leaking antifreeze - Forums at Modded Mustangs
post #1 of 18 Old May 8th, 2010, 02:30 PM Thread Starter
dark_horse's Avatar
leaking antifreeze
hello...i have antifreeze leaking. i just bought it yesterday and everything looked fine no leaks no nothing, and as of today took it for a drive and say antifreeze on the ground, so i started it up and theres antifreeze leaking out of this "pipe" (its rusted) thats leads from the water pump into the intake some where.
im trying to figure out whate the "pipe" is called
thanks
dark_horse is offline
post #2 of 18 Old May 8th, 2010, 05:04 PM
mustang227's Avatar
Well, first of all, i think that is the water pump that the line is connected to. It look like that has been occurring for awhile due to the rust. I would ask the last owner about it. He should have seen it. Did he let you drive it before you bought it?
mustang227 is offline
post #3 of 18 Old May 8th, 2010, 05:07 PM
Stang Tech's Avatar
Send a message via AIM to Stang Tech
it's the coolant bypass tube it leads to the heater core line in the back.
Ford Certified Tech Land Rover Certified Tech
Ase Certified Tech Honda/ Acura Certified Tech
AllData Automotive Information Specialist
03 Mustang GT
Vortech V3 Intercooled
407/415 to the wheels
BOOOOSSSTTTTTT
Stang Tech is offline
post #4 of 18 Old May 8th, 2010, 05:09 PM Thread Starter
dark_horse's Avatar
yeah...we and we drove it home at it took us about 3 hours to get home and we had no problems thank goodness. yeah the line comes right out of the top of the water pump.
i just need or trying to figure out what the line is called
thanks
post #5 of 18 Old May 8th, 2010, 06:55 PM Thread Starter
dark_horse's Avatar
i called o'reilly's and the guy didnt know what i was talking about, all he had was the vacuum line. is the part only available at a ford dealership or what?
post #6 of 18 Old May 9th, 2010, 01:02 AM
97fordsixer's Avatar
bullshit i work for an advance auto and if you ask then the company DORMAN makes a bypass tube in the help section. you might want to consider putting on a new waterpump while your in there too. just so you dont have to mess with it later.
bolt ons for now..... split port swap very soon....
97fordsixer is offline
post #7 of 18 Old May 9th, 2010, 01:04 AM
Gandolf's Avatar
Yeah!!! Like 8000 RPM!!! High RPM puts a LOT of pressure stress on Ford heater/coolant systems Find the weak spots you will!! Be glad coolant was not spraying on your front seats like when those *%&^&)#$% heater cores blow out!!!
It's a "blown heater hose bypass o-ring at the water pump". They are weird now since they have that wonderful o-ring+clamp thing to save money - I guess The "O"-ring failed... A minor problem... The car has probably been sitting for awhile... Print and takes you pictures to NAPA instead of "o'reilly's" and expect to pay $5 to $10 for the parts to fix it Know the "'Ford Mustang V-6' and 'year'" of your car since that is the first thing they will ask you. They will then just 'go get you' the stuff
It's trivial... Slow down, and it will seal itself... But fix it, and keep on driving!!!
Gandolf
Gandolf is offline
post #8 of 18 Old May 12th, 2010, 05:19 PM Thread Starter
dark_horse's Avatar
ok so i got a new line...the coolant bypass line or heater core line or whatever it called...i just got a new one today.
the thing is do i have to remove the intake manifold to remvoe the old one or not?
the thing raps around it and is bolted on somewhere.
thanks
post #9 of 18 Old May 12th, 2010, 05:40 PM
Gandolf's Avatar
You should not have to remove the manifold. I think all you need to do is:
Be sure the engine is cooled completely down.
Remove the clamps on both sides of the hose. Some coolant will spill but not much is up there.
Clean up any fittings and put the new stuff on.
Add some coolant to make up for what was lost.
That should be it. Sometimes those hose go under the manifolds and are harder to reach, but yours in the pictures looks really easy.
