windstar swap
Old May 16th, 2010, 02:27 PM   #1
1998 mustang
lemkerailroad1 is on a distinguished road
Send a message via AIM to lemkerailroad1 Send a message via Yahoo to lemkerailroad1
windstar swap
i have a 98 3.8 that i am considering doing a windstar swap, i have read alot of posts here and i am asking for help as to what all i will need to upgrade the engine to the windstar
has anyone done this???? if so can you help me out as i am new to fuel injection modding
pics would be a bonus , please
dave
Old May 16th, 2010, 03:13 PM   #2
Stang Tech's Avatar
2003 Mustang GT Vortech
Stang Tech is on a distinguished road
Send a message via AIM to Stang Tech
do you mean changing the whole engine or just doing the windstar intake swap?
You will need to do a split port swap first as the windstar is only for split port and not a the single port like your car is.
Ford Certified Tech Land Rover Certified Tech
Ase Certified Tech Honda/ Acura Certified Tech
AllData Automotive Information Specialist
03 Mustang GT
Vortech V3 Intercooled
407/415 to the wheels
BOOOOSSSTTTTTT
Old May 16th, 2010, 10:28 PM   #3
1998 mustang
my 3.8 is a 98, i have heard that if i change the heads and lower intake to a 99-04 this will allow me to do the windstar change using the 98 block???????
Old May 16th, 2010, 10:48 PM   #4
rhauf is on a distinguished road
I too an interested in this.. and, not to hi-jack or anything (as i think this is relevant) but what are the differences between the single port mustang v6's, the split port mustang v6's, and the (split port) windstars? are the windstars better than the split-port mustang v6's?
Old May 17th, 2010, 12:41 AM   #5
Stang Tech's Avatar
ok to answer both the split port swap will give you some more hp and tq. the windstar intake swap will give you a lil more. but you need to do the split port swap before you can do the windstar intake.
for the split port swap you need: head's, lower intake from a 99+ v6.
the main difference between single and split is that with split you have about 20+ hp then single.
03 Mustang GT
BOOOOSSSTTTTTT
Old May 17th, 2010, 12:46 AM   #6
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
southfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of light
Send a message via AIM to southfour! Send a message via MSN to southfour!
From what most people say here ,You will see closer to 40hp in gains from a split port swap.
H/C/I V6
BMC Member: 12521
Old May 17th, 2010, 01:23 AM   #7
so if i want to do a split port swap, the ONLY parts i need are the heads and lower intake? (aside from the obvious such as gaskets)
Old May 17th, 2010, 01:37 AM   #8
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
no, you need this
Split Port Swap
heres the full list (from plove71387):
-99+ mustang v6 heads (including valves/springs)
-99+ mustang v6 upper intake **
-99+ mustang EGR tube and valve
-99+ Throttle Body
-TPS sensor for TB (1-CX-1488 from Ford) if not already on TB
-Throttle cable from 99+ mustang v6
-Modified fuel rail that has a universal fuel pressure regulator, and a return line.
-Accelerator Bracket (F4SZ-9728-B) if not already included on upper intake
-99+ mustang v6 coil pack and wires (your stock coil pack will work too)
-99+ mustang intake tube, or any 99+ mustang CAI kit
-99+ mustang cooling hoses (including the ones going to the heater core) and pipes. You can also make your own lines, by using plumbing elbows,hoses and clamps, and fab it up yourself. (Definately get these if you can.)
-16 a.w.g automotive electrical wire
-teflon tape, pipe sealant, RTV
-99+ head bolts/studs
-head gaskets (I recommend 99+ mustang gaskets)
-99+ upper and lower intake manifold gaskets.
-99+TB gasket
H/C/I V6
BMC Member: 12521
Old May 17th, 2010, 01:40 AM   #9
Awesome.. thanks for that list.. i've been searching for it but couldn't find it.. very helpful to have a shopping list ready!
Old May 17th, 2010, 01:51 AM   #10
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
Its in the sticky that says "Read this before asking about mods"
Look Here Before Asking About Mods
H/C/I V6
BMC Member: 12521
Old May 17th, 2010, 02:03 AM   #11
Dancing Naked In The Rain
mcqueen's Avatar
Originally Posted by southfour View Post
no, you need this
Split Port Swap
-99+ Throttle Body
-99+TB gasket
Just a note on the bolded point. If you're doing the windstar swap, you ONLY be taking the upper intake manifold from ffrom a 96-98 Windstar. Do the swap at the same time as the split port swap and don't waste money buying an upper intake from a 99-04 V6. It will need some minor modifications and everything else will either be reused from your car (well the 99-04 parts), purchased new, or custom fabricated. Check out VAP Auto - Windstar Kit for a good idea of what parts you'll need for the swap. Vapauto sells all the custom pieces if you're not up for fabricating them yourself.VAP Auto - Windstar Kit
My Hubpages
Hey.. r u really a tranny??
Old May 17th, 2010, 08:38 AM   #12
1998 mustang
ok thanks guys for the info
does it matter weather the heads are from any 3.8l as long as its 99+
and i was looking at head gaskets also they are totally different as well, would i use 99+ or the pre 99
again, thanks for all the info guys
dave
Old May 17th, 2010, 01:06 PM   #13
mcqueen's Avatar
Since you're swapping in 99+ heads I'd say 99+ head gaskets are what you want.
My Hubpages
Old May 17th, 2010, 01:34 PM   #14
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
I think you might need the pushrods too.
271rwhp N/A V6
Suck it.
Old May 18th, 2010, 01:56 PM   #15
1998 mustang
thanks again guys
i am off to the yard of dreams
Threads Similar to: windstar swap
windstar swap questions iammclovin804 V6 Mustangs 26 July 3rd, 2010 08:29 PM
3.8 windstar swap!!!! oscarhdz V6 Mustangs 2 May 13th, 2010 08:54 PM
4.0 windstar swap davidstivers09 V6 Mustangs 5 May 11th, 2010 01:15 PM
windstar swap!! Stang808 V6 Mustangs 72 March 18th, 2010 03:44 PM
For The Windstar-Swap Guys One Bad Sixxx V6 Mustangs 42 March 16th, 2010 06:45 PM
