Help with alignment?
Old June 9th, 2010, 02:39 AM   #1
MustangV6Man? can only hope to improve
Ok so I have lowering springs about a 2" drop on the front. There used to be some on the rear but they were removed. So original springs in back, lowering in front. Need to get the car aligned now after putting a new rack on. Will there be any problems? I have read about some places not aligning if you have a car lowered.
Old June 9th, 2010, 02:43 AM   #2
Dancing Naked In The Rain
mcqueen's Avatar
You're putting caster/camber plates on with that much of a drop, right? Call around and make sure any place you want to take it works with caster/camber plates.
My Hubpages
Hey.. r u really a tranny??
Old June 9th, 2010, 02:45 AM   #3
I didn't put the springs in. The car came lowered front and back when i got it. But the back springs had to be removed due to the ebrake. Everything is as it was. Does Kost tire do this with no problems?
Old June 9th, 2010, 02:52 AM   #4
mcqueen's Avatar
I have no idea as there is no Kost Tires where I live. With a 2" drop, you'll need CC plates for them to do a proper alignment. 2" is a big drop, without CC plates they can only do their best and your alignment is probably still going to be off.
My Hubpages
Old June 9th, 2010, 02:56 AM   #5
Well I believe it's 2" but im not positive. And it's only the front...are you positive I'd need the Castor Chamber stuff?
Old June 9th, 2010, 03:22 AM   #6
mcqueen's Avatar
100% positive. The CC plates only go on the front. They'll replace the current bracket holding the struts in place. If you buy 4-bolt CC's then you'll have to drill another hole in the strut tower for the 4th bolt. Or you can go with 3-bolt CC's which won't require drilling. I'm sure 4-bolt are a little stronger though (and more commonly used).
My Hubpages
Old June 9th, 2010, 07:03 PM   #7
99 BLUE V6's Avatar
99 V6 BASE
NEVER RACED THIS ONE
99 BLUE V6 has a spectacular aura about99 BLUE V6 has a spectacular aura about
Absolutely
Threads Similar to: Help with alignment?
Alignment Off. ModMustang97GT The Clubhouse 16 June 30th, 2008 10:56 PM
Doing your own alignment AndrewA. 99-04 1 June 26th, 2008 03:04 AM
alignment Toph6888 V6 Mustangs 13 February 23rd, 2008 04:24 PM
? About Alignment mustang fanatic 2005 - 2010 4 December 17th, 2007 10:34 AM
Alignment? Mrdestboi 2005 - 2010 5 December 10th, 2007 06:24 PM
