2001 mustang v6
Do I have gears???
I got the car as a gift and there are many upgrades that have already been done. The one thing i can't figure out is if it has upgraded gears. is there any way to do this without opening the differential cover? would a tuner help me?
'00 V6 Procharged Mustang
Jack the car up, put it in neutral and spin your driveshaft by hand until you get one complete rotation out of your wheel.
If it takes 3.27 rotations then they're stock gears. Also you can check to see if you have limited slip similarly, jack both back wheels up and if when you spin one by hand the other spins the opposite direction then you do not have limited slip.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). Last edited by mp4 player; August 12th, 2010 at 05:20 PM. |
14.37 @ 96
or try this also, tell us what ur driving (auto or stick) and what your rpms are at 70 mph, most people can tell you just by that what your gears are
3.73's w/ auto @ 70mph are just under 2500rpm thats what im driving. |
It's not easy being green!
2001 mustang
3.76@306
at 65 to 70 my rpm's are at 2k. at 60 there like 1800-1900
2001 V6 vert....mostly stock but she's my beauty. ![]() TOPLESS MUSTANG CLUB |
2001 mustang v6
I have a 5 speed. I'm at work so I can't post my rpms till tomorrow morning
Ok well my 5speed with 3.73s at 75 is at 2.5k
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
04 Stang 1.0Gallon V6
14.45 @95.8
![]() ![]() iTrader: 2 reviews
stock gears are around 2k at 70mph and 2.5k at 80mph, shit thats with auto though, so it should be a little lower rpms with the manual
2004 Bolt on & Cammed 3.9L V6 |
#8 | |
2000 mustang v6
14.6@99.68
I thought stock gears wernt even above 3.0 more like 2.27 or a little higher cuz 3.27 and 4.10s u can by and there not stock.....americanmuscle.com
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust Fixed clutch!!!!! "My mustang likes a good ol' fashion bowl of rice....especially fried" |
2010 GT Sterling Grey
12.97 @ 107.34
you could just ask the person who gave it to you...
#10 | |
Just because americanmuscle sells them doesn't mean they aren't stock, they sell lots of direct replacement parts. if I recall correctly 70mph on my manual is 2050rpm with stock gearing.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). |
2001 mustang v6
5th gear at 65 is 2200, 70 is 2500.
Gears? |
2003 Mustang GT
14.16 @99.03
Sounds like you have some gears in it.
Military Crew - United States Navy - Second Class Petty Officer My 2v build - MMR 1000 rotating assembly, Stage 3 heads/cams, 76mm turbo. Shooting for 700+rwhp. |
12.97 @ 107.34
Sounds like 3.73s to me, possibly 4.10s.
2003 mustang
7.48x1.56=11.67
What rims and tires?? 26"??
Sounds stock to me.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
I have stock 15" rims with stock size tires and stock gears. I turn 2050rpm(or 2150, can't recall atm) at 70mph in 5th gear.
If he's turning 350-450rpm higher than me then those definitely aren't stock gears or he has some really really small tires.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). Last edited by mp4 player; August 13th, 2010 at 06:38 PM. |
14.37 @ 96
i believe 94-98 were 2.73's and 99-04 were 3.27's
2001 mustang v6
At work again but il check my tire and rim size at lunch, the rims are svt if anyone knows the size.
2003 mustang
7.48x1.56=11.67
26" prolly
14.37 @ 96
dads svt focus are 17 rims dunno his tires lol
Threads Similar to: Do I have gears???
| Speedo after gears. Where to buy gears and speedo fix... | justinsstang | V6 Mustangs | 9 | September 15th, 2010 02:57 PM |
| speedo gears for 4.30 gears | bcinthearmy | 94-95 | 2 | April 23rd, 2009 12:02 AM |
| 3.73 gears or 4.10 gears? I need to get away from the 3.31's | 07torchgt | 2005 - 2010 | 91 | November 11th, 2007 12:25 AM |
