broken odometer
Old August 13th, 2010, 11:50 AM   #1
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
broken odometer
need to fix/replace a broken odometer in my 94 before i sell
any suggestions, need to roll it to about 110k miles maybe 105k
idk how they work in those cars, if tied into trans or what
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old August 13th, 2010, 08:12 PM   #2
brett22's Avatar
2004 Mustang V6
heart of a 4V
brett22 will become famous soon enough
Pictorial Guide to Ford Odometer Gear Replacement
To see exact location of the screws to be removed, Please see picture below of the left side as this is a mirrored location of the right side of cluster.
You will need to gently pry under the face of each gauge cluster to remove, using a flat blade screwdriver. It is best to remove the left and right gauge clusters first and then the speedometer. The gauges are held into place by electrical studs that press through electrical contact sleeves.
The five (5) illumination bulbs are part number #194 and can be purchased from your local autoparts store. Great time to switch gauge backlighting color
The gauges will synchronize once reinstalled and the ignition switch is switched on.
When trying to remove the motor you may either have to depress or lift up on the plastic tabs.
It is easier to do this with two people but can be done with only one person.
Once the motor is remove you will also see the worm gear attached to the bottom side of the motor. If replacing remove the old worm gear by pulling off. Install the new worm gear using channel lock pliers leaving the thickness of two business cards between the motor and the gear.
There is no need to apply grease to the new gears as our gears have graphite mixed into the material.
Reverse Order to complete installetion.
Source: odometergears.com
Turboed 4.6 4V build in progress
Milwaukee School of Engineering
Class of 2015, BA in Mechanical Engineering
2004 Terminator 100% Stock 5000 Miles
Red 2004 V6 (swapping in a turboed 4.6)
Old August 13th, 2010, 08:18 PM   #3
2004,1994,1967
14.37 @ 96
thanks, for the info man, havent even attempted to look at it yet, just wanted some heads up
227whp N/A V6
Old August 14th, 2010, 03:09 AM   #4
KennethRichard's Avatar
1997 V6 Mustang
0-60mph 9.7s
KennethRichard is on a distinguished road
+1 ^
i acutally am going through the same problem right now. those are the instructions i used, its really easy to get to, the only pain, is you gota take it apart to see if the teeth are broken first before ordering, so right now mine is halfway put together until my new piece comes.
BUTTT.....
do not take the needles off if you dont have to, i at first read the instructions wrong and took off all the needles and thought i had to pry the black part off, not know it and the clear plastic was one piece =\
so i spent a long time trying to remember where the needles go and getting them right, so if you need to take them off, Take a picture!! otherwise if you keep them on, and even if you move them a littlebit, they should recalibrate once you plug it back in and start your car. and where they belong
Odometer Gears | 72 Croatan Road | Newport News, VA 23606 | 757.593.3478
thats the website to get the new gear if thats whats broken for you. Its $29 after s&h and all that jazz
Threads Similar to: broken odometer
Broken odometer on a 98 gt. 97S281 96-98 11 March 9th, 2010 11:55 PM
Odometer lwhitetrash88l V6 Mustangs 5 January 26th, 2010 04:13 PM
Odometer wannabeimportkiller 96-98 16 January 5th, 2010 05:01 PM
Odometer!! 97mustanggt Audio/Video 9 December 19th, 2008 02:51 AM
Odometer help please! militant54 Audio/Video 10 August 18th, 2007 03:24 PM
