Discussing will this blow my engine? in the V6 Mustangs Forum. a couple of people told me that my turbo design would blow my engine and ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
a couple of people told me that my turbo design would blow my engine and i have seen the design i have on a few other v6 stangs. t3/t4 60trim. its a twin turbo intercooled system that flows out to a true dual exhaust. they tell me that its just to much air to flow in there. anyone who can give an answer to this would really help.
2000 v6 mustang this is the engine i have. |
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
mileage and boost numbers would help, but more than likely you will need forged internals and you would be fine, our blocks are beastly
![]() Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot, Custom suspension, Doc. I 50% STS MM 4 Banger club: Senior Ricer "Horsepower sells cars, torque wins races." -Carroll Shelby Thanks To My Sponsors: Strup Performance |
#3 | |
Re: will this blow my engine?
Just keep the boost at 8lbs or less and you should be fine for quite some time on stock internals. you will need to upgrade fuel to get past 4lbs though without leaning out
![]() New block with forged internals running 16psi, tuned by Lasota Racing Too many mods to list... 3.73's and Truetrac Finally Done! ![]() Water-methanol injection? Dyno Tune fo sho, Street tune FTL! |
#5 | |
#6 | ||
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
#7 | |||
#8 | |
damn thanks to every one who replied to this. that really helped now for my last question. im new to turbos and i dont know where to find this particular one. its a garret t3/t4 hybrid 60trim. i dont know all the numbers mean when i went to that website to find it. can some one help me find this one. also i need a big one for higher speeds and a smaller one for the lower speeds. thanks to any one who can help me with this one.
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
Yeah I agree texan are internals are great I just like to throw it out so if someone blows something I can say I told you so lol
![]() And Dark I'm not sure on the turbo stuff if Cricket doesn't get on this pm him and he will be able to help you, there are few other turbo guys on here I think.
any new t3/t4 will do, unless your looking for somethin with ball bearings which would be much more expensive.
A t3 would be too small for a 6 however the t3/t4 would work nice. anything larger would be overkill and increase spool time and lag unnecessarily. the t3/t4 can do 25 easy and 30 if you push it. either way, numbers youll probably never see most likely, so itd be a good turbo to work with for a twin setup.
#11 | |
hey thanks for that link but on a tt dont you use one big won and one small one? also, damn thats the cheapest one i have seen yet any reason for that?
#12 | |
plus seq turbo are tuning nightmares |
#13 | |
well i choped off the y pipe and put on a h pipe adapter for a true dual exhaust. thats why i thought of using that set up. if i had one turbo than wouldnt the air flow out of one pipe causing less power?
#14 | |
#15 | |||
1995 BMW 325i
http://img.photobucket.com/albums/v3...5/cpc1copy.jpg
#16 | |||
anyways blow your money how you like and dont take my advice i dotn care i am just putting it in perspective |
#17 | |
1995 BMW 325i
i would rather have twin turbo to compensate for the weak engine. in a more powerful car i would lean towards single.
#18 | ||
Air Embolism Assassin
8.876@80.013 1/8th
the setup your talking about with the 2 sized turbos is called a sequential setup. Now since you are new to turbos I don't recommend that setup because you need to know how to read turbo maps. You want a turbo that spools quick, and then "dumps" it boost into a larger turbo to spool it quicker. It acts as like a single turbo setup with no turbo lag. Also it takes a bit of fab work as well. I really don't recommend that kind of setup too much. For a street car a parallel turbo setup will make you happy. Remember...turbo lag is foreplay.
![]() Blue Mustang Society Modded Mustangs Breast Cancer Awareness Bike Thread |
#19 | |
ok guys cmon. see i think i can do it for just under 4000. but i dont want to go back 2 a single exhaust. thats why i was wondering about the twin turbo. but wouldnt i lose power if i used one turbo on a dual exhuast like that. wait a minute what if i put an x pipe on there with some high flow cats. would that work with a single turbo??
#20 | |
8.876@80.013 1/8th
You still need a fabbed up y-pipe, and then something like a y-pipe type adapter to make it look like true dual exhaust. It won't work the way you think it will because both exhaust manifolds have to go to the turbo, and then out from the turbo for the exhaust.
Threads Similar to: will this blow my engine?
| best way to blow 3k | chrish91286 | 99-04 | 32 | October 31st, 2007 02:29 PM |
| blow off | mystang0673 | 99-04 | 0 | August 30th, 2007 11:26 PM |
| Blow By | jj2473 | 5.0 Mustangs | 7 | July 15th, 2007 12:32 AM |
| engine gonna blow | rcm | Engine | 10 | April 19th, 2007 08:20 PM |
| Blow This! | TheUNZippee! | The Clubhouse | 29 | March 15th, 2007 10:16 AM |
