Gears
Could someone explain to me how changing your gears ratio works? Which gear? etc........
I keep seeing this all over the forums about people upgrading theres to like 4.10's and that after you do a install like that you'll only be in first gear for a few seconds. Also if i Did this would there be any specific gear you change or all of them? |
Use the search feature here and you will find your answer.
MM's Resident Ricer
2006 Scion tC
13.001@113
I have a v6 so the stock gear numbers might be different for you not sure, but
stock 3.27 gears(ring and pinion in your rear dif.) your tires will go 3.27 rotations per 1 rotation of the driveshaft, but with 4.10 gears your tires will go 4.10 rotations per 1 rotation of the driveshaft. Hence you get much better acceleration.
that makes me wonder though...wouldn't that also result in more spinning when you gun it from a stop?
o ok that makes sense now thank you very much
#6 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
do 2005+ models have a 8.8" rear end?
#8 | |
#9 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
So then the GT have 8.8 thank you GreenFaleen
MM's Resident Ricer
2006 Scion tC
13.001@113
yup gt has 8.8. No problem
I'm going to this mustang lot this weekend with my dad to look for a car
Sweet.
Threads Similar to: Gears
| 3.73 gears or 4.10 gears? I need to get away from the 3.31's | 07torchgt | 2005 - 2010 | 91 | November 11th, 2007 12:25 AM |
| T-Loc or Gears? | Nick_Rapitis | V6 Mustangs | 24 | May 13th, 2007 04:18 PM |
| gears | 4.6gtmarine | 99-04 | 7 | April 3rd, 2007 10:23 AM |
| Gears? | gregkelley | 5.0 Mustangs | 4 | March 25th, 2007 04:34 PM |
| Gears and DRs | HessiaN257 | 99-04 | 6 | March 24th, 2007 10:04 PM |
