2000 mustang v6
torque ?
First of all hi im new to this site and i need some help hopefully you guys can help me out here i have a 2000 v6 mustang
and it has a rattleing soung coming from the rear of the engine i think its the torque converter ive tryed to find a good one for it but cant find one any ideas of where i can find one better than the stock one..
you might wanna make sure it's nothing else before you try replacing torque converter..
24/7 spotless 2004 v6-gone 2012 black 5.0 r.i.p. 2012 white 5.0 premium bassani axle back
Modded V6
![]() iTrader: 1 reviews
Make sure the torque converter bolts are tight.
![]() 1999 e46 328i BMW - Daily Driver 2001 SVT Cobra - Project 1995 v6 vert - SOLD 1996 v6 vert - SOLD 1995 v6 vert #2 - SOLD 1995 GT - SOLD 1997 v6 coupe - Parting |
2000 mustang v6
I WAS READING SOME THINGS ABOUT THE TORQUE CONVERTER ONLINE AND IT SAID SOMETHING ABOUT RATTLEING WHEN BAD MINE DOES THAT ONLY WHEN IN GEAR NOT IN PARK OR NEUTRAL IT DOES IT WHEN IM GOING UP A HILL REALLY SLOW OR WHEN I PRESS THE BRAKES AND THE GAS AT THE SAME TIME
2003 mustang
7.48x1.56=11.67
Converter is pretty simple to check. Put the front tires up on ramps and secure the e-brake. There is a dust cover where you can see the bolts. There is also an access panel mid ways up on the drivers side...this will reveal the bolts.
Start the car up and see if you can see or hear strange noises while under the car. May not be the converter. Could be a loose exhaust clamp or something along those lines. Usually if the converter is going out the car will feel real slugish. The converter will also whine.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
2000 mustang v6
So When I Do This I Got To Put It In Gear Right But The Problem Is I Would Need To Push On The Gas Pedal Thats The Only Time It Does It Ill Probably Have To Ask Someone To Help Me Out Ill Probably End Up Making A Short Video Just To Show You How It Sounds Thx Alot
Threads Similar to: torque ?
| torque | zigbigadoru | 96-98 | 29 | May 26th, 2009 09:57 PM |
| i need torque!!!! | silverstang | 2005 - 2010 | 84 | August 21st, 2008 07:43 PM |
| NEED MORE TORQUE!! | Cantbeatblack | 99-04 | 29 | September 26th, 2007 08:32 PM |
| torque...? | geofarrey | V6 Mustangs | 10 | February 8th, 2007 04:54 PM |
| torque | Rolis | V6 Mustangs | 14 | December 10th, 2006 01:51 PM |
