3.8 to a 5.0
whats the difficulty on switching out the v6 to a v8, and will the 8 cyl. fit the stock v6 manual transmission?
Zoolander
04 Cobra #2260/3768 1/820
you would need a new bellhousing, but it can fit. It's more difficult than just dropping the motor in. Unless this is gonna be a balls out strip only car...it's not worth the effort.
Modded V6
![]() iTrader: 1 reviews
Not worth it all....5.0's didnt even come with that much power =/
![]() 1999 e46 328i BMW - Daily Driver 2001 SVT Cobra - Project 1995 v6 vert - SOLD 1996 v6 vert - SOLD 1995 v6 vert #2 - SOLD 1995 GT - SOLD 1997 v6 coupe - Parting |
¡ʇsnq ɹo uʍop ǝpısdn
Your car should be as you desire... If you wanna 5.0 then put a 5 0 in it... they are nice engiens if you get a crate motor you can get them with a lot of power... or one from a junk yard that is re done...
it will not be a direct drop in a few mounts will have to be changed and the tranny will not mesh right the bell housing will be off a bit... but if you could find one with the 5.0 out of a junker that would work... everything else if you use a OBDII harness should be kinda easy... just a lot of custom fabbing
#5 | |
Zoolander
MM's Resident Ricer
2006 Scion tC
13.001@113
If you have a 94 or 95 it isn't that bad, but if you don't and still want an 8 get a 351w
if you have the chance to get a 5.0 they are pretty good motors just upgrade it a bit before you drop it in.. they say "5.0 didnt come fast" who cares fox bodys are also heavier than our cars so youll see more power through that.. also 5.0 react to mods very well.. you wont have to fabricate anything.. you just need custom motor mounts.. the wiring harness for the motor will be the hardest/expensive part you need
I don't drive fast. I fly slow.
are you sick??? foxbodies are a good bit lighter than an sn95-newer
'87 Mustang 5.0 T5 Coupe New motor I/P: stock shortblock Edelbrock heads Typhoon Intake 70mm TB 80mm MAF 24lbers 1.7 rr B303 cam. Shooting for 300rwhp? |
thats what i meant along the lines of fabbing to be honest
the mounts and the wiring harness... hey just kinda on this topic Clevland or Windsor which is better along the lines of 351's?
MM's Resident Ricer
2006 Scion tC
13.001@113
Windsor is a better engine but Cleavland has better heads. Alot of guys around here have Windsor's with Cleavland heads
