relieve fuel pressure_ take off gas cap to release the pressure
the fuel filter is held on with hairpin clips, spread the legs on the clamps then push in towards the filter do this on both sides
grasp the fuel lines and pull them off. be ready to get coverd n gas.
use a screwdriver to loosen the clamp securing the filter. and remove it
to install_ make sure you have the filter orientated correctly. push on the fuel lines, make sure the hair pin clips lock into place. pull on them gently.tighten the bracket..
turn the ignition to the on postion and give it a min to prime the system before you start the engine.
i just take the cap off tank. if you wanna do it the other way you can unplug the fuel pump or remove the fuse or relay for the pump and start the car and run it till it shuts off.
Here's how I've always done mine.
1.) Pop the trunk and pull back the carpet on the driver's side wall of the trunk, there should be a little eletronic device, unplug it. The plug is on the underside of the device, this is the inertia switch.
2.) Try to crank the car over.
3.) Unhook the battery
4.) Pop the filler cap
5.) Pop the hood
6.)Grab a small screwdriver and some paper towels.
7.) Locate the schrader valve behind driver's side of the throttle body on the fuel rail.
8.) Unscrew schrader valve cap and use the screw driver do dress the small metal nipple in the schrader valve. This is the same type of valve on your tire, so you use the same technique to relieve the fuel pressure as you would to let air out of your tire. Only difference it the gas will come out of the schrader valve when you depress it so that's be sure to wrap some paper towels around the screwdriver and valve to soak up the gas.
9.) Screw schrader valve cap back on
10.) go back to trunk only this time remove pull back the carpet on the opposite side (passenger side). Here you should see your fuel filter.
11.) Unscrew the screw clamp if you have one on your fuel filter.
12.) Take your fuel/brake line tool and use it to remove the hoses from either end of the fuel filter. Have paper towels ready and possibly a small container to catch any gas that may remain in the filter.
13.) Install new filter and put the carpeting back
14.) Put filler cap back on
15.) Plug the inertia switch back in
16.) Then hook the battery back up
17.) Turn key to on, wait a few seconds to allow the fuel system to prime itself.
18.) Fire up the car.
There's a Schrader valve near the fuel rail on the drivers side that you can use to relieve pressure if you want. Otherwise you can just relieve pressure by disconnecting your fuel filter since you'll be losing some fuel there anyways.
You will need a set of fuel like disconnects to get your filter off. I bought a 4.99$ set at my local auto parts store. They're easy to use if you never have, just pop the metal clips off of each side of your filter, slip the fuel line disconnect over the line and push in until it releases.
wow, or you can just take the friggn cap of the tank. and i dont know about yours but my filters on the pass. side in front of the gas tank under the car.
Yeah fuel filter is underneath car in front of gas tank. Hit the inertia switch in the trunk on drivers side as said to relieve pressure. Turn the car on after this, it will die on its own due to no fuel, but you want to empty the lines. Then you use the special tool to remove the lines from each end of the filter. Plug and play new one. Flip the switch back after installing new one.
*Use eye and hand safety you'll be spilling a little bit of fuel.
Thanks everybody for the replys. I had to get that tool to remove the fuel lines from the filter and I changed it this morning. It was really easy thanks again for the help!
i've never had a problem with just removing the gas cap, then again i've never replaced one after just driving it so the pressure could have dissipated on its own. but its the way i way taught to do it. hasnt failed me yet.
Just safer and takes more fuel out of the lines to hit the inertia switch and really clear the lines, rather than just letting the tank pressure dissipate through the fill tube.
Appreciate the info. Also...for anybody who has the same fittings as me
Related Threads
Modded Mustang Forums
6.3M posts
80.3K members
Since 2005
