2003 Mustang V6
Cooling fan and AC problems....
I am assuming that my 2 issues are related since they both poppe up at the same time. I was idling at a stop light with my AC on when suddenly the air got hot. Once I got up to speed again (45mph) the air worked again but not nearly as good. Also, the compressor seemed like it was whistling or sickly sounding. At idle it only kicked in fo about 5 seconds at a time.
I was trying to figure out what was going on under the hood when I realized that the cooling fan was not turning on and the engine was overheating. No fuses blown that I can see and all plugs are tight. No CEL either. What does this sound like? Bad coolant temperature sensor? Do the problems seem related? |
2002 V6 82k
Does it over heat when the ac is off too?
2003 Mustang V6
I figured it out. The fan blade was broke. The rim on the edge broke and the fan quit trying to spin. We reattached it with a little sheet metal and pop rivets but the blade is very sensitive to balance. Anyone know where I can buy just a fan blade?
2002 V6 82k
At least you found your problem. Maybe try a junk yard
Threads Similar to: Cooling fan and AC problems....
| Cooling fan? | DegralDan | 99-04 | 4 | July 11th, 2010 05:13 AM |
| cooling fan | ModularSteed | 96-98 | 3 | October 29th, 2009 02:13 PM |
| cooling fan problems | fast5.0lx | 4V / SVT | 1 | April 9th, 2008 09:40 PM |
| Radiator Cooling Fan Problems | jagstang96 | 96-98 | 1 | October 15th, 2006 05:05 PM |
| Cooling Fan Problems | rene9 | 96-98 | 6 | September 26th, 2006 06:29 PM |
