Transmission from a V8 work in a V6?
Old May 18th, 2010, 12:06 PM   #1
krys091 is on a distinguished road
I have a 99 V6 Convertible with 150k miles, that has a crack in the transmission housing so been leaking transmission fluid for awhile. I've just been adding transmission fluid as needed figuring when the transmission started slipping I would take care of it then. Well, it started slipping a couple of days ago (doesn't seem to like 3rd gear much).
So I have been looking for a transmission and came across a Ford 4R70W with 41k miles on it for a really good price. But it came out of a V8, will it work in the V6?
Also thinking about doing an engine while I'm at it, what engines are direct bolt ins? Just the 99-00 mustangs, or are there others?
Thanks for any help!
Old May 18th, 2010, 12:18 PM   #2
1997 mustang gt
jhills2 is on a distinguished road
Yes the 4r70w will fit fine, because its the same transmission that broke in your car :-)
Eaton SC 6psi, 4.10 gears, PI cams, CAI, 70TB, OR-H, Bilstien struts/shocks, B springs, MM C/C, B&M trans cooler, 10th anny cobra brakes
Old May 18th, 2010, 12:22 PM   #3
Don't I feel silly
Thank you
Old May 18th, 2010, 01:45 PM   #4
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
The GT trans is stronger. 1st and Reverse are slightly steeper and 5th is slightly shallower. but I bet you wouldn't even notice it. Its like a .02 difference one all three.
271rwhp N/A V6
Suck it.
Old May 18th, 2010, 02:03 PM   #5
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Didn't realize it was auto... they are they same exact ratio if its auto...
271rwhp N/A V6
Suck it.
Old May 18th, 2010, 03:17 PM   #6
Yeah, I can't do the standard thing (bad knee :0) )
How about the engine? Any suggestions on other stuff I should change out while I'm at it? I love my car, so anything that's going to make it keep going.
There are 2 engines on ebay with under 75k miles on them that I can pick up locally for pretty cheap, but I was under the impression that only 1999/2000 are direct fits.
Threads Similar to: Transmission from a V8 work in a V6?
Transmission redsnake 5.0 Mustangs 20 April 5th, 2010 08:48 PM
Work pranksWhat are some pranks you have played at work and how did they turn out. Do chocolate The Clubhouse 33 November 25th, 2009 03:37 PM
Need New Transmission. ?which? Draidin 99-04 15 December 27th, 2008 10:48 AM
transmission invisa stang 5.0 Mustangs 8 February 15th, 2008 08:08 PM
Will This Transmission Work 88GTGirl New Members Introductions 3 August 13th, 2007 07:46 PM
