bad ground?
Old April 4th, 2006, 05:05 PM   #1
bobvogel44 is on a distinguished road
bad ground?
having voltage problem 99 V-6, repalced pcm, new keys. Wasn't starting at all, but now we got it started but the voltage is high output and the engine is cutting out. We were told that was a bad ground SOMEWHERE but can not find it anybody had any problems like this one?
Old April 4th, 2006, 05:07 PM   #2
00SoSlow's Avatar
00SoSlow is on a distinguished road
Send a message via AIM to 00SoSlow
sry man never seen or heard a problem like that, ill look into it tho
Old April 4th, 2006, 05:43 PM   #3
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
To the best of my knowledge there should be about 3 places that ground on your car. The negative cable from the battery should ground to the engine, there should also be a smaller wire coming off of the negative battery clamp that goes into the body with a screw and there should be a body ground coming off the back of the block and grounding to the firewall somewhere. check all these connections and make sure that they are solid. If the grounds are all good I would recomend having the alternator checked. Overcharging is usually something to do wit the charging system itself (bad battery, bad alternator, bad voltage regulator, etc...).
Old April 4th, 2006, 08:47 PM   #4
173speed is on a distinguished road
I had the same problem bout 1 year go it was the voltage regulator
as far as ground i made my own with some wire and connection from radio shack it made my lights brighter
the ignition system that got it says that there should be at least 2 good grounds but i got four in the engine bay
SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$%
Old April 5th, 2006, 02:24 PM   #5
thanks for the replies, I'll check and see if any of these help, still no luck.
checked grounds, changed battery, the fan comes on and theft light binks fast. Any other suggestions.
Threads Similar to: bad ground?
Ground cable stano76 96-98 2 November 12th, 2007 08:32 AM
Dream Car - Fox GT Vert From Ground Up phsycostang 5.0 Mustangs 19 May 10th, 2007 07:47 PM
gt ground effects 347tt 5.0 Mustangs 22 March 7th, 2007 01:10 PM
ground effects mustangmaniac 5.0 Mustangs 10 December 4th, 2006 06:52 PM
GT ground effects brackets ruger 5.0 Mustangs 0 August 4th, 2006 08:45 AM
