My white smoke problem
Old March 21st, 2007, 05:30 PM   #1
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
Well took the car in today...turns out the oil and coolant are not mixing at all, and there is no blown headgasket on intake manifold gasket...the car has been running and sounding fine, but i did throw a massive coolant smelling smoke screen on friday night, but the resevoir looked un touched. The mechanic did say something about mayb a coolant leak getting on the headers and burning off causing the smell and the smoke. Anyone have any ideas what it could be or where the smoke is from
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old March 21st, 2007, 05:58 PM   #2
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
Breakout is a jewel in the roughBreakout is a jewel in the roughBreakout is a jewel in the rough
Send a message via AIM to Breakout
It may be that a clamp holding the coolant hose to the block broke and/or loosened up causing coolant to get on your block. The only other thing if your gasket isn't blown is a hose actually has a hole. Usually what a coolant hose will do is bulge up (aka "becoming pregnat) right before it starts squirting coolant. As a result, the coolant could be spraying on your engine. I'm surprised the mechanic didn't check for loose clamps or broken hoses while diagnosing that oil wasn't mixing with the coolant and checking to see if your head gasket is blown. They can also do a pressure check on the system to see if there is a leak in your hoses.
Old March 21st, 2007, 06:07 PM   #3
2000 V6
He did say something about old hoses too...
2000 V6 vert
Old March 21st, 2007, 06:14 PM   #4
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
Yeah...grab a flashlight and look under the hood. Check around and see if you see any bulges in any of your hoses. If you see any, it would be a good thing to have the hose(s) replaced before they cause you a huge issue. If it's not your hoses, it may be your heater core. Every vehicle has a different location for heater cores. That is how you get heat in your car. They go out on older vehicles and spew coolant. It may be your heater core leaking on your hot exhaust. I wouldn't overlook that one....
Old March 21st, 2007, 06:32 PM   #5
2000 V6
Hmmm...doesnt the heater not work when a heatercore goes out
2000 V6 vert
Old March 21st, 2007, 06:36 PM   #6
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
sometimes...sometimes not. You can still get hot air even though the heater core is leaking. It probably only leaks when you have the heat on, as that's when the coolant runs through.
Old March 21st, 2007, 06:45 PM   #7
2000 V6
Hmm...I think I did have the heat on friday...
2000 V6 vert
Old March 21st, 2007, 08:40 PM   #8
¡ʇsnq ɹo uʍop ǝpısdn
check the heater core hose its a small by pass looking hose on the top of the water pump... mines behind the coil pack...
if that appears to be fine check the front cover and see if that looks to be in good shape... thats the metal piece that covers the timing gears and sits behind the water pump... it is covered with acesorries... so idk you could just check it ... but it might take a second
Old March 22nd, 2007, 01:35 AM   #9
2000 V6
Hmm...I'm off tomorrow...ill have time after class
2000 V6 vert
Old March 22nd, 2007, 01:36 AM   #10
2000 V6
2000 V6 vert
Old March 22nd, 2007, 01:37 AM   #11
yea i would have some pictures but my camera sucks ass and i don't have my car... so sorry... hopefully you can find what im talking about
Old March 22nd, 2007, 01:41 AM   #12
2000 V6
Ill start by the water pump...I know where that is...
2000 V6 vert
Old March 22nd, 2007, 01:41 AM   #13
2000 V6
Ill start by the water pump...I know where that is...where's your car?
2000 V6 vert
Old March 22nd, 2007, 01:45 AM   #14
in a garage... the front cover broke and they are gonna fix it cuz i wasn't making any progress on it over the last month
so yea
Old March 22nd, 2007, 01:56 AM   #15
2000 V6
Oh...too bad I hate to see a stang down
2000 V6 vert
Old March 22nd, 2007, 01:59 AM   #16
me to ... but at least its down of jack stands now too... instead of completely immobilized like it had been for 2 months T_T
Old March 22nd, 2007, 02:06 AM   #17
2000 V6
Lol true...my car has seen its share of jackstands too
2000 V6 vert
Old March 22nd, 2007, 10:44 AM   #18
Mustang RacR94's Avatar
99 cobra
N/A
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
smoke
check the thermostat gasket its common for them to go and all your gaskets and check your radiator to make sure it didnt blow out
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
BBK L/T off road H/steeda catback
SCT MAF
Tune
03 cobra pumps
HVGC
Threads Similar to: My white smoke problem
White Smoke When I First Start It Up? scrapdaddy jr. V6 Mustangs 14 February 27th, 2009 01:32 PM
My white smoke problem pt.3 ByPopularDemand V6 Mustangs 16 May 12th, 2007 05:40 PM
That white smoke ByPopularDemand V6 Mustangs 19 April 19th, 2007 10:56 AM
white smoke zero 5.0 Mustangs 47 March 19th, 2007 11:22 PM
white smoke? ByPopularDemand V6 Mustangs 31 March 6th, 2007 02:15 PM
