whats the deal
with my rpms i normally idel a little under 1k well yesterday @ McDonald's drive through i was waitin 4 my food n my rps were bobbing back and forth between about 1000 and 1250... whats the deal? this is odd
How long had you been driving at that point? Mine idles around there for a little while after I first start it, but after the engines warms a little it idles around 700 like its supposed to.
Just another middle class white guy. |
MM's Resident Ricer
2006 Scion tC
13.001@113
Do you have your tuner yet?
no but crazylegs said its on its way... needless 2 say i cant wait!
MM's Resident Ricer
2006 Scion tC
13.001@113
Hmm may have just been a fan shutting off or something mine did it every once in awhile before I got my tuner.
#6 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
Thats weird, do you have a stick or an auto?
#8 | |
#9 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
nm then. are you like sitting on the clutch and letting it out a bit to roll forward when it is doing it? You may just have the clutch at an awkward point.
no i just put the e-brake on and was sitting there listing to music (it was really busy haha)
MM's Resident Ricer
2006 Scion tC
13.001@113
hmm e-brake may have done it if you left it in gear.
i didnt hav it in gear cause it was on...lol
MM's Resident Ricer
2006 Scion tC
13.001@113
I figured not. I have no clue then man.
Your idle is controlled by the IAC valve and the ecc. It's possible you just had a glitch condition in the ecc that caused this. Alternating rpms like that is an oscillation condition that can happen occationally, but it should not persist. Does it do it still? Have you changed something to you car or has the ambient temp changed abruptly? Do you use an oil/cotton air filter? Sometimes the adaptive learning portion of the ecc can develope a bad habit. If it persists, try clearing the adaptive learning by disconecting the battery from the car for 15 minutes or so. This clears the learned conditions and the ecc will start to relearn new ones.
2002 Summer Beater |
#16 | |
#17 | ||
Cleaning the IAC valve (google search for how to) Cleaning the MAF sensor with nonresidue electrical contact cleaner (google search for how to) Check for vac leaks (including the CAI connections) Clearing the adaptive learning (disconnect the bat for 15+ min.)
Tree Fiddy Z
Was your air conditioning on when you were sitting in the micky d's drive through? The compressor clutch engages/disengages constantly, causing rpms to sometimes flucuate....usually not that much though and usually not at that high of rpm.
#19 | |
#20 | |||
Threads Similar to: whats the deal
| good deal or bad deal!!!!!!!!91 coupe and 5.0 engine | kngkahious | 5.0 Mustangs | 11 | June 6th, 2007 02:38 PM |
| ok I beat another 4.6 whats the deal on HP. Why switch to 46 | 1911A1 | 5.0 Mustangs | 27 | June 1st, 2007 01:02 AM |
| Good deal or No deal??? | Hoss | Classic Mustangs | 17 | January 9th, 2007 10:23 PM |
| 2006 Mustang - Deal or No Deal? | PacMan66 | 2005 - 2010 | 8 | November 30th, 2006 10:58 PM |
| E brakes...whats the deal? | RedneckPony | General Tech | 3 | June 25th, 2006 06:14 AM |
