00 3.8 Mustang
Slow@slow
![]() iTrader: 2 reviews
after market sterio
i have a 2000 mustang that came with an aftermarket sterio, and i have no clue how to get it out, i have removed the faceplate and suck hopeing i would beable to just pull it out but no...the left side slides out but the right is held in some how, not sure what it is?
thanks, nick |
1999 Mustang v6
What brand/ model?
I went to school to be a mechanic, so I know what I'm talking about most of the time. mods in the garage, slowly getting peppier. 6ershootout.com summer of 2012... Be There |
00 3.8 Mustang
Slow@slow
its a ALPINE CDE-7872
thanks |
Resident badass
pics?
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
1999 Mustang v6
My Alpine just pulls out. Take the faceplate and trim off, then pull on it where ever you can get a grip.It might be the wires in the back getting caught on something.
Resident badass
Pull the cubby hole out and try to push the back of it.
Formerly 01silversixer
2001 V6
15.47@89.57
Most aftermarket head units require keys to get them out...basically little metal hook type things that you jam down the sides and they grab onto something and pull the head unit out from the mounting cage.
2000 GT 'vert
+1 try downloading the manual for the head unit.
Resident badass
I have never seen an after market one use the key. Mine bolts in, but I have the double din. All the other decks I have worked with will have clips on the dash kit the just hold it in there snug.
2000 Convertible V6
My kenwood head unit came with a set of the metal strips/keys to take it out. I am sure they are probably the same for all the kenwood systems. Look on ebay for alpine key/strips.
2000 Mustang
slow@slow
same with my pioneer. I also had the double din and my cd player was seperate from the radio itself. Working on something to fab that up! Anyways. Yeah take off the face, and border, and it should have a place to put a "key"
#12 | |
Dancing Naked In The Rain
These here are what my stereo came with for removal keys: They worked great since I pulled the radio back out because I'm going to sell the car. Also when you get it out, check what kind of stereo system you have. The basic system will have 2 connectors, 1 black and 1 gray. The premium will have the gray connector and then 2 metallic connectors (1 6pin and 1 8pin) and an amp housed in the dash. This in very important if you're getting a new stereo system because you'll need the right wire harness.
#13 | |
2000 Mustang
slow@slow
Yep, I had the premium too. Being a V6 I figured I'd just have the base so that was the wire harness I ordered with my stereo. Ended up going to Wal-Mart and picked up one that kind of worked although it didn't have anywhere to plug in the rear subs. I dealt with it for a few weeks before putting the factory stereo back in. I'll get the correct wire harness when I sell this car and get a new Mustang.
#15 | |
2000 Mustang
slow@slow
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
I second this... Easy solution to this problem
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
Problem is some aftermarket stereos have a sleeve that goes over stereo. The stereo locks into the sleeve and the sleeve locks into the dash so trying to force it out will damage the dash. The sleeve is a pain in the ass to get out even with the stereo out of it
2000 Convertible V6
You can try taking off the plastic trim from the center console (which I think is all the cage/sleeve holds on to). While its out you can paint it to match your exterior
Jailbait till 2013
2001 V6 / 94 Z28-gone
0-60 in -10.3
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
if you need the key, take a piston ring and cut it in half and maneuver it into the slot of the keys, thats what i did with mine and got it out in 15 minutes, beats having to go buy one for sure, but than again, i don't know who all has an extra piston ring lying around .
Threads Similar to: after market sterio
| Sterio Head Unit | BadBlackGT | All Other Vehicles | 3 | December 24th, 2009 02:29 AM |
| After market distributor??? | jam77 | 5.0 Mustangs | 8 | December 16th, 2007 10:57 PM |
| After market convertor's? | 2BFEARD | 2005 - 2010 | 0 | May 2nd, 2007 03:33 PM |
| new doll out on the market | HMUSN | The Clubhouse | 18 | April 26th, 2007 01:01 PM |
| after market vendors | jessy_is_rad | Vendors | 2 | November 17th, 2006 01:30 AM |
