X- Cal 2
Old March 21st, 2007, 02:32 PM   #1
mustang1072's Avatar
mustang1072 is on a distinguished road
Send a message via AIM to mustang1072 Send a message via MSN to mustang1072
X- Cal 2
Ok guys i need your advice on what 3 tunes i should get for it.... i want the most performance and HP i can get out of it... i really dont care much about gas mileage!... and 2 b honest i dont kno much @ all about these kida chips! thanks again guys
Originally Posted by Onemanzu
your moms a quicky... ha just playin ... but seriously
Originally Posted by mustanginky View Post
.... felt great in the seat of the pants dept.
2002 Ford Mustang GT
And so it begins... (mods)
Old March 21st, 2007, 02:35 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
get the tuner not the chip.
send a list of your mods to your tuner.
get a track tune
get a race tune
get a street tune
Old March 21st, 2007, 02:40 PM   #3
ya my fault im gettin the tuner not the chip
http://www.vmptuning.com/store/index...d=137&parent=0
thats what im getting... ok i hav... CAI, 65MM TB, TB spacer, exhuast, 4.10, Posi, plugs, wires, and am inches away from pulleys
Old March 21st, 2007, 02:42 PM   #4
get a track tune
get a race tune
get a street tune
i am very stupid when it comes 2 these tuners... whats the difference? so is that all i hav to tell crazylegs is i want a track tune, race tune, and street tune?
Old March 21st, 2007, 03:10 PM   #5
HMUSN's Avatar
iTrader: 9 reviews
i dont know if he tunes or not
but the pre ordered tunes are called "canned tunes" and they are OK
but if you want the best tune go with either a dyno tune or get a wide band 02set up
and datalog off of that.
Old March 21st, 2007, 03:16 PM   #6
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
Tell him you want a tune for the 1/4 mile a tune for WOT on a road course, and a normal everyday driving tune.
also what is this wide band o2 thing and how it work *sry to hijack*
NCMM #9
Old March 21st, 2007, 03:24 PM   #7
HMUSN's Avatar
iTrader: 9 reviews
here is why you need a wide band if you plan on more modifications. In case you don’t know much about AF, Lean has higher AF numbers and less gas, and Rich has lower AF numbers and more gas. If you run too lean your motor will get extra hot and lead to issues like detonation which will burn holes into your pistons, blow head gaskets, grenade motors, etc. Running too rich will wash the oil off the piston rings and cause issues due to excess friction. Lean will get you more HP, but will be closer to the edge of detonation. Running rich will net less HP, but will be more tolerant of bad gas, hotter temps, etc (safer). Timing also plays a role in heat and detonation so it’s good to know that a lean mixture will handle less timing that a rich mixture due to the cooling effect of the extra gas. Higher octane is required for leaner / more timing tunes. Never ever run 87 octane in a highly modified vehicle, and never run 91 octane in a car with the stock tune for 87 or you will loose power and get worse gas mileage.
The stock O2 sensors are narrow band sensors that have the very good resolution around the stoichiometric AF of 14.64, but have very poor resolution in the range below 12. The Narrow band gauges are a waste of money, they do nothing as far as actual AF at WOT because they are not accurate at the desired ranges. They are designed to use about 90% of their output range centered directly around AF of 14.64, so you get excellent resolution between 14 and 15 which works great for part throttle driving, gas mileage, emissions, but is way too inaccurate for WOT ranges.
The wideband O2 sensors have a linear output range from about AF 9 to AF 18 so they give accurate results over the entire AF range.
Here is some general AF target ranges, but feel free to ask any questions you might have.
NA car 12.4-13.2
Blown Stang 11.5-12
Heavily blown 11.0-11.5
here are 2 links where you can get them:
https://shop.tricktuners.com/splashPage.hg (my tuner)
http://www.autocarparts.com/parts/PLX/
Old March 21st, 2007, 03:29 PM   #8
MM's Resident Ricer
2006 Scion tC
13.001@113
thanks man. And how hard is the install?
NCMM #9
Old March 21st, 2007, 03:39 PM   #9
HMUSN's Avatar
iTrader: 9 reviews
its not too hard to do.
read the thread.. instructions are in the posts
http://www.mach1registry.org/forums/...539#post748539
Old March 21st, 2007, 04:37 PM   #10
MM's Resident Ricer
2006 Scion tC
13.001@113
awesome thanks again man.
NCMM #9
Old March 21st, 2007, 05:37 PM   #11
Thanks GF your once again a big help!
Old March 21st, 2007, 05:47 PM   #12
MM's Resident Ricer
2006 Scion tC
13.001@113
no problem
NCMM #9
Old March 21st, 2007, 07:16 PM   #13
Murderjetz's Avatar
Murderjetz is on a distinguished road
Send a message via AIM to Murderjetz Send a message via MSN to Murderjetz
that tuner seems to be available for a 94...I thought GF said for a 94 I'd have to stick to the chip..?
and how is a tuner better than a chip?
Listen to my music | Visit my garage
Old March 21st, 2007, 07:55 PM   #14
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
Is there really any purpose of having three canned tunes, when you pay for two of them, wouldnt just taking the free canned tune work untill you could get a dyno tune
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old March 21st, 2007, 08:35 PM   #15
MM's Resident Ricer
2006 Scion tC
13.001@113
canned tunes are cheaper.
And the tuners you can do more with and you don't have to re-flash them to get new tunes, but tuners aren't available for pre 96 cars you don't have ODB2 ports
NCMM #9
Old March 21st, 2007, 11:01 PM   #16
Murderjetz's Avatar
but on that website you can choose 94 and 95 from the list....
Old March 22nd, 2007, 09:15 PM   #17
I just ordered it... WHOOT! crazylegs is awesome $350 w/ tunes shipped! thanks 4 tellin me bout him chris... and thanks 4 the tune suggestions GF
