2000 Mustang V6
(2000 Mustang V6) I think my lifters are bad?
It all started a few days ago, from the inside of the car, it seems to come from behind the speedometer and rpm tach.
it will do it sometimes when it starts up cold and then when it idles down to about 700rpm it goes away most of the time but not always. When the engine gets hot, it gets a little louder but not too much. It usually clicks between 800 - 1000rpm and goes away after that. I figured that if anything Id hear it under the hood but i cant hear anything unless i place a broom stick on the engine with the other end to my ear to hear the inside of the engine through the stick, and you can really hear it under the air intake with the broom stick to your ear..its starting to tap even at an idle now too.. I thought it might be my crank so i put the stick on the oil pan like a friend told me to and listened for odd noises and everything seems to sound ok in there. Everyone i have talked to is saying its my lifters because its coming from under the air intake on the passenger side, but can only be heard through a stick or if you sit in the drivers seat inside of the car.. Someone please help me, Im new to these Mustang engines lol Thank You for any help at all |
Resident badass
By intake, do you mean intake manifold? I sounds like I could be lifters to me, but I'm not the guys to give a good answer on that, as I have never experienced it.
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
If i understood this all correctly Mr. Red Pony might be right, Im thinking it could be a sticky lifter which is where the sound is coming from.
Not Banned
seafoam it, then see if the noise is still there.
Resident badass
HaHAAA
![]() seafoam corrects everything!!
2000 Mustang V6
haha idk what seafoam is though?
Resident badass
it is at autozone. You put in in your intake, gas, and oil.
Resident badass
look up how to seafoam...
2000 Mustang V6
ok will do, oh and when you asked about if its under the intake manifold, if you can, go and look at my profile pics and look for the pic of the engine, i took a picture with the pole on the place of the engine where it taps a lot, let me know what you think
2003 Mustang V6 Pony Edit
Did you get the seafoam to get the lifters running good again. I think I got the same thing and it'd be nice to see if this worked before I go to the other options.
thanks. A
2003 Mustang V6 Pony Edition | 1968 Mustang RS |1980 Datsun 280 ZX | 1977 Camaro with '85 Intercooler Engine | 1971 Cadillac 472 cu.in. (7.7L) Engine | 1973 Mustang 5.0 Ragtop |
2001 Mustang V6
dont get seafoam, get B12 from what i hear its the exact same thing just the off brand. you can either pay $9 for seafoam or $3 for B12
2001 Mustang V6
i did just find out tho with the B12 and a plastic cup do not mix together. it ate a hole right through the cup. never had that problem with seafoam.lol
#13 | |
2000 Mustang 3.8
ehh w/e the mostly stock time is
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
2001 Mustang V6
yeah i kindof thought of that too. thats y i didnt put very much in it.lol
#15 | |
2000 Mustang 3.8
2001 Mustang V6
well i did pay the extra $6 the first time and put it in the wrong PCV hose and there was no vaccum on that one so most of it ran out the air filter so i had very little to put in the right PCV hose.lol the only thing i used the B12 for was through the vaccum hose and not strait into the crank case. after seein it eat through plastic i deffinatly wont do that so the OP should disregard my first post and spend the money. it is weird tho that the B12 is stronger and cheaper than the more expensive seafoam
#17 | |
2000 Mustang 3.8
It makes my wife horny
16.3@84@5kft
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k 1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21 2004 Nissan Armada - HIDs, LEDs, sippy and DVDs 2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
2000 mustang v6
14.6@99.68
You know wat if its a lifter I say eff it and while ur down in the block......cam it lol
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust Fixed clutch!!!!! "My mustang likes a good ol' fashion bowl of rice....especially fried" |
Threads Similar to: (2000 Mustang V6) I think my lifters are bad?
| Lifters Going Bad | burnout5.0 | 94-95 | 11 | November 6th, 2010 11:40 AM |
| Need help possibly bad lifters on my 2000 V6 mustang? | dfernandez10 | V6 Mustangs | 5 | July 15th, 2010 03:28 PM |
| 2000 Mustang GT Missing bad | ant305 | 99-04 | 5 | May 16th, 2007 09:07 PM |
