Datalogging
LinkBack (2) Thread Tools
Old July 7th, 2010, 02:53 PM   2 links from elsewhere to this Post. Click to view. #1
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
Datalogging
Ok, so I am trying to datalogg my car. I am curious if I use the cable that I hook to the usb port that came with my xcal 3? I have all the livelink software downloaded, but when I plug it in with the xcal it says device not found.
UDP, CAI, True Duals, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, FRPP C Springs, and J&M Full Length Subframe Connectors
Great Automotive How To's http://tooldesk.com/blog/
Old July 7th, 2010, 03:08 PM   #2
Trick Tuners's Avatar
KB'd GT
General Datalogging How to Guide - Trick Tuners Forums
Getting Started
Load both of the Xcal drivers. Plug in the xcal and make sure it turns on and the computer gives some sort of connected message. Then unplug it. I've found that the best way to reduce livelink errors is to always reboot the computer before doing any data logging and follow this order.
1. Plug the SCT device into the OBD2 port up under the drivers side dash. Start up the livelink with no other programs running and wait for it to load, but to not touch anything.
2. Then plug the SCT device into the usb port of the computer and start the car.
3. Click on the graph icon (under file on the top left) to select the options you would like to data log. If you are not logging any external signals click OK and it should say verifying PIDs and the options should pop up.
Old July 12th, 2010, 11:35 PM   #3
Codeman's Avatar
Ok, so this is getting annoying am i retarded or what?
I hooked the xcal into the car first.
Then I started live link on computer with nothing else running.
I then connected the usb cable from the xcal to the computer with the program running.
I then clicked the graph button.
I still get the same device failed to open, failure to connect. I have tried all three usb ports on my computer same thing. I even tried connecting usb to computer, then open livelink and try it. It does the same thing. What am I doing wrong? Do I somehow have to add my device to livelink?
Old July 12th, 2010, 11:49 PM   #4
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of light
2 things I've figured out...
Livelink hates windows vista and windows 7
Anyway did you download the firmware?
Normally when I install on a new computer I download the firmware, download live link, then I'll plug the sct in to make sure everything runs good. Then out to the car I'll plug the sct into the car, then into the laptop and normally it works.
Hi, You can call me Kyle
Old July 13th, 2010, 11:05 AM   #5
Codeman's Avatar
Ok, I will try downloading firmware and see if that works. thanks
Old July 13th, 2010, 01:32 PM   #6
KB'd GT
Did you load the drivers for the X3? Typically its best to always use the same usb port.
Old July 13th, 2010, 02:40 PM   #7
Codeman's Avatar
I loaded the program for the x3 from sct. i will take a look at it when i get home which is where my laptop is. maybe i will try re installing it.
Old July 13th, 2010, 03:16 PM   #8
KB'd GT
Open up device manager and see if there is a yellow question mark that pops up when you plug the X3 in without the livelink software running. The drivers are stored in the SCT folder in the program files folder. If you plugged in the x3 and clicked ignore when the computer tried to load the drivers then you would probably get that message. Call up SCT if you are still having trouble.
Old July 13th, 2010, 04:19 PM   #9
Codeman's Avatar
ok thanks. i will check tonight.
Old July 13th, 2010, 04:28 PM   #10
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
Mine gives me trouble half the time, even though I do it exactly the same. Neither I nor my tuner know why.
Old July 13th, 2010, 04:42 PM   #11
Codeman's Avatar
ok well thanks. i know what you mean. it is like it hates me lol.
Old July 20th, 2010, 10:05 PM   #12
Codeman's Avatar
Ok well I now got the device to open in the livelink. I deleted and installed it again, and it was a newer version and now it works.
Now I selected the items to datalog by clicking on the little graph thing and then picking them from the list. They show up on a list. I then click the checkmarks next to them. But then when I start my car and datalog only like one if any will show values in the chart. What is going on?
Old July 20th, 2010, 10:33 PM   #13
2004 V6 Mustang
wolfeman04 is an unknown quantity at this point
Send a message via AIM to wolfeman04
Who doesnt??? Mac FTW!!
-Fab'd Dual Hpipe Flowmaster 40's
-K&N "FIPK" Air Intake
Buy my new gears and tlok
Old July 20th, 2010, 10:46 PM   #14
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
I hate mac, and generally dislike mac users when it comes to tech conversations... The usually aren't very "tech savy", and they try to argue ignorant points about why Mac is better. And then I ask them "so you have windows running on your mac why again?"
... Kinda shuts them up
/offtopic
Old July 20th, 2010, 10:49 PM   #15
Codeman's Avatar
I just have windows vista on my laptop.
Back to the point anyone know what I am doing wrong?
Old July 20th, 2010, 10:50 PM   #16
2004 V6 Mustang
/offtopic
well...i personally like my mac better because i like coding with it better. Im a huge fan of applescript. I also do have a pc and use it often for things my mac cant do. I do think both have there better points but im just a bigger fan of apple.
Old July 21st, 2010, 11:17 AM   #17
Codeman's Avatar
bump anyone know what i am doing wrong?
Old July 21st, 2010, 12:03 PM   #18
KB'd GT
Try following that order.
You need to run everything as the administrator and in xp compatibility mode. Enable those options on livelink and the drivers just to be sure.
Old July 21st, 2010, 01:09 PM   #19
Codeman's Avatar
Ok, I will look at the XP compatibility mode.
And oooohhhhh. I think I figured it out. I would not have the car running while I clicked the graph Icon. I will try that and if it don't work post back up.
Old July 23rd, 2010, 08:35 PM   #20
Codeman's Avatar
Ok, I am about on the verge of taking my tuner and shoving it up SCT a**
This is absolutely ridiculous. I just went to try datalogging my car for the fifth time. Did exactly like joe said.
I plugged in tuner on obd2 port. Started up livelink with nothing running. Then plugged tuner into laptop. Then started car. Then clicked graph. Still nothing only the time changes none of the items datologged do.
Ok how do I change the xp compatible mode?
Also this livelink must be new cuz it is different than the old one it is livelink 6.0 the extra shi*** version.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/173271-datalogging.html
Datalogging Troubles - Trick Tuners Forums This thread Refback August 5th, 2010 12:52 PM
Datalogging Troubles - Trick Tuners Forums This thread Refback August 2nd, 2010 07:38 PM
Threads Similar to: Datalogging
Datalogging with SCTX3? BlueDevil 2005 - 2010 3 February 4th, 2010 05:35 PM
Datalogging Codeman V6 Mustangs 11 October 31st, 2009 01:53 PM
Xcal3 datalogging carlos General Tech 1 August 21st, 2008 06:45 AM
datalogging? Drxlubex All Other Vehicles 3 April 6th, 2008 10:58 PM
DATALOGGING FIND NEED TO KNOW 05mustang_kb_charged 2005 - 2010 2 May 19th, 2007 12:35 PM
