2003 Mach 1
12.7@107
![]() iTrader: 1 reviews
Is it the same thing?
Would putting a stroker kit on a 3.8 mustang be the same thing as buying a precision 4.2L motor? If so which would be cheaper?
the stroker would be cheaper... i believe
2003 Mach 1
12.7@107
What tools do you need to bore out the engin for the parts? A milling machine? I have no clue.
2003 Azure Blue Mach 1 5-Speed BBK LTs, o/r X-Pipe,FRPP 4.30 Gears, MGW Shifter, JLT Ram Air, AJE K-member, Eibach Sportline Springs, Moroso Wet Sump Street/Strip Oil Pan, Nitto 555Rs, Steeda Clutch Adjuster, SCT X-Cal 3, NGK TR55ix Plugs |
¡ʇsnq ɹo uʍop ǝpısdn
that one will come down to mechanical fees a stroker kit will run what 1.5-2k? and a new engine is 2.5k but with using your old you have to uninstall teardown then rebuild...
so its only a few hundred in difference... the thing is the 4.2 is new... so thats a huge swing on top of the price
2003 Mach 1
12.7@107
If i know what kind of machines I need to do it I might already have them.
so you are gonna do this in your garage?
an engine lift... a few jack stands and or engine stand... lot of wrenches and an impact should do it... just simple mechanic tools... maybe a crow bar or two? if you wanna do this in your garage i say get the 4.2 cuz thats just an easier endevour... but thats just me
oh yea then sell the old one after you clean it up really good and use the 4.2's create ... bet you could make $400 off an old used motor that is really really cleaned up
2003 Mach 1
12.7@107
No the tools to put a stroker on my engine.
#9 | |
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
... well you would have to rip apart the whole block... so pretty much what ever tools that takes... which i believe wouldn't be much more then wrenches and pry's... but thats just me... do you have a chilton or hanes?
read throught those and see if they say anything about rebuilidng an engine cause thats all your doing when storking... just now you have a longer pull/push so the psiton head moves farther ... therfore a bigger crank... but the block shouldn't have to be modded... you can contact a maker of stroker kits and see if the block needs to be remachined in anyway... but i am pretty positive it doesn't
Tuned hows it going i haven't seen you for ages... how are the internals coming?
#12 | |
ohh yea... so thats good... well at least its getting back together... i had a problem with my front cover... that being it broke... so i haven't driven my car for a few months... so i know how your feeling... i get my car back on monday too...
get us some finall numbers after you get it tuned and runnin right
#14 | |
I've got a trac loc and 3.73's waitin to go in once i get it back also
that will be nice... get a new video up too that old ones kinda out of date now huh?
Threads Similar to: Is it the same thing?
| any thing else | jwe | 5.0 Mustangs | 2 | November 5th, 2007 03:36 PM |
| Is there such a thing? | Red87DropTop | 5.0 Mustangs | 5 | August 19th, 2007 08:08 AM |
| one thing after another | sivart | 5.0 Mustangs | 7 | June 5th, 2007 10:23 PM |
| one thing after another. | flames_blue | V6 Mustangs | 34 | March 29th, 2007 11:02 AM |
| The cutest thing ever! | Victoria | V6 Mustangs | 25 | January 30th, 2007 08:15 PM |
