upgrading throttle body
Old May 14th, 2010, 11:37 AM   #1
iammclovin804's Avatar
iammclovin804 is on a distinguished road
so from what i've read on here, its pretty much pointless to upgrade the throttle body. I was thinkin maybe getting a 70mm throttle body then porting the upper and lower intakes to match. would it still be pointless to get a new throttle body?
Old May 14th, 2010, 11:38 AM   #2
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
In all reality the 300$ isn't worth it even with ported intakes.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old May 14th, 2010, 11:46 AM   #3
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
the only time a TB would help at all is if you go with FI or some serious power.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old May 14th, 2010, 01:40 PM   #4
davidstivers09's Avatar
1999 Mustang v6
davidstivers09 is on a distinguished road
What exactly does the throttle body do?
Old May 14th, 2010, 02:08 PM   #5
I'm doing it wrong
Rich J's Avatar
04 Grand Cherokee
Rich J is just really niceRich J is just really niceRich J is just really niceRich J is just really nice
It opens when u hit the accelerator to let more air go in your engine so you can accelerate, its right above your air intake. It also controls your idle with a screw that is attached to it.
Formerly known as Demon_54
"I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Old May 14th, 2010, 02:28 PM   #6
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
:facepalm
271rwhp N/A V6
Suck it.
Old May 14th, 2010, 02:46 PM   #7
Codeman's Avatar
A bigger tb won't do anything hp wise but it will give a little notice in different throttle response. just do to the greater volume of air entering quicker. it is not worth the 300 bucks. That would be the last mod I would do on our vehicles. You could get a lot better bolt ons for 300 bucks.
Old May 14th, 2010, 05:16 PM   #8
1999 Mustang v6
Thats what I thought, what kind of throttle body would you upgrade to anyways?
Old May 14th, 2010, 05:31 PM   #9
rfcsoulja's Avatar
01 True Blue v6
to slow to matter
rfcsoulja will become famous soon enough
. . . .I wouldn't. . .I've read a few cases where people have switched over and have only seen a 2-3 hp gain with force induction (around the 400hp mark).
My supercharged v6
http://www.youtube.com/watch?v=1lNkgKBw0bw
Old May 14th, 2010, 05:55 PM   #10
stangcharger's Avatar
stangcharger is on a distinguished road
Send a message via AIM to stangcharger
I made 385rwhp on 91 oct @11 psi with factory TB not ported. Switched to 70mm and saw no difference.
And the Throttle body response difference is due to getting more percentage of the air your engine needs at a sooner point in the pedal position.
example.
Stock TB- You see 50% air needed at 50% throttle.
70mm TB- you see 80% air needed at 50% throttle.
Only reason to upgrade TB is if it can not keep up with CFM needed by the engine itself.
436rwhp/378rwtq tuned by HPP
www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com
Old May 14th, 2010, 06:00 PM   #11
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
southfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of light
Send a message via AIM to southfour! Send a message via MSN to southfour!
If you really want to get a bigger throttle body get a cheap GT one, they can be made to work with VAP's tb jig so im sure you can make it work on a stock setup, however i still think this would be a waste.
I could be wrong but if you up grade your throttle body to say 70mm your intake opening would still be stock right, making it useless?
H/C/I V6
BMC Member: 12521
Old May 14th, 2010, 06:10 PM   #12
2006 GT Twin Turbo
BISKIT is on a distinguished road
My sixer had the prototype tb from accufab which we helped road test. Power gains were minimal for the cost of what it would be.
Don't waste your money.
If you haven't yet, do some gears. You will feel the difference A LOT more and spend just a little more than you would on a tb.
Old May 14th, 2010, 11:03 PM   #13
02 Mustang V6
13.605 @ 101.60
Garman91 is on a distinguished road
iTrader: 6 reviews
I have a BBK 70mm and the power gain wasn't noticeable. It also has a bad habit of "sticking." Very hard to smoothly open it from idle making driveability pretty crappy. Anyone who has one, take it apart, knife-edge the butterfly, polish the crap outta the housing where the plate closes at, and grab some all purpose bearing grease and put a very light coat on the rubber o-rings, that'll make it smooth again, for about 8 months...
Ported the upper intake to match the TB opening and then you run into having no material left at the top where the idle air bypass passage is... It's all together a pain for no gain...
You've been warned, LoL.
BBK Intake, BBK 70MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, Aluminum DS, 7.5 T-Lok w/ 3.73's, Centerforce Clutch, ZEX 75 Shot, Sniper Tuned
Old May 14th, 2010, 11:09 PM   #14
alright well i suppose i wont waste any money on that ha. my plan is to build a 4.2 with forged internals and i suppose a kenne bell 2.2 now. hopefully she'll be pretty fast.
Old May 15th, 2010, 04:22 AM   #15
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Most plans, never seem to happen...
I'm just saying.
Old May 15th, 2010, 09:36 AM   #16
02 Mustang V6
13.605 @ 101.60
iTrader: 6 reviews
^ What he said.
Old May 15th, 2010, 11:06 AM   #17
Codeman's Avatar
there is no hurt in dreaming though.
Old May 15th, 2010, 01:08 PM   #18
yeahh but when i make a plan, i follow through with it. just gotta wait until i get out of boot camp to start.
Old May 15th, 2010, 02:57 PM   #19
1999 Mustang v6
Plans can be accomplished, they just take time.
Old May 15th, 2010, 03:08 PM   #20
rfcsoulja's Avatar
01 True Blue v6
to slow to matter
I'm just saying.
My planes all along were to make about 330 hp. Heads and a supercharger and I should be there.
My supercharged v6
Threads Similar to: upgrading throttle body
Throttle Body? scxc15 4V / SVT 6 May 5th, 2009 09:12 PM
Throttle body 70 or 75? JerseyTrueBlue 99-04 15 April 23rd, 2009 12:33 AM
throttle body kreil45 94-95 3 March 23rd, 2009 03:58 PM
Throttle Body cobrarob 4V / SVT 18 April 13th, 2008 04:55 PM
Throttle Body? stangNV 2005 - 2010 9 March 30th, 2008 06:59 PM
