2006 mustang 4.0
Never use this tool for rear brake calipers
http://static.summitracing.com/globa...-w80621_cp.jpg
Changed the rear brakes on my newly aquired Mustang (new ford owner). Holy crap! I had that square piece of ass tool that looks like something out of Hellraiser to turn the caliper back in, what a big mistake! I had to get a buddy to hold it down while I tried to fit the adapter in (had to be the smallest and least teeth), turn it, and push in. Spent forever on it until I learned to beat the rachet with a hammer while turning it. WHAT A TASK! Now that I look at it I only spent 5 bucks on the tool (instead of the more expensive hefty better tools) but if I had to do it again, I would go ahead and rent a high class device. WHAT A PAIN IN THE BUTT! But its done and over now....DONT BUY THIS TOOL! |
MM's Database Error
sorry you had trouble with it. i have the same tool and I never had any issue turning it.
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
i had the same problem as you. it sucks
![]() Mods = stuff to make me take corner faster
There's a similar but larger version that is designed for Ford brakes.
Resident badass
wtf is it... ?
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
MM's Database Error
its a caliper tool for turning the back brake pistons to get them back in when you change the pads
i always just use a rubber mallet on mine..
#8 | |
Resident badass
C-clamps on the front. Found out the hard way that the back ones lock up it you try to just push them in...
Senor Tini
this is what i used. its still kind of cumbersome. I rented it from autozone. 57 bucks with a full refund.
CAI, Screamin' Demon Coil, Livewires, Steeda Tri-ax, Steeda Clutch Quadrant and Adjuster, UDP, 8.8 rear end with 3.73's, 1/2 inch VAP intake spacer, SCT X3. |
Thats a different way of doing it but whatever works for ya I guess
#14 | |
2003 mustang
7.48x1.56=11.67
I just rent the oem tool from the auto parts store.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
2006 mustang 4.0
[QUOTE=motorhead6776;2837420]a c-clamp usually works for me. i havnt had to do the rears yet but it works for the fronts.[/QUOTE
YEA! LOL! The back ones are a lot diffrent than just pushing them in. You NEED TO TURN THEM as well as push. Whoever said they push the rear ones in with a C-clamp or beat them straight in with a mallet is smoking crack or has one nasty mod done.... |
Have the same tool man i had to do a little bit of tweaking to the tool but i got it to fit and work eventually made the brake job take a 30 minutes longer though
Compress rear brake calipers
I would actually recommend buying the universal brake caliper cube. Though non of them fit, minor modifications will allow the tool to work.
Take the surface with the 4 small pins in each corner. Take off 2 DIAGONAL pins with a hack saw, and file down if necessary. It is now wide enough to lock into the slots on your rear brake caliper. Works like a charm. |
One gear, GO!
![]() ![]() ![]() ![]() ![]() iTrader: 8 reviews
Resident badass
I just tried using that cheap tool two nights ago and the first brake it worked perfectly to compress the piston. But there was two much pressure after the first one was done so i had to go at 9:00pm to autozone to rent the caliper tool set and i was done in 5 minutes. It took me over 4 hours to change just the rear pads because i kept trying to get the cheap tool to work. I know from now on i will be buying the caliper tool set instead of the cheap tool.
Threads Similar to: Never use this tool for rear brake calipers
| Rear Brake tool | 04DSGV6 | V6 Mustangs | 11 | September 9th, 2008 10:48 PM |
| Rear Brake Tool | Mach Boy | 4V / SVT | 13 | July 15th, 2008 12:13 AM |
| 97 GT rear brake calipers, Help Please.. | 79StangPace | 96-98 | 6 | April 25th, 2008 09:09 PM |
| Has anybody rebuilt the rear brake calipers. | RandySiemens | 96-98 | 1 | October 14th, 2007 09:26 PM |
