Porting Update
Old August 12th, 2010, 08:04 PM   #1
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
Porting Update
I started porting two days ago and did some more today. I have worked around 4 hours on the lower intake. I am making good progess. Ok I have one question however. I have a pretty rough finish from my cutter. I know that you don't want a smooth finish because it slows the air. But how smooth is too smooth? And how rough is too rough?
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old August 12th, 2010, 08:08 PM   #2
plak424's Avatar
2000 Mustang v6
16.683@83.86
plak424 is on a distinguished road
you want as smooth as possible. If you leave any roughness it creates turbulent flow in the air which slows it down. When its really smooth it promotes laminar flow, which is faster and more stable.
A turbo, exhaust gasses go into the turbocharger and spin it, with a supercharger, air goes in,witchcraft happens and you go faster~Jeremy Clarkson
Old August 12th, 2010, 08:13 PM   #3
Codeman's Avatar
Ok are you sure? I have heard it both ways?
Old August 12th, 2010, 08:48 PM   #4
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
What I have heard is you make the lower as smooth as you can, but with the heads, you want rough in some spots.
271rwhp N/A V6
Suck it.
Old August 12th, 2010, 09:43 PM   #5
Codeman's Avatar
Ok well I will use a sanding stone bit and smooth it out. That should make it pretty smooth.
Old August 12th, 2010, 10:29 PM   #6
99 BLUE V6's Avatar
99 V6 BASE
NEVER RACED THIS ONE
99 BLUE V6 has a spectacular aura about99 BLUE V6 has a spectacular aura about
Use the stone to knock down the high spots. Then go through with like a 36 grit sanding roll about 3/4 diameter. Then hit it with a flapping paper aprox 60 grit medium speed. look for high spots and do it again. Then finish it with a 60 grit sanding roll slow to medium speed. Without going into great detail that should get a rookie headed in the right direction. I spent about 8 hours on one before I'm ready to polish.
Old August 13th, 2010, 12:47 AM   #7
v6kid's Avatar
1999 Mustang v6
v6kid will become famous soon enough
^ that is beautiful work!^
I went to school to be a mechanic, so I know what I'm talking about most of the time.
mods in the garage, slowly getting peppier.
6ershootout.com summer of 2012... Be There
Old August 13th, 2010, 01:09 AM   #8
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
what i always wondered about porting is, how do you guys know you porting the entire length of the runner evenly,does it need to be that perfect?
2004 Bolt on & Cammed 3.9L V6
Old August 13th, 2010, 08:19 AM   #9
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
I think they have kits to make sure the porting dead even
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old August 13th, 2010, 09:05 AM   #10
nukeman13's Avatar
99 mustang v6
nukeman13 is on a distinguished road
where can u get these kits from?? i been lookin into polishing.. idk if im good enough to port but i was gonna go to the pull a part and grab some so i dont have to take mine off and if i mess them up it wont hurt anything lol
Old August 13th, 2010, 10:10 AM   #11
Codeman's Avatar
I just try to keep it as even as possible all the way through. I am eye balling it.
And holy crap blue!!!!!!!!!! WOW mine looks like crap compared to yours
I have put about 5 hours into mine so far. I need to get a new air grinder because mine the end is bent I noticed so the bit trys to jump. Making it difficult to control.
Thanks for the gaskets. And I am going to have to buy some more bits lol. I need one of them flapper things. I got sanding rolls and those sanding stones like that.
Old August 13th, 2010, 12:10 PM   #12
99 BLUE V6's Avatar
99 V6 BASE
Its not nessacarily even all the way through.( not sure what you mean) Sometimes you have to move a wall over or take a hump out or even redo a radius. Its also important to have a good entree from manifold to head with out a very sharp turn. That sometime requires a little reshaping.
Old August 13th, 2010, 12:13 PM   #13
99 BLUE V6's Avatar
99 V6 BASE
If a mans going to be in this line of work he's going to need some tools. LOL LOL
Threads Similar to: Porting Update
Intake porting update. lol Mr. Red Pony V6 Mustangs 9 May 29th, 2010 10:13 PM
almost done porting SWEET2KSTANG 99-04 7 July 21st, 2008 09:55 PM
porting a 4.6 DickH 99-04 11 June 1st, 2008 02:36 AM
Porting Codeman V6 Mustangs 13 April 6th, 2008 11:27 PM
Pro 5.0 shifter update/vid update 07stanggt 2005 - 2010 43 February 29th, 2008 10:17 PM
