Wise to reset fuel pump shut off switch in trunk?
LinkBack (1) Thread Tools
Old June 29th, 2010, 12:37 AM   1 links from elsewhere to this Post. Click to view. #1
MustangV6Man? is loose again, somebody get the straightjacket
Just for the hell of it? Any harm done?
Old June 29th, 2010, 12:39 AM   #2
v6kid's Avatar
1999 Mustang v6
v6kid will become famous soon enoughv6kid will become famous soon enough
There is no real resetting as far as I knew. The button pops out when tripped, then you have to push it back in.
I went to school to be a mechanic, so I know what I'm talking about most of the time.
mods in the garage, slowly getting peppier.
Old June 29th, 2010, 01:02 AM   #3
lkyspwn's Avatar
2002 Mustang V6
lkyspwn is on a distinguished road
Mhm. ^^^
Black Stang Crew Member #12
Old June 29th, 2010, 01:14 AM   #4
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
If it's working, don't mess with it.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old June 29th, 2010, 01:44 AM   #5
Just Cheesin'
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.88 @ 101.15 N/A
Mr. Red Pony is just really niceMr. Red Pony is just really niceMr. Red Pony is just really niceMr. Red Pony is just really niceMr. Red Pony is just really nice
iTrader: 13 reviews
It doesn't reset it. It just turns it off. It would literally do nothing
271rwhp N/A V6
Suck it.
Old June 29th, 2010, 01:48 AM   #6
Not A Regular Member
Log Surfer has a brilliant futureLog Surfer has a brilliant futureLog Surfer has a brilliant futureLog Surfer has a brilliant futureLog Surfer has a brilliant futureLog Surfer has a brilliant futureLog Surfer has a brilliant futureLog Surfer has a brilliant futureLog Surfer has a brilliant futureLog Surfer has a brilliant futureLog Surfer has a brilliant future
There's really no use in doing it. That switch is also called the inertia switch. If you were changing the fuel filter and wanted to run the fuel lines dry before you pull the old filter off, then unplugging the switch would be a good idea. Otherwise you're not doing any harm nor any good. I think that switch is actually meant to be tripped in the event of an accident to keep fuel from being removed from the tank and spilled into the open (unless of course the tank itself is pierced) where it becomes potentially very dangerous.
Old June 29th, 2010, 02:00 AM   #7
Just Cheesin'
01 Built V6 (3.9)
13.88 @ 101.15 N/A
iTrader: 13 reviews
It keeps the engine from running in case you become unconscious and you are upside down with the engine running. You're right too though.
271rwhp N/A V6
Suck it.
Old June 29th, 2010, 02:05 AM   #8
I knew there was more to it, it's just been a while since I read up on the inertia switch Thanks for adding tho
Old June 29th, 2010, 02:09 AM   #9
Just Cheesin'
01 Built V6 (3.9)
13.88 @ 101.15 N/A
iTrader: 13 reviews
you bet
271rwhp N/A V6
Suck it.
Old June 29th, 2010, 02:10 AM   #10
Just Cheesin'
01 Built V6 (3.9)
13.88 @ 101.15 N/A
iTrader: 13 reviews
Im happy for has them though; not just for safety, but an easy way to drain to fuel lines.
271rwhp N/A V6
Suck it.
Old June 29th, 2010, 02:58 AM   #11
+1
Though my fuel filter was still full of fuel after I ran the lines dry. I wasn't wearing safety glasses and I really wish someone would have been there to see my ninja roll when I attempted to dodge the falling fuel and keep the fuel filter held up so it didn't dump all of the fuel out
Old June 29th, 2010, 03:01 AM   #12
Relieving fuel pressure is overrated. I parked my car, got some jack stands under it, got my fuel disconnect out and closed my eyes.
Old June 29th, 2010, 03:06 AM   #13
I hope you closed your mouth and plugged your nose too
Old June 29th, 2010, 03:07 AM   #14
Actually I just held a rag over the connection as I undid it. Seriously, you're only going to get a few ounces more out. When you plan on spilling some fuel anyway it's not a big deal.
Old June 29th, 2010, 09:29 AM   #15
1997 Thunderbird
14.06 @89.53 needs tuned
Dirtyd0g is on a distinguished road
That switch gets weaker every time you move it. First you never have a problem with it, then you mess with it. Before you know it someone slams the trunk and your car won't start, then you start hitting bumps on the road and the car dies....
Don't mess with it. That is a seriously rare happening, but I have seen it.
Alan
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/172085-wise-reset-fuel-pump-shut-off-switch-trunk.html
fuel pump inertia reset switch on 2007 Chevrolet Impala This thread Refback October 13th, 2012 12:28 PM
Threads Similar to: Wise to reset fuel pump shut off switch in trunk?
fuel pump wont shut off??? EscortSportage 5.0 Mustangs 2 September 29th, 2008 02:53 PM
fuel pump wont shut off. squirt 5.0 Mustangs 14 February 8th, 2008 12:27 AM
Fuel Pump/Relay Switch soop7 V6 Mustangs 3 December 20th, 2007 02:59 PM
Fuel Pump Cut Off Switch For Security catchtheroadrunner Audio/Video 12 November 28th, 2007 09:59 PM
Fuel Shut Off Switch jangrif 2.3 Mustangs 5 February 28th, 2007 06:57 PM
