LinkBack (1) | Thread Tools |
#21 |
North Dakota State College of Science.
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
#22 |
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
It would be badass to have a 5.0 from your year tho
#23 |
Ok so I got a hold of an air grinder that is 1/4 shank. I need to get some bits for it. What bits did you use most blue? Also what speed or air psi should I run the air grinder at? I have been reading up on it. I am planning on buying a lower intake for my car that is already ported. But I still want to do it and learn how to port. And I would like to practice and hopefully do a decent job on the lower and upper and then sell them and help pay for more stuff for my car.
Also I have sanding wheels for polishin. My question is how smooth of a polish do you want? I have heard that you don't want a really smooth polish on the intake side. Would an 80 grit sanding wheel be smooth enough? Or should I go smoother? Alright thanks for all of the help.
#24 |
[8MINUS2]
get carbine bits , and a few junk manifolds from the junk yard and practice on those. Then practice porting with those..
#25 |
Ok I will try that. Then hopefully I can get decent at it and sell some manifolds and make some money.
#26 |
99 V6 BASE
NEVER RACED THIS ONE
Heres a few pic of carbide for alium. I would suggest you start with short shanks for a while.then work your way to the longer shanks.the more flutes the less agressive. make sure you get aluim cutters. the last one in pic is for cast iron, see cross section
![]() I used # 3 and #4 to do my lower and heads #4 gave a very good finish. I was not going to get involved in messy polishing.
#27 |
1999 Mustang V6
![]() iTrader: 3 reviews
Where can I find those bits? I used an iron one and the only problem was that they liked to clog and I had to keep using oil on the bit.
#28 |
Ok thanks blue. I will go and start looking for some bits. I am excited. I am planning on calling a salvage yard and maybe getting a junk intake to practice on. Then hopefully do a half ways decent job on mine so I can remove them and sell them for some decent money.
#29 |
99 V6 BASE
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/165253-worth.html
| My Updated Mustang Compilation - Car Videos on StreetFire | This thread | Refback | May 13th, 2010 12:37 AM | |
Threads Similar to: Worth it?
| Worth it? You tell me... | LaserRed97GT | Modular Mustangs | 10 | April 15th, 2009 10:34 AM |
| What is it worth? | ModMustang97GT | 96-98 | 14 | April 8th, 2009 03:01 AM |
| Would it be worth it???? | jack90gt | 5.0 Mustangs | 6 | April 4th, 2009 08:45 PM |
| Is this worth it??? | ma67cpe | 99-04 | 10 | September 18th, 2007 07:30 PM |
| Is it worth it | jem02 | V6 Mustangs | 7 | May 28th, 2007 12:49 PM |
