How to fix the Intake exhaust manifold - Page 2
Old March 8th, 2007, 12:12 AM   #21
Sexyloftgirl is on a distinguished road
Look I am a girl and I have no cue what I am doing
I took the car to a mechanic and he said that it is cracked all the way around. The car sounds like it is popping popcorn when decelerating and it wsounds like atank when accecelerating. it has buring noises and it is on the right side of the car. I was told to replace the manifold, but I need to know how
Old March 8th, 2007, 12:18 AM   #22
punkafi888 is on a distinguished road
no no no, your exhost must be balanced!, some backpressure is good, but a lot is bad, the flow give some more air velocity to the engine. its all simple air flow dynamics, its like putting a 1000cmf carb on a 81 celica 4 banger, would all that flowgive you more power? no!
Old March 8th, 2007, 12:20 AM   #23
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
you can buy replacement stock manifolds for 99 bucks at
www.v6mustangstuff.com
and the different between manifolds and headers
manifold go into one big collection area before exiting while headers stay separate till they exit.
NCMM #9
Old March 8th, 2007, 12:30 AM   #24
MicronXD is on a distinguished road
Send a message via AIM to MicronXD
dats real spit right dundundun
lmao
Official MM Zeppelineers. Crew member #6 - Chief Petty Officer
Old March 8th, 2007, 02:21 AM   #25
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of light
Oh come on now green this is easy -
Their 99$ a SIDE... and in the case that you need BOTH SIDES
99x2 = 198
The Shorties are 219
And: Headers have the own exhaust pipe which is ran into the collector, where stock mainfolds do not.
Hi, You can call me Kyle
Old March 8th, 2007, 02:34 PM   #26
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah thats true but I mean if you do just need one your good with those or if your keeping it stock.
NCMM #9
Old March 8th, 2007, 02:49 PM   #27
The damn Car
Ok the mech. said that the right lower manifold is cracked all the way around. I have a good deal on a manifold for the car I am not worried about the price. But i was told that I would have to remove the engine out of the car to fix it and that seems kinda pointless since I am doing it myself. What i want to know is that if I need to take it off are there are free website car fixers on here???
Old March 8th, 2007, 02:55 PM   #28
MM's Resident Ricer
2006 Scion tC
13.001@113
you do not need to take the engine out. I am pretty sure it is just bolted on. I would go grab a Haynes manual it will have step by step instructions.
NCMM #9
Old March 8th, 2007, 02:57 PM   #29
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
yep its just bolted on easy to remove do this with the exhaust system warmed because that way u wont risk breaking a exhaust stud if you do good fuckin luck tapping your engine block heed my warning its not fun also dont burn ur self! if your putting long tubes on you may need ot unbolt the engine mounts and lift the engine a little to get them to slide into place on the studs correctly.
Old March 13th, 2007, 12:37 PM   #30
stephen has a spectacular aura aboutstephen has a spectacular aura about
replacement of exhaust manifold
If it is the same as a 99 V6 the job is certainly possible with the engine in the car. You are talking about the right exhaust manifold? The air intake tube needs to come out (the part that connects between the air filter and throttle body). Then there are two tubes connected to the manifold for EGR/air injection. Disconnect the one at the front and disconnect the front end of the tube that connects at the back of the manifold. The second tube can stay connnected to the manifold, though it would be much easier if you could remove it. Remove the two nuts at the lower exhaust flange to Y pipe. Remove the six nuts that hold the manifold to the head. Then remove the studs from the head. There is a hex end on them that fits a 5 mm socket. It should then be possible to remove the manifold and attached tube from the top.
Reassemble in reverse order with a new manifold and gasket. The nuts are tightened to about 30 ft lbs as I remember.
It would be helpful to soak all the nuts with penetrating oil overnight before taking it apart.
Old March 13th, 2007, 03:27 PM   #31
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
Its simple and pretty straight foreward...juts bolts right on...I did my long tubes with a couple jackstands....no need to pull the engine...there is a walkthrough somewhere on here with pics that should help you. That's what I used
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old March 13th, 2007, 10:13 PM   #32
95 mustangmiz's Avatar
95 mustangmiz is on a distinguished road
you schould go buy a haynes manual it not that much $$ but it is worth every penny
Old March 14th, 2007, 12:35 AM   #33
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
a good turbo kit comes with turbo manifolds...shorties are pointless for a turbo set up
[SIGPIC][/SIGPIC]
Acmillr loves me
Threads Similar to: How to fix the Intake exhaust manifold
Swapping a 98 V6 intake manifold with for a 99 V6 manifold 98mustang V6 Mustangs 6 November 21st, 2010 12:20 AM
Intake Manifold. Slicey 99-04 10 January 13th, 2008 05:50 PM
Help Intake Manifold stang94 5.0 Mustangs 8 October 26th, 2006 02:38 PM
PI intake manifold on a 96? tlgrant 96-98 8 September 7th, 2006 10:11 PM
intake manifold ayyubam2002 General Tech 2 July 9th, 2006 01:13 PM
