Could it be the CPS? - Page 2
Old August 13th, 2010, 02:59 PM   #21
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Bent connecting rod. I just remembered that when I bent mine is was misfiring a lot. And when they took it out they did a compress test and that cylinder was about 20 PSI less. (my piston was hitting the crank a BDC though) It wouldn't put as much pressure in the cylinder because the piston wasn't going up high enough.
271rwhp N/A V6
Suck it.
Old August 13th, 2010, 03:15 PM   #22
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Originally Posted by Walters97Racing View Post
the only tbs i see remotely related is this
NOTE FOLLOW THIS TSB PROCEDURE ONLY IF THERE ARE NO SPECIFIC MISFIRE TSBs/SSMs RELEASED FOR THE VEHICLE SYMPTOM BEING EXPERIENCED.
ISSUE
Approximately 50% of coil on plug (COP) coils returned for warranty do not have a problem.
ACTION
The misfiring cylinder must be identified through Self-Test misfire codes or through WDS Power Balance. Rule out base engine problems, rule out fuel problems, and then look at ignition problems (be sure to rule out coil primary circuit issues). Once the above steps have been completed, and the issue is in the secondary part of the ignition system, the oscilloscope procedure outlined in this TSB can isolate the difference between a coil or spark plug problem.
How does this relate? If its about anything remotely close to our cars (push rod 3.8/3.9) it doesn't have COPS.
Originally Posted by Mr. Red Pony View Post
Possibly not a valve closing completely allowing just a little air to escape. That's my guess. But you would figure if it would let a little out, it would let all out. I think if it was the CPS it would cause it on all. Is the spark plug letting air past it? right before I blew out a sparkplug it was missfiring on that cylinder. Could be a combination of those WITH a faulty injector.. It is fuel injected right?
Valve not closing is one of the tracks I had in my mind when I said valvetrain, and it doesn't have to let all out depending on how its bent/burnt/chipped/etc.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old August 13th, 2010, 03:23 PM   #23
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
I think it is the connecting rod. Is said engine 'real'? have you seen/heard it if so?
271rwhp N/A V6
Suck it.
Old August 13th, 2010, 07:48 PM   #24
8A_Honda is on a distinguished road
Well, I'm sure it has to be real. He told us that one of the keypoints to remember is that it's a 3.8 liter Ford motor. So after hearing that, it leads me to believe that it's a common problem with this motor. I could see it possibly being a bent rod or something, but makes me wonder why it'd only happen on the #1 cylinder and not the others.
Old August 13th, 2010, 08:16 PM   #25
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
I would think the miss fire part is because the lower psi, wrong mixture cause a premature detination or such not an expert so not saying thats right, doubt it would be a computing problem, sounds mechanical to me. the bent push rod idea sounds like its in the right direction, anywhere between cam and piston, so valves, springs, retainers, rods. like i said im no expert but that would be my guess from what little i know. im curious though sounds interesting to learn. i didnt take it but, sounds like your auto tech is more in depth than my hs was lol
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old August 13th, 2010, 08:57 PM   #26
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Im starting an auto tech class monday!! I get to sharpen my knowledge.
271rwhp N/A V6
Suck it.
Old August 14th, 2010, 01:21 AM   #27
rfcsoulja's Avatar
01 True Blue v6
to slow to matter
rfcsoulja will become famous soon enough
Would a valve not seating correctly cause a missfire?
My supercharged v6
http://www.youtube.com/watch?v=1lNkgKBw0bw
Old August 14th, 2010, 01:23 AM   #28
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
When are you going to install my cam?
271rwhp N/A V6
Suck it.
Old August 14th, 2010, 02:11 AM   #29
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
yes.
Old August 17th, 2010, 10:52 PM   #30
Okay folks. Sorry for the late reply but I was sick and skipped school yesterday. But anyway, the answer was kinda retarded cause we really didn't get all the info needed. Anyway, here's what happened.....
The headgasket blew and leaked coolant into the cylinder. It bent the rod but they didn't know it. They fixed the headgasket so there wasn't a leak in compression but it was lower because of the bent valve. I know the 3.8's are bad about headgaskets so that was the 1st thing I said. But he said the leakdown test showed no leakage. Anyway, that's the cause but was kind of a b.s. answer really cause he didn't tell the history at all. Had he mentioned that it HAD a blown gasket, I would've known the answer right away. But thought I'd report back on what it was.
Old August 17th, 2010, 11:58 PM   #31
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
I win!! I was going to reply today and ask if the head blew, because I asked MY instructor and he said the essex engine have head gasket problems.
271rwhp N/A V6
Suck it.
Old August 18th, 2010, 12:10 AM   #32
streetscraper1's Avatar
96 Boosted GT
streetscraper1 is on a distinguished road
so it had a bent valve and rod?
Old August 18th, 2010, 12:15 AM   #33
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Yup. I wonder how the valve bend though. But I bent my rod from a bad head gasket and had all those symptoms.
271rwhp N/A V6
Suck it.
Old August 18th, 2010, 12:29 AM   #34
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Oh look, exactly what I thought it was...
Old August 18th, 2010, 12:30 AM   #35
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
WE were right sir.
271rwhp N/A V6
Suck it.
Threads Similar to: Could it be the CPS?
cps injected03stang 99-04 4 October 20th, 2008 03:27 PM
CPS?? CBSTANG 5.0 Mustangs 1 January 24th, 2007 09:37 PM
