and see if you can find it at your local autoparts store for cheaper.
UDP, CAI, True Duals, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, FRPP C Springs, and J&M Full Length Subframe Connectors
Great Automotive How To's http://tooldesk.com/blog/
Old March 20th, 2010, 10:38 PM   #3
3.9L V6
ford is going to charge you out the ass for a factory pan...order an aftermarket pan...i suggest jegs
as for the stripping...is it the plug that is stripped (couple of $), or do you know if it's the pan...i assume you aren't talking about the filter nipple since the plug is the problem
[SIGPIC][/SIGPIC]
6k HIDs - Rear Sway Bar - Mac Prochamber - Goodridge Gstop SS Lines - Lots of Visual Fun - Go Fast Mods (no point in buying...it's a v6)
Want to see your car as art...ask me how
Old March 20th, 2010, 10:43 PM   #4
HMUSN's Avatar
iTrader: 9 reviews
That's a Ford part man. Or a junkyard. You could also look into adapters I suppose.
Old March 20th, 2010, 10:50 PM   #5
Proud American
Its not the pan at alll.. its the housing that mounts to the side of the block... his oil pressure has been acting goofy on his stock gauge... so we were putting in a autometer... we took the plug out of housing. drilled and tapped it for the autometer sending unit. and it went back in crooked... now its stripped and is leaking even more than it was before... its a #8 o ring thread... im going to try and re tap it for 5/8s pipe thread since the diameters are the same and use a different plug... i bet it works... but now i got to wait til i get keys for it again and can pull it in the garage.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old March 20th, 2010, 10:52 PM   #6
HMUSN's Avatar
iTrader: 9 reviews
hmm.. I can see it now.. A mustang that takes an f150 filter.. lol
Old March 20th, 2010, 11:01 PM   #7
Proud American
if it works it works... lol but its not the actual filter, but the extra plug on the end of the filter housing. ill see if i cant grab a picture
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old March 20th, 2010, 11:07 PM   #8
HMUSN's Avatar
iTrader: 9 reviews
Yea a pic would be nice.
I assume the threaded part is what you screw the oil filter onto?
Old March 20th, 2010, 11:42 PM   #9
3.9L V6
now that you shared the info about the tap for the new gauge things are clear....before it sounded like you meant the pans plug
[SIGPIC][/SIGPIC]
Old March 21st, 2010, 01:49 AM   #10
Proud American
similar to that... where the brass part goes in, its all stripped on the inside...
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old March 21st, 2010, 10:43 AM   #11
stephen has a spectacular aura aboutstephen has a spectacular aura about
The front cover costs more than $200 so be careful that you get it right. Perhaps you can drill and tap it for a bushing that will bring it to the correct thread size.
Old March 21st, 2010, 02:04 PM   #12
Proud American
Well its not the front cover... its the oil filter housing g that bolts to the side of the blooxk
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old March 21st, 2010, 08:10 PM   #13
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
I completely understand what you're saying, though it doesn;t seem like anybody else does. It really has nothing to do with the oil filter. It's the plug that goes in the end that you have to run an oil line from, that's how I know. And why did you re tap it in the 1st place? All you have to do is match up the plug that was in it with a fitting that would reduce to 1/8 npt or whatever it is for your gauge. It's a standard thread, not NPT. What your doing seems like the best bet to fix it.
Old March 21st, 2010, 08:25 PM   #14
Codeman's Avatar
+1 on above. You could have just reduced it. Since you have a tap and the threads are already shot I would try retapping it to a different size. You might get lucky. If not instead of buying a new oil filter housing look and locate the oil pressure sensor. It is a pain to get at, but with time you can work it out. And since his oil pressure gauge is working up you can then install the oil sending unit for the autometer in there. Again it is a pain to get at due to the location. Then if you take and either put some silicone gasket on the threads of the plug or something like that to prevent it from leaking you could plug that hole. Then you could use the oil sensor port for the oil sending unit for the autometer.
Old March 21st, 2010, 10:55 PM   #15
02 Mustang V6
13.605 @ 101.60
Garman91 is on a distinguished road
iTrader: 6 reviews
I'm lost... My oil filter screws on to my oil pump, which is held to the timing chain cover by 6 bolts. I have no brass fittings around my oil filter. Pics would be great but I understand you don't have the vehicle... I have a plug near the bottom of the oil pump (where the filter mounts to) that takes an allen key to remove, tried to take it out before and it's in there good, is that the location/fitting you're referring to? If so a new oil pump would resolve the issue and they're less than $100. Hope that helps a little, maybe?
Best of luck either way. Sorry if I'm completely off but I would really like to understand where the problem is at!
BBK Intake, BBK 70MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, Aluminum DS, 7.5 T-Lok w/ 3.73's, Centerforce Clutch, ZEX 75 Shot, Sniper Tuned
Old March 22nd, 2010, 06:47 PM   #16
Proud American
I got it fixed... was able to tap it to 1/2 NPT from the 1/2 oring port thread they are... no leaks now!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old March 22nd, 2010, 08:32 PM   #17
Codeman's Avatar
that is good. at least you got it fixed.
Threads Similar to: 3.8 Oil Filter Housing
Oil Filter Housing djstaab 96-98 5 March 22nd, 2010 10:23 AM
Oil filter housing bolts? 03_StangGuy 99-04 2 April 18th, 2009 08:26 PM
oil in spark plug housing conrad 96-98 2 August 25th, 2008 09:48 AM
Will this STOCK AIR FILTER HOUSING WORK for 2004 V6 warrior86 V6 Mustangs 4 September 26th, 2007 12:09 AM
Taking off stock Air filter housing RandoGT 96-98 6 August 3rd, 2007 03:20 AM
