A few auto transmission questions
Alright, so i know the first that needs to be done is a transmission cooler.
after that i understand there are a few tweaks and mods that can be done to improve shifting and increase ability to hold power while staying in one piece however i seem to be finding some mixed info. what i would like to know is if on the 1999 4R70W auto transmissions, is the Jerrry mod, or JMOD, still worth doing? the how to link i found is here. TCCoA Tech Articles is for a older(1997) transmissions. are there other suggested drill sizes to use etc...? also are there any other modifications that can be done with the use of a drill press and replacement gaskets and parts? i would enjoy doing the mods myself then simply buying a shift kit, however if there is a kit that just has things like springs and gaskets, that still have you do the drilling, that'd be great! also i should note that the end goal(not for awhile ) for the car is 300-400HP (turbo, maybe built guts etc...) so i would rather do most the mods to the tranny while im in thereThanks all for the help! -levi p.s. searching yielded me the posted link, as well as confusion |
1998 Mustang 3.8
I installed a B&M Shift kit formy '98 4R70W. I had to drill some holes, replacing springs, and other little stuff. I like it a lot, a lot more responsive shifts. (I can break the rear tire loose going into 2nd). I have put about 6,000 miles on it since it was installed and no problems.
2002 Nitrous Injected V6
12's?
You might want to think about a highstall tc, just a thought while your figuring out your transmission goals.
![]() Project Red Magic -Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped- -18 Inch Hypercoated Saleens wrapped in Nittos- |
Thanks for the info! im still debating on the shift kit Vs the mod....
as for the highstall TC thats just for better launches right? id probably pass as it wont be a drag car... more of twistys and road course toy. would still like to hear more info about the J-MOD... -levi |
2000 Mustang v6
16.683@83.86
check out trans-go shift kits as well, I did a lot of research a while ago on different kits and the j-mod, and trans go looked the best
![]() A turbo, exhaust gasses go into the turbocharger and spin it, with a supercharger, air goes in,witchcraft happens and you go faster~Jeremy Clarkson |
#6 | |
12's?
Threads Similar to: A few auto transmission questions
| Auto Transmission | trent2590 | 99-04 | 20 | June 3rd, 2010 06:02 PM |
| Auto Transmission | USMC '03 GT | 99-04 | 13 | September 15th, 2009 03:06 AM |
| 92 lx 5.0 Transmission Auto | bob | 5.0 Mustangs | 0 | September 28th, 2008 08:08 PM |
| Auto Transmission question | 04DSGV6 | V6 Mustangs | 9 | September 18th, 2008 11:41 PM |
| Auto Transmission Question | CyberPrey | V6 Mustangs | 7 | November 13th, 2006 05:03 AM |
