The dreadful drip...
Ok so since ive been a member here ive read about this several times on here. Something is dripping on the passenger side and when i turn the car off and get out and listen, i hear it dropping on to something and sizzling. If i remember correctly our stangs are notorious for this and its dripping on the exhaust manifold. So my question is whats dripping? and is it an easy fix?
'00 V6 Procharged Mustang
Is that just from your AC condensor? If so it's normal.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). |
So is there no way to stop it? Wont this cause the exhaust manifold to leak?
#4 | |
Not sure if it will cause the manifold to crack though
Poor college student club ![]() |
2000 Jeep Grand Cherokee
![]() ![]() iTrader: 2 reviews
Is it anti freeze? My heater core broke and my friend showed me this little hole/plug right above the passenger side manifold that leaks coolant if heater core is broken. It started leaking onto my headers and yes, when I turned the car off I could hear it drip onto the header, then sizzle and burn up from how hot the headers get. Do you know where the two coolant lines are that bring coolant into and out of the heater core?
Here's a picture. See the two bare pipes sticking out of the firewall right above the passneger side PCV, those are the coolant lines for the core. Of course your's will still have the rubber hoses attatched to them. Scan the firewall down towards the ground until you see a little whole with like a black grommet sort of thing in it. Once you know where it is look again after you let the car run for a little bit, turn it off and if it is a broken heater core you should see coolant dripping out of this hole. I disconnected the hoses and bypassed the heater core all together to temporarily fixed the problem, but I will have to get it fixed before winter because right now I have no heat. ![]() Make sense, or am I just babbling?
Cammed '99 Mustang V6 -- Sold Supercharged '89 Hatch -- Sold Looking for a project Stang now... MILITARY CREW - TERMINAL LANCE - MARINE CORPS. INFANTRY www.wotmustangs.com |
99 mustang
it is the AC, unless it is an unrelated problem as you said to do with your coolant. you can re rout the tubes i think and it wont drip onto the manifold, it WILL cause it to crack.
MM's Database Error
it is just the ac condensation. a lot of people will build a shield that lets the condensation go around the exhaust instead of directly on it. yes the dripping over time can mess up your exhaust so if you can, try to do something about it.
Just get some tubing from your hardware store, and run it away from the headers. Eventually it will cause a crack
![]() Spectre CAI - Bullit 17x9s - Flowmaster divorced duals - VAP Intake Spacer Soon: ASP, Tokico Shocks/Struts, SCT X3 Tuner |
Admanistrator
Dude you might have gonorrhea. Go talk to your doctor about that.
2001 Mustang V6 Coupe
beat me to it. i was looking for a pic from that chapelle show episode "ITS YOUR LITTLE HOMIE HERPES"
99 V6 BASE
NEVER RACED
+1^ Thats what i did . Easy fix.
gotcha...thanks guys!
Gallagher's Worst Nightmare
Pics? Im not familiar with the AC components. I want to STOPTHELEAK...
![]() C/H/I 3.8 227rwhp 226rwtq @ 0psi, 0hp shot The Name is Danny. I'm a GM Technician. hi-comp 3.9 coming very soon. |
I never had a problem like this, guess I'm lucky. That I don't use my ac too often.
Threads Similar to: The dreadful drip...
| drip rail? | mmikeclass06 | Classic Mustangs | 6 | August 2nd, 2009 01:39 AM |
| Tranny fluid drip. | Darwin | 2005 - 2010 | 7 | July 9th, 2009 12:33 AM |
| drip rail? | mmikeclass06 | Classic Mustangs | 3 | May 1st, 2009 04:39 PM |
| Drip and hiss | LanceD | V6 Mustangs | 5 | August 4th, 2007 01:59 AM |