Gandolf is offline
post #10 of 18 Old May 12th, 2010, 07:48 PM
rfcsoulja's Avatar
thanks
Why didn't you just buy a 5 cent o-ring? There's no need to take off the intake. There are some small bolt on the backside of it, but you should be able to get to them.
rfcsoulja is offline
post #11 of 18 Old May 12th, 2010, 10:55 PM Thread Starter
dark_horse's Avatar
well the entire line had to be replaced....where the coolant we coming out it caused it to rust and im suprised the line never did bust lol
well took the manifold off, getting a new gasket tomorrow morning and finishing up tomorrow and going for a niceeeee drive =).....finally
post #12 of 18 Old June 28th, 2010, 06:21 PM
Intake Waterpump Bypass Hose Question
Hi, I am a female, 39, but know a bit about cars from my father. Just bought a 99 Ford Mustang, 6 cylinder, 3.8, and I am having the same problem with this water pump intake hose. It busted a leak. Man at the junk yard even had problems getting it off and said the intake would need to come off, then another guy said nope, it didnt, and another guy got it off. It seems its bolted in under the manifold in the back and that's the big hassle with this thing. I'm low on funds and was hoping this was a simple procedure but I'm guessing it isnt! My question is... if the intake doesn't 'have' to come off... is this something someone with little expeience can do? I mean I can use a crescent wrench, a screwdriver, and basic tools, etc, I'm just not a professional mechanic. Is this something that an amateur can do? It sounds like alot of problems but also since I'm a female I have little hands, and that might help, but with little hands comes little strength! It is the exact same hose shown in the pics on this forum. Also... I had read around and seen some things about bypassing it. Is this something that can be bypassed considering its a bypass hose? I mean, what's its purpose anyway! Is it necessary? Thanks, any help will be greatly appreciated.
khluvskh is offline
post #13 of 18 Old June 28th, 2010, 07:44 PM Thread Starter
dark_horse's Avatar
well i ended up takeing the manifold off...it was alot easier...
well the metal tube i had to end up ordering from ford. it was a 100...and of course you will need to get a new gasket for the intake aswell...but overall it was super easy, probably took about 10 or so minture to get the intake off, and the tube, maybe about 15 or so because the bolt on the tube was rusted so i had to use some penetrating oil...but other than all that it was EASY!!!
post #14 of 18 Old June 28th, 2010, 07:47 PM
SPAMMER
Yeah take the upper intake off and its pretty simple to do.
ESG-642T is offline
post #15 of 18 Old June 28th, 2010, 08:26 PM
There is a stud-bolt that holds that pipe to the intake manifold at the back and also supports one of the ignition wire standoffs. I believe that stud-bolt mounts to the lower intake manifold. It is fairly easy to remove the upper intake manifold then everything should be accessible. While you are in there replace all the hoses and get new coolant in the engine. One of the heater core hoses pretty much requires removing the upper intake to replace it.
stephen is offline
post #16 of 18 Old June 28th, 2010, 09:01 PM
Thanks!
Yeah, I dont know much about removing an intake manifold. A bit scared to do that. I think I know enough now to know I'll get someone else to do it. lol. Thanks for all the info!
khluvskh is offline
post #17 of 18 Old April 15th, 2013, 04:41 PM
Look Ma! My First Post!
coolant bypass tube
I was replacing my waterpump and the guy that was helping me crimped the coolant bypass tube a little bit right above where it eneters the waterpump but there is almost an inch that goes into the waterpump that is fine so we thought it would be alright but coolant started to spray out the top is this because its crimped or could i have broke the new oring by accidant
aperez26 is offline
post #18 of 18 Old April 15th, 2013, 05:15 PM
Way to bump a 2 year old page.
Anyway why did he crimp it in the first place. If you upload pics it would help.
13 Corolla S (ohhh yeah)
99 V6 DD
05 GT
BadXperiment is offline
Human Verification
